Question about Hardware & Accessories
How to set tork outdoor timer model no.sa0022
Nt to know how to set timer
  • 5,089 Answers
Timer is not identified.
1) Copy following links to help identify SA0022 timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
2) Add comment and describe timer in exact detail so expert can possibly identify same-similar manual
Posted on Dec 03, 2012
SOURCE: I have a Tork timer model number 1101 24 hr time
Tork 1101 is a 120V mechanical dial-type timer
c79f9b8.jpgTork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
Posted on Oct 15, 2010
  • 15 Answers
SOURCE: I have a Tork dzm200bp timer and do not have
http://www.tork.com/pdfs/tork/ssamoreinfo.pdf
or
http://www.tork.com/tork/productdetail.aspx
Posted on Nov 06, 2009
SOURCE: Model 59204EV Outdoor Mechanical timer
Different Woods timers have same model number, depending on who packaged and sold product.
Manuals are sometimes generic. They say pins when they mean segments or tabs.
Segments are small plastic divisions located around outer edge of dial.
They divide 24-hour day into 15 minute or 30 minute periods.
Link below shows sample pins and tabs.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
With the 15204, I believe these segments pull out or push inward; but they could also pull upward or downward.
Move a couple segments, plug in the timer and lamp, and then manually rotate dial to watch how lamp turns on-off.
Lamp must be turned ON and bulb working.
Some 15204s have a switch on face of timer, or somewhere on timer. Some do not have a switch, and some have a dial. Move switch to TIMER, or to AUTO. Or rotate dial to ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, any do-it-yourself project.
Posted on Jan 13, 2011
SOURCE: I don't know how to set the timer to come on a 7
See T1100 Tork timer on following link:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
To set this timer, rotate clock dial clockwise until current time lines up with the word 'TIME' located at 5 o'clock position.
Place black and gold P47 trippers at times you want timer to turn on-and-off.
As time passes, the dial rotates. ON tripper flips a lever that turns Load ON, and then later, the OFF tripper flips same lever and turns Load OFF.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 23, 2011
SOURCE: i have a noma outdoor digital timer, model n1502.
Link below has photo of timer to confirm correct timer.
Manual and other information also show about timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
Posted on Jan 24, 2011
INSTRUCTION MANUEL FOR Tork 654A Digital Outdoor Photocell Timer
Copy following link to identify 2-outlet, dawn-dusk, Tork 654A digital timer and download possible manual, and read instructions.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#outdoor
Also sold as GE 15255:
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
Nov 11, 2012 | Hardware & Accessories
I have a tork 651a . that only works at knight and its a photo cell,go figure....can you help???????????????
Tork 651 timer is dawn-dusk that automatically turns on at dusk.
Open following link to identify timer and download instructions:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#651
If you want ordinary 24-hour on-off timer for outdoors, instead of dawn-dusk timer, then select Tork 611A or Tork 601, or Tork 611 timer shown on same link above.
http://waterheatertimer.org/How-to-set-timers.html
Jul 25, 2011 | TORK 651A Photocell Controlled Mechanical...
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
Is there an instruction booklet available?
Instructions for tork timers:
Tork makes several timers that look similar.
Link above has photos of each type with manuals.
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
I have a Tork timer model number 1101 24 hr time switch. Can you tell me how to set it???
Oct 14, 2010 | TORK 651A Photocell Controlled Mechanical...
I have a 15 yr old tork 1101 pool timer. I misplaced the tripper pins the replacements P-47 dont fit. What do I do
1) Tork P47 tripper is correct tripper for 1101 timer.
Trippers are brass-colored and black-colored.
If they do not fit timer dial you might need new timer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
2) Buy new 120Volt indoor/non-weathertight Tork T1011
To identify timer for sure:
3) Google search Tork 1101 shows timer cost $83
4) Intermatic cross reference shows replacement is T-101 indoor/non-weathertight
Amaxon sells T101 for 43$:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
5) Raintight/outdoor: Aplus and Lowes sell raintight outdoor T-101R for $71
http://www.lowes.com/pd_29405-251-T101RD89_0_
http://www.aplussupply.com/intermatic/timer.htm
6) Cross over wiring.
Tork terminal X is T101 terminal A
Tork terminal 1&L are T101 terminal 1
Tork terminal 2 is T101 terminal 2
Jul 11, 2010 | TORK Digital Interval Timer Ssa100r-24
Hardware & Accessories Logo
369 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
