Question about La Spaziale Mini Vivaldi II Espresso Machine
Boiler not heating
I inherited a Spazio EK espresso machine, and the boiler won't heat up (I think the water level got too low). Is there a reset switch that will fix this, or am I out of luck and have to replace the heating element?
Mcdonnell Miller automatic feed valve does not seem to supply enough water for steam boiler. Is there an adjustment?
Steam Boiler Water Feeder Valve Repair FAQs
inspectapedia.com/heat/Steam_Boiler_Water_Feeder_FAQs.php
It does not say, what causes high level of water in the steam boiler. ... High pH in your water supply can cause foaming and water feeder troubles; .... I have a clearenough understanding of the condition of your water feed valve .... My system has separate McDonnell and Miller automatic water feeder and Low water cut off.
Steam boiler Automatic & Manual Water Feeder Valves
Dec 21, 2015 | Coffee Makers & Espresso Machines
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
Boiler Making popping sounds when heating
Not much else you can do unless you want to open the boiler to clean it out. Yes, I like the Francis Francis too!
Oct 05, 2012 | FrancisFrancis! X1 Espresso Machine
Boiler pressure (steamer pressure) is at 0. Usually, when it goes down it comes back up in few minutes but not today. Also, the water coming out for our espresso shots is not as hot as it should be and our...
Problem is either the element, the pressure stat or the reset thermostat on the boiler left side if the model is equipped with one, has tripped, possibly because the machine is low on water in the boiler or the contacts for the pressure stat are damaged or dirty. First I would check the water level in the boiler then remove the left side panel and check the reset switch and press it in, then turn on machine to see if it heats up. If you do not have a reset switch on the machine then check the element and pressure stat to make sure they are working properly, do a resistance test.
May 28, 2011 | Astoria Argenta SAE-2 Espresso Machine
Hi! I have a Rancilio epoca DE 2 group machine and the antivacuum valve spurts water as the machine is heating up. ow can I fix this? Please advise
Your boiler is flooding because the water level probe is not behaving properly. The machine thinks it needs water.
Jan 09, 2011 | Rancilio Epoca ST-1 Espresso Machine
Water safety sensor preventing heat up of boiler?
If the red light is on then the machine is not getting water and or level is low in boiler. Try this remove the bell looking softener and run it under the faucet to see if water flows through, it could be that is blocked and not letting water through, and if so then the reset switch for element might have tripped because machine has low water.
Jul 02, 2010 | Rancilio Epoca ST
After several failures, I replaced the pressure stat on my Pasquini Livia 90, only to find that the water would not heat. I put back the old stat, but it still doesn't work. Can anyone help?
Hi
Check the wire on the water reservoir to make sure that it is properly connected.
Check to make sure the wire connection is clean and making good contact.
If the machine turns on the connection is dirty, so you will need to remove nut and clean.
There is a level probe on top of the boiler (actually 2) The right one (yellow wire) is the low level probe and it will not let the boiler turn on unless it sences water at the probe. If it is scaled it can't tell if there is water in the boiler and the element will not heat. Remove and clean the probe.
Jun 03, 2010 | Abernook Pasquini Livia 90 Automatic
Gaggia Syncrony logic loses water pressure. If left unused for an hour or two it only dispenses half the water it should. After this it's ok until not used for a while. Any ideas?
Yes the machine should not be left on for that long, it only takes a few minutes to heat up. It does not have an auto refill if the boiler is low on water.
If it heats up the water in the boiler for over an hour, it is safe to assume, that the water might at some point turn to steam, when you use it for the first time, it flushes out all the steam, and fills the boiler with water.
Feb 20, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Livia 90 - Power on no pressure
When you say no pressure do you mean steam pressure or water pressure?
If it is steam pressure the machine is not heating up, then the elements could be damaged, disconnect the machine from power open top 4 screws on the top panel, you will see the boiler and element(middle of the boiler with 1 wire on each of the terminals) disconnect both of the terminals and check for resistance between the terminals, if you get a reading then the element is fine.
The bottom level sensor is not reading the water level and told the machine to not heat(stainless steel probe sits on top of the boiler there are 2 of them one checks the min water level and other checks the max water level, disconnect one of them and using ohms meter check reading from the stainless steel level to the top of the boiler, if there is a reading connect and then check the other one using the same method. If there is no reading on any one of those they might be covered with scale buildup or there is no water in boiler.
The machine cannot read the water reservoir(screw with ground connection on water tank).
There is also the Pressure stat(black box which sits on top front right of the machine with 2 electrical wires going to it), remove wires and check with ohms meter.
Mar 27, 2009 | Pasquini Livia 90 Espresso Machine
La Spaziale Mini Vivaldi II Espresso Machine Logo
Top La Spaziale Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a La Spaziale Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
