Question about Pacific Image (PRIMEVIEW801)
Cant get key lock off my pacific 1002 dvd player
After playing, dvd unit smells and quits playing. Saw online that there was a recall on ones bought at Walmart. I purchased at walmart but they said to contact Durabrand.
Recall on certain models of Durabrand DVD:
Pink: UPC 1799934100, Model No. 1002 PINK
Silver: UPC 1799901002, Model No. 1002
Purple: UPC 1799932100, Model No. 1002 PUR
https://www.cpsc.gov/Recalls/2009/wal-mart-announces-recall-expansion-of-durabrand-dvd-players-due-to-fire-hazard
Jan 14, 2016 | Durabrand DVD-1002 DVD Player
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
I cant get the key lock off my pacific 1002 dvd player
If it has a key lock the instruction manual will tell how to clear that--no manual? Google the mode number with manual to see if can locate one.
Dec 02, 2012 | Televison & Video
Pacific DVD player 1002 Mk2. Insert disc and display informs "loading " and then" No Disc". Checked menu and find it will not accept/enter scart RGB. No manual available. Could this be aproblem with the...
You have a clear case of the failure of the optical head. If you are familiar with electronic works then you must purchase the same model for replacement. Many spare part shops would do this for you at a nominal cost because the short in the new unit for prevention of static charge must be opened with care. Hope this helps
Jun 30, 2010 | Televison & Video
NESA DVD-1002 Car DVD - Region Codes
Oh that sucks... I had the same issue with a Sony Xplod Indash DVD Player, You have to contact the Manufacturer, They will either replace the system, or explain to you how to fix it, In my case they replaced mine.
Apr 14, 2010 | Nesa Vision DVD-1002 Car DVD Player
Need to know what formats are supported by the Durabrand 1002 DVD Player.
The complete Detail would be :-
Product MPN MPN DVD-1002
Key Features DVD Type DVD Player Number of Discs 1 Progressive Scan With Progressive Scan Playable Disk Types CD (Audio), CD-R, CD-RW, DVD Video, Picture CD Playable File Formats JPEG, MP3
Audio Surround Sound Dolby Digital (Digital out only)
Connections Outputs Composite x 1, S-Video x 1, Analog Audio x 1, Digital Audio Coaxial x 1
Convenience Remote Control Standard OSD Yes
Other Features Exterior Color Gray
Miscellaneous UPC 017999010026
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | Durabrand DVD-1002 DVD Player
Dvd wont play
the Durabrand model dvd-1002 is not a blu-ray dvd player. It can only read the regular non-bluray discs.
May 15, 2008 | Durabrand DVD-1002 DVD Player
Lost code
Please post the make and model number of your tv or go onto the manufacturers website to find the manual.
Dec 31, 2007 | Durabrand DVD-1002 DVD Player
Quick Start Guide for Durabrand DVD 1002
place one end of the scartlead into av 1 or av 2  on back of  tv,
other end of scart to dvd player .
plug dvd player  in,and turn on dvd player it should detect the dvd and turn to dvd channel automatic .
Oct 23, 2007 | Durabrand DVD-1002 DVD Player
Pacific Image (PRIMEVIEW801) Logo
128 people viewed this question
Top Pacific Image Televison & Video Experts
Electro Med Services...
Are you a Pacific Image Televison and Video Expert? Answer questions, earn points and help others
