Question about Electrolux EIMED55I Electric Dryer
Can't get electrolux dryer to perform an installation cycle
    Top Expert:
  • Electrolux Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Dec 03, 2012
Electrolux Insight Iron Aid. Why does it steam up kitchen?
Electrolux Wave Touch Dryer Problems. It Leaks! - YouTube
? 2:12
https://www.youtube.com/watch?v=uMFpFVOFE5M
Sep 27, 2012 - Uploaded by erik malewski
My less than a week old Electrolux Wave Touch Dryer leakedfrom the perfect steam inlet all over my ...
Water under my Steam Dryer (May: condo, appliances, house ...
www.city-data.com > City-Data Forum > US Forums > Oklahoma
Aug 15, 2012 - My washer and dryer is an Electrolux designed in Italy to Sears ... wasleaking; but the repairman said it wasn't and that the dryer just had built ...
Electrolux steam dryer Questions & Answers - Fixya
Jan 01, 2016 | Dryers
Have a Electrolux dryer and the moisture bar pulled loose by bib overalls and have the new one but am not sure which wire terminal goes where. 2 wires and the dryer used to dry on one normal cycle but
Hello lester haugstad, thank you for your post!
I understand that the moisture bar inside of your Electrolux dryer was pulled loose and you would like to reattach it. I have researched and there is not an available part guide to show how the moisture bar is reattached. I would recommend seeking assistance from a professional for proper installment of the part. I hope this information has been helpful. -Matt
Oct 16, 2014 | Electrolux Dryers
I have an Electrolux Dishwasher that always starts on low rinse
Hello Friend, this is Z. Thank you for your post!
I see that your Electrolux dishwasher starts cycle on low rinse. This typically indicates your dishwasher has low rinse aid. The RINISING AGENT LOW light, typically located near the Rinse Only Pad, comes on at the end of cleaning cycle when the rinse agent reservoir is low. The light will remain on through 5 successive cycles or until the reservoir is filled. Also, using rinse aid will enhance dryer performance and reduces water sports and filming. Hope this helps!
Jun 04, 2014 | Electrolux Dishwashers
Electrolux Gas Dryer: E66 error
Should the heater wire have electrical continuity to the housing
Mar 08, 2012 | Electrolux EIED55H Dryer
I have an E63 Dryer Error on my Electrolux Dryer - My husband is able to test and fix if someone can provide some information on the steps he needs to take. Please advise.
Hello & Welcome to FixYa
Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Please get back to me if you have any other questions.
Kevin
Dec 16, 2011 | Electrolux EIED55I Dryer
My stackable washer/dryer is taking at least 3 cycles on high heat before it will dry one load. It's heating up but it doesn't get hot enough. I've checked the venting and it is clear and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 19, 2011 | Electrolux Dryers
I have an electrolux ewx1440w washer-dryer. It keeps stopping part way through wash cycle. Cycle pause light flashes and door catch releases allow you to be able to open door. Machine will not restart...
Hi I exactly have the same problem.. seems to be a common issue with this Electrolux series.. Thought that Electrolux was serious brand but obviously quality is leaving our world.. did you fix the problem and how..?
May 20, 2010 | Microwave Ovens
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Electrolux EIED55H Dryer
Electrolux Lavamat Turbo 16830 Washer/Dryer but dryer not working
Has the little belt on the dryer turbo come off? or is the turbo seized - it should turn freely by hand. You may need to replace the turbo fan if the belt keeps coming off - the pulleys can get out of alignment, ie not running parallel to each other - they tend to be cheapo plastic construction these days. Could also be dryer elements or thermostat problems, or blockage with lint causing reduced air flow and overheating - but check belt first.
Nov 28, 2017 | Electrolux EW1209i Front Load Washer /...
Electrolux EIMED55I Electric Dryer Logo
175 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
