Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
No water from dispenser
Water isn't coming out line appears to clogged or frozen. Any ideas?
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Check the water tank in the refrigerator section.
Posted on Dec 03, 2012
  • Tricia Menture
    Tricia Menture Dec 03, 2012
    We lowered the setting on the freezer and it seems fine now. I think it was frozen. Thanks
  • mdaeng Jul 22, 2014
    water line creased / blocked / frozen dispenser mechanism faulty or broken goodluck
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: frozen water line
GE has a heater kit available. I can email you the sevice bulletin in PDF format and you can se if its something you can do.
Posted on Dec 02, 2007
SOURCE: Water dispenser not working
water wont dispenser from door
Posted on Jul 29, 2009
woodchuck789
  • 4070 Answers
SOURCE: Water not dispensing - ice is working properly.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
Posted on Mar 11, 2010
Sea Breeze
  • 4655 Answers
SOURCE: My hotpoint side by side is not dispensing water,
In this case the dual water control valve side that turns the water on for water dispenser found here as location 800 in photo=> HSM25GFRASA Motherboard and Compressor Components
I believe you replace this part=> WR57X10051 Water Valve - Dual Outlet
And you will be good to go for dispensing water! Click here for a Service manual that will work with your model=> Here Please rate this solution and If you have any questions please let me know, Thank You Sea Breeze
Posted on Oct 10, 2011
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
Water dispenser and icemaker not getting water on a maytag fridge
pull line off of the back of fridge to see if water comes out if not its where ever you have that line taped into yuur water supply for the fridge had the same problem hard water clogged up the tee off take it off poke some thing in the little hole make sure you have the water shut off to the water supply when was the last time you changed the filter in you fridge it could be tht too
Nov 12, 2011 | Refrigerators
No water from dispenser, ice is fine. Tried the hair dryer and light on and solenoid ideas. Still not working. Any idea how to get to switches on door panel, they must be next check or any other ideas?...
I've had the same problem. Take the grill off the lower front of the refrigerator and disconnect the water line at the coupler. Get a small shallow pan or container to catch the water and place the water lines in the container and press the dispenser for water. If water comes from the long line coming from the rear of the unit the filter and water valve are fine. The line going up to the dispenser is most likely frozen. Thawing it is a real chore.
Feb 07, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser does not dispense water. the ice will dispense But any ideas would be appreciated and i am not the best fix-er-upper but can understand easy and simple steps. Model number of fridge is (GE...
Several possibilities. Clogged water filter (can be eliminated if you dump the ice bucket..if it makes two more batches of ice it's not the filter). Frozen water container (behind lower refrigerator drawers) or bad fill valve behind the refrigerator where the water line goes in. Likeliest is water valve.
Final possibility is a frozen water line inside freezer door. This would NOT be desired nor would you be fixing it yourself. Good Luck.
Aug 24, 2009 | Refrigerators
My water dispenser flows very slowly. The unit is
Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
Thanks for using fixya
proton
Aug 14, 2009 | Refrigerators
The frigde stopped dispensing water. I replaced the inside the fridge water filter, but it still doesn't dispense water. The ice maker is ok so it's getting water. Any ideas on what I can try next?
OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 10, 2009 | Refrigerators
Water won't dispense
check water container in fridge is not frozen up
Jun 19, 2008 | GE Refrigerators
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
166 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
