Question about Microwave Ovens
My Neff microwave combination blows the internal 10amp fuse after about 5 secs.
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
Have someone look at the unit----shorted diode? Or bad inverter or MAGNETRON---10 amps means something serious is bad.
Posted on Dec 03, 2012
fridgetech
  • 473 Answers
SOURCE: Microwave keeps blowing fuse
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Posted on Nov 19, 2007
wiznet2000
  • 86 Answers
SOURCE: keeps blowing fuses
This problem is just like my own microwave, replace the shorted HV capacitor
Posted on Jul 27, 2009
MicrowaveSvc
  • 9098 Answers
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Posted on Oct 09, 2009
Testimonial: "Thanks for your help. Customer Services were no help. Can you please advise which type of caulking to use."
beltronic205
  • 1474 Answers
SOURCE: SIZE OF INTERNAL FUSE
Check to see if its marked on the panel itself could be an 8 amp 1.1/4 inch size ...you must fit the correct amp fuse for safety also be careful as the Capacitor may hold a charge and can be lethal voltages within...good luck.
Posted on Apr 12, 2010
Neff b6774N0gb/02. Inner glass shattered. replaced. Internal fuse blown. replaced. Now microwave working (heating water) for approx 5 sec, then switching off, beeping and showing E1 fault. Also display...
Usually if this model stops after approx 3 secs it is an invertor or mag fault. Check that the aerial cover is clean Page 3 of the breakdown part position 315. If this is really grubby it would be the cause of the door shattering. The PTC is not used on the microwave function so may be an additional fault. Check also the alignment of the door switches as this can also cause a similar fault. My best guess is if you remove the mag, you'll probably find scorching on it and it (and the invertor) will need replacing.
Mar 25, 2013 | Neff Microwave Ovens
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Neff h5642 doesn't start at all. No lights, no display. What should I check first?
safety fuse (internal) will have blown usually caused by faulty inverter short circuit if fuse changed and blows again this is what it will be costly repair if out of guarantee.
Apr 19, 2010 | Neff H5642 Convection / Microwave Oven
Microwave starts as normanl but cuts out after 5 seconds on all settings?
sounds as either inverter or magnetron is faulty difficult to diagnose although when mag fault usually runs for about 22 secs inverter fails sooner around 5 secs.
Apr 09, 2010 | Neff H5642 Convection / Microwave Oven
NEFF MICROWAVE OVEN BLOWS 10A INTERNAL FUSE
We had the same problem, got Neff service engineer to come out after taking out insurance. He said the megatron cracks which is a large magnet and causes the fuse board to blow and needs to be replaced. This occurs through lack of ventilation on instalation. Total cost £370 may as well get a new one. Plus our insurance wouldn't pay the cost and cancelled the insurance policy.
Mar 24, 2009 | Neff H5470 Microwave Oven
Neff combination microwave oven
We have had NEFF repair man out again and he replaced the door switchs and this time it is OK.He did say if it was a problem again it will be classed as unrepairable because he thinks it is shorting out on an internal rivet on the bodywork which is inaccesable. fingers crossed it was the door switchs and it dosent blow the main fuse again .thanks for your responce. Simon.
Jul 23, 2008 | Microwave Ovens
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Microwave Ovens Logo
147 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
