Question about Acer Aspire 5100 Notebook
Dow to defrag acer aspire 5532
My laptop is getting very slow and I have been told to clean out temp files and defrag the hard drive but can't figure out where to do that. Help Please and Thank You.
preachw996
  • 1179 Answers
SOURCE: My Acer Aspire 5100 Laptop wont detect the hard drive
If it works on another computer then either the ide cable in the acer is bad/loose at either end or the ide controller on the motherboard is bad. I would try a known good ide cable first as if this is the problem it is fixable alot cheaper than a motherboard. Hope this helps.
Posted on Mar 27, 2009
SOURCE: Acer Aspire 3050 Laptop running slow Changed
1st go through your 'programs and features' in your control panel and delete anything over around 100Mb unless it is necessary, a lot of ram is taken up by these programs even when they are not being run.
Posted on Sep 28, 2009
SOURCE: How to replace the DVD drive on Acer Aspire 5002
I actually had to permorm this action yesterday.
First remove the small strip above the keyboard by unscrewing the three screws at the back of the machine that hold it; then twisting the screen al the way back and lifting it up.
Second unscrew the keyboard (2 screws) and lift it away (don't detach the cable).
Third: on the left side under the keyboard unscrew 3 screws that hold the cdrom in place.
Pull the drive out. The rest (taking the case of the dirve) should be transparent.
There is nothing on the bottom you have to unscrew!
anthon@mnt.org
Posted on Nov 05, 2009
  • 3 Answers
SOURCE: how do i trun my acer aspire 5532 wabcam on.
webcam should be listed in your My Computer files
Posted on Jan 03, 2010
tech-guy818
  • 33 Answers
SOURCE: how do you get acer aspire 5532 microphone working
visit here http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012 , choose your operating system, and try to download and install AUDIO DRIVER
Posted on Mar 11, 2010
Acer aspire 5720, after erasing everything, still getting "low disk space" message. beyond disc cleans & system defragmenting...Any suggestions?
Hi Brandon, You can try cleaning the temp files Click Start >> Run, then type %temp% Enter, then delete everything in that folder.
Please download CCleaner to clean up your registry
CCleaner Download
Mar 11, 2014 | Lifetime Acer Aspire 5720-4126 Replacement...
My Acer Aspire 5742 runs so slow even after a reboot, what can I do? Thanks. Kevin.
Hi Kevin...you can install a free software like cc cleaner and run to remove cookies and temp files on ur PC
->perform a defrag of the Hard disk
->you can increase virtual memory
->you can disable some unwanted programs at startup
->can do a registry cleanup if it works well and good if not
my email address is jalander.reddy@gmail.com please email me when ur free and ur convenient time so that i can take and work on ur PC and try to optimize ur PC performance..n it wud be for free.
Oct 01, 2013 | Acer Aspire One AOA150-1784 Netbook
Computer slow and freezing
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer freezes problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 02, 2013 | Acer Aspire 5500 5570-2609 Laptop
My new Acer Aspire5560 is very slow
Delete programs you never use
Limit how many programs load at startup
Defragment your hard drive
Clean up your hard disk
Run fewer programs at the same time
Finally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that made your system slow
Sep 02, 2013 | Acer Aspire 5560 Laptop Charger...
Slow acer aspire 5520g
Disk defragment is first step. This will locate files closer to each other on the hard drive. Should be located in system tools. Other than that I would save all important files externally and format the drive and start fresh. Beyond that, you would probably need to upgrade.
Apr 14, 2013 | Acer Aspire Computers & Internet
How to fix or get rid of service error alot
Is the screen frozen BEFORE or AFTER the screensaver activates? If it's after then try doing a scandisk and defrag of the hard drive to clear up errors. Also make sure to go into MY COMPUTER, right click the C: drive and in PROPERTIES runa clean up to delete the temp files that may be corrupted.
    Sep 10, 2012 | Acer Aspire 5720-4984 Notebook
    Acer aspire 5735z
    The games will slow the system down considerabily, which is a good start. I recommend going to www.download.com Type ccleaner and install, gets rid of a lot of junk on the hard drive, one of the best and it is free, then defrag the hard drive for better performance.
    Jul 01, 2012 | Acer Aspire 5500 5570-2609 Laptop
    Hard drive needs cleening
    Open My Computer and right click on the C drive and select Properties. Click on Disk Cleanup and after it calculates how much space you can free up it opens up a box that you can check off which areas you want to clean. You probably want to check them all unless you have a specific area you dont want cleaned. This will take a while. After it is through Click the Tools tab and click Defragment now. When the box opens make sure the C drive is highlighted and Click Defragment. This will take a while too. when it is done, reboot the computer
    Jul 31, 2009 | Acer Aspire One AOA150-1405 Notebook
    Acer Aspire 3680 too slow
    Sure but if it has acually been slowing down you must also find the problem. Have you disk cleaned up and defragged your hard drive lately. Cleaned out all the junk from your internet exploier?  Have you gotten rid of everrything that you don't need or want. Slowest thing in a computer is the Hard drive seek/read time.
      According to you manual (Link below) You can have up to 4GB total memory. Two strips of 2GB each soDIMMs
    http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=1016&formid=3425&website=AcerPanAm.com/canada&siteid=7297&words=all&keywords=&areaid=17
    Jan 04, 2009 | Acer Aspire 3680 Laptop
    Freezing in game play
    Need more information on your laptop. Model Number, Processor, Memory Hard Drive. Have you Defrag the Hard drive, Clean Temps File, Clean free space, Derag Memory, Defrag Registry, Clean Registry. Tell me what you have done so far, to help determine whats needed in the future.
    Aug 10, 2008 | Computers & Internet
    Acer Aspire 5100 Notebook Logo
    47 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
