Question about Vizio VW32L 32 in. LCD HDTV
I have a Vizio 32" TV with it set to widescreen. Sometimes when I'm watching cable TV, the screen stretches further by itself causing the edges to not be visible. I try adjusting it to normal and
SOURCE: VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
Posted on Aug 29, 2008
SOURCE: Digital channels freeze
I also had this channel 5-1 freezing problem and spoke with Vizio support a few times. They thought the problem was the SSID code from the local CBS station and said they would try talking with them. I am not certain if they did this or not, but, as of mid December, my Vizio no longer has this problem.
Posted on Jan 14, 2009
  • 131 Answers
SOURCE: 32 plasma Vizio VP322HDTV10A .
Hello; I am John at J D Electronics in Poland, Maine. I have now repaired 9 of this same model in my shop. The set may be dead always or work intermittently. There are 2 versions of this piece of junk, but I have only seen this one. They all have 2 capacitors that fail on the power supply board just above that red chopper transformer. The are labeled C233 and C234. These are 3300 ufd at 10 volts and 105 C temp rating. You can buy these for about $1 each from Digi-Key Electronics plus shipping. There are some cautions worth mentioning. Make sure the set has been unplugged for a day or more before starting the disassembling. It is VERY important to keep the set face down on a soft surface when doing ANY work on the set. This crappy designed set has a glass faceplate that will fall down if you don't have it face down when all the back screws are removed and it is very hard to put it back into position if it falls. The bottom plastic speaker strip has a million screws to remove both from the bottom edge. Then take out all the screws for the metal back and unplug the speakers. The connector wires to the speakers will not just pull off without you pressing on a side release pin for each of the 4 wire- Stupid design again!. If you are not able to solder these parts in , you can send the board to me for $25 labor plus $10 return shipping and $4 for the parts ( or send your own). We accept only cash or USA postal MO. There is NO Warranty on this repair. It is a better than 80% chance this will fix your set. Call me at 207 998 5687 Good Luck! John
Describe your Vizio VP322 32 in. Plasma TV Problem
Posted on Nov 15, 2010
  • 12 Answers
SOURCE: My vizio 32" flat screen keeps shutting off by
sound like the main board is starting to fail
Posted on Mar 07, 2011
Mas Baz
  • 177 Answers
SOURCE: LCD tv Vizio 42 inch has vertical colored lines
hello imvega7, as i know, 42 inch is a plasma display TV.
Refer to your image, and my experience that symptomp because of connection between buffer PCB and panel. Some cases, dirty conection may cause this symptomp.
Un plug power cord, open rear cover, fine pcb on upper or lower panel.
unplug flat cables from pcb buffer, clean soket using a brush. And also clean flat cables using celaner or alcohol.
Wait untill that conection dry. reassembly and try it.
i hope that help you.
Posted on Mar 15, 2011
Testimonial: "Very detailed."
What causes my aspect to constantly change? My tv or my cable box?
It could be both.
If you set your TV to Auto, then it will try to 'best guess' the correct picture shape based on what's displayed on screen. That's okay in the lab, but in the real world where there's too much changing then it's not so good.
The other thing could be the box and the TV channel you happen to be watching. If you have the box's aspect ratio set wrong i.e. to a different picture shape to the TV, then it will squash or stretch pictures.
Set your box to match the TV shape. The two main choices are Widescreen (16:9) or the old picture shape 4:3
Set your TV on a fixed aspect ratio: Either Widescreen if it is a 16:9 set, or Normal if it is a 4:3 set.
Sep 14, 2014 | Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
Nov 10, 2011 | Sharp Televison & Video
I'm watching football and cannot see the top score
You should adjust the aspect ratio on your cable box. Depending on your cable company there should be an aspect/HD zoom button. If this does not work go into the TV settings using the "menu" button and try to find a reference to aspect. Make sure it's set to 16:9 normal vs. stretch. You can contact Total COntrol Remotes (www.totalcontrolremotes.com) for help with this kind of issue.
Sep 06, 2009 | Vizio 42 in. LCD TV
CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
Yamaha dv-c6760 we can only see the top half of our subtitles
Hello shell
I do not believe your problem is with the DVD player. It most likely is with your TV. What happens alot is the picture on a TV is set to a different aspect ratio(ie:4:3,16:9). and sometimes it stretches or zooms the picture, allowing part to be cut off the edge of the screen. This aspect ratio problem can have two causes now that I think of it. The TV or the DVD player. To determine and fix, follow these steps.
PART 1-determining problem-
1 Watch regular TV for awhile and get some infomercials(yes, you have to watch Billy Mayes) on the bottom and edges of the screen, are there words and 800 numbers cut off, if so, your problem is with the TV and skip now to part 2(not step 2)
2 If you can see the whole number and everything , determine if your TV auto adjusts or not. Switch to your DVD player and see if the screens seems to move(shrink or enlarge). If it does shrink or enlarge, your problem is with the DVD player and you can now proceed to part 2.
PART 2-solving problem-
1 By now, you have determined whether the problem is with your tv or dvd player. From this point on "it, it's will refer to whichever has the problem
2 Go into it's menu
3 search for "picture" "video" or "setup"
4 Search for "aspect ratio" or anything containing "4:3" "16:9" or the words "stretch" "zoom" or "widescreen"
5 Set to 4:3 (sometimes 4:3 has multiple options such as stretch, zoom, and normal, if so, select normal)
6 ***OPTIONAL*** If you want widescreen, select 16:9(again if multiple choices, choose normal)
7 Insert or select a DVD and test your subtitles
If this does not work, please post a comment and I will help you further.
Hope this helps and please don't forget to rate
-Chris
May 03, 2009 | Yamaha DV-C6770 Multi-disc DVD Player
Audio humm on VIZIO VW32LHDT30A
You have a bad ground through the cable box or cable system. This causes AC to leak into the TV showing up as bars that roll from bottom to top and sometimes audible as well. Have the cable company replace the cable box and/or check out for proper grounding outside at the demarcation point.
Mar 23, 2009 | Vizio VW32L 32 in. LCD HDTV
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Widescreen cinema mode
Make sure the DVD player is set to 16:9 screen mode.
If you still get the bars at the top & bottom, then its probably because the DVD was filmed in true cinema widescreen, (21.7:9) whereas the TV is only 16:9.
There may be other settings on the DVD player to expnad the picture out, but you will either lose the edges of the picture, or it will be stretched.
Apr 03, 2008 | Televison & Video
Widescreen?
If the programs you are watching are in standard definition they are meant to viewed in 4x3 and the best you can do is stretch them. If they are in HD you need to use the component video inputs or HDMI, then the TV will see you are watching HD and display it in its natural format 16x9. Also some SAT recievers and Cable boxes have thier own size/ratio settings
Apr 21, 2007 | LG 26LX1D 26 in. LCD HDTV
Vizio VW32L 32 in. LCD HDTV Logo
23 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
