Question about Cannon Chesterfield C60G Kitchen Range
Cannon Chesterfield door latch
The roller part of the latch has broken so will have to replace it but it is in the frame of the cooker!
    New Friend:
I need the door for my brown chesterfield main oven door cannot get it from cannon any help out there
louis.pratt@btinternet.com
Posted on Jan 09, 2013
3 Suggested Answers
SOURCE: the clock has stoped working on my cannon
i have the same cooker (in brown colour) and is just 3 years old. The clock was coloured green and over the last 6 months or so has gradually faded to no illumination at all. Then it started to buzz very lightly when the mains was switched on to ignite the gas. In August 2011 phoned Cannon Indesit repair line on 08448 224 224 and agreed to pay £104.99 for call out and labour to fix. The parts are covered for 5 years so no charge for the clock. Engineer took 22 minutes to replace the clock which is now a deep yellow colour and much easier to see in the daytime.
Posted on Sep 09, 2011
SOURCE: how to reset the clock on my cannon chesterfield
Chesterfield gas cooker/clock - doesn't display time, ticking sound in background, timer still works but difficult to set more than 15-20 minutes.
Posted on Feb 23, 2011
GRILL IGNITES BUT WILL NOT STAY LIT
If its not staying on and going out as soon as you let go...then this sounds more of a thermocouple fault to me. All cookers have these on every burner now. Remember always use a gas safe engineer!
Sep 18, 2012 | Cannon Chesterfield C60G Kitchen Range
The clock has stoped working on my cannon chesterfield cooker, why!!
Sep 03, 2011 | Cannon Chesterfield C60G Kitchen Range
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to reset the clock on my cannon chesterfield gas cooker
Oct 17, 2010 | Cannon Chesterfield C60G Kitchen Range
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
Cannon Chesterfield C60G Kitchen Range Logo
325 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
