Question about Frigidaire GLTF2940ES Front Load Washer
Computer shows ddo &won't finish the wash
Wife started a wash & the kid must of hit something because the wash stopped & it beeped the computer screen shows ddo
  • Official Brand Answer
  • 4,342 Answers
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Posted on Dec 04, 2012
4 Suggested Answers
  • 42 Answers
SOURCE: washer won't finish wash cycle
e20 on a lot of machines will generally indicate a water emptying problem. Possible solutions: kink in the outflow pipe, internal blockage which is letting the water away too slowly, pump not functioning each of these needs to be checked.
Posted on May 25, 2010
  • 1382 Answers
SOURCE: The water wont start filling up - it beeps and
The meaning for ddo error means "Dispenser Drawer Open"
To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
SOURCE: water won't go out when the washer finish
i have desame problem, be sure that the washing mach. cover touching the switch (might be on the leftside) if its broken u can replace it.
Posted on Oct 28, 2011
My 02 Suburban won't disengage 4.wheel drive. The
This is a mechanical technicality that U can't fix at home, you need an expert to reset the system for you
Sep 09, 2013 | Cars & Trucks
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Timer is loose, stopped working; basket filled with water, then stops.
try checking if the tube that drains the water is not clogged with something such as a small sock.
Mar 24, 2013 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
The water wont start filling up - it beeps and then has the code "ddo" on the screen.
Thank you !!
May 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
73 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
