I have an Amana mod# PTC123E35AXXXAB. The fan blower rotates and produces some air but not nearly at full capacity. What would cause this and how do I fix it?
    Genius:
  • 1,033 Answers
Typically a weak capacitor can cause this. The only option is to replace the capacitor.
Posted on Dec 02, 2012
  • 31 Answers
SOURCE: Amana gas fired warm air
either bad run cap on motor or bad blower motor
Posted on Nov 16, 2008
james3751
  • 614 Answers
SOURCE: Amana Air Command 80 blower won't come on
Sounds like fan relay or fan motor possibly capacitor. Call a service tech for free estimate on repair. that wasy you know upfront your cost.Rus
Posted on Jun 25, 2009
  • 34 Answers
SOURCE: blower motor not blowing
you will have to replace the blower motor
Posted on Aug 12, 2009
asood23
  • 200 Answers
SOURCE: Amana air conditioner unit, model ARUF182416AA,
Looks like there is no gas in the compressor. Refill the gas.
Posted on Sep 20, 2009
hvac1960
  • 2133 Answers
SOURCE: Have a Amana Wall Unit
PLEASE CHECK THERMOSTAT SETTING +29 AND ALSO MODE"HEAT". STILL PROBLEM CHECK THE HEATING SENSOR IS NOT OPENED. BY A OHMS METER CHECK THE SENSOR. iF ANY READING IN OHMS IT'S O.KAY.
Posted on Dec 13, 2010
How to test blower interface board 20158901
Please repost under correct category
Have you checked the fan motor is ok?( If the board is producing an output as you say)
Jun 19, 2014 | Refrigerators
Amana AP148D-RB, Air Conditioner Parts
Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
AC-8000-27 Wheel-blower condenser $21.81
AC-8000-26 Wheel-blower evaporator $21.81
I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
Mar 02, 2010 | Heating & Cooling
Hi i just replaced my evap fan in my amana mod bbi20tpsw i have 120 v at the motor leads until i hook up the motor then the voltage drops to 9 v
Replace the defrost thermostat , not the motor . The defrost thermostat ( bimetal ) sends power to the fan motor when bimetal is cold ( 35 degrees maybe ) . When first plugged in , the compressor cools the coils until the bimetal clicks on . Then the fan comes on , blowing cold air into the fridge . If the fan came on when first plugged in , it would blow warm air , gradually getting colder . Amana is the only brand using this process of coolant .
Sep 02, 2009 | Amana Refrigerators
Blower motor not blowing
Aug 11, 2009 | Amana PTH123B35AE Air Conditioner
Out of 48 PTACs why only one is releasing too much water
There may be a breeze or draft near it. The wall or something around it may be damp. Maybe alot of human or animal activity near it. There can be many causes for humidity. Then again, the unit may just run better then the rest and removing more moisture.
Aug 11, 2009 | Amana PTH153B25AJ Heat Pump Air...
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
Jun 25, 2009 | Heating & Cooling
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
