Question about Kodak EASYSHARE M763 Digital Camera
I have dissambled my camera to clean, now cant reassemble
I do not know where to attach the film of the lcd and when reassmbling. also theres is a loose piece of metal which i dont know where to replace
  • 30 Answers
Take to a shop thats your best bet saves you breakin it
Posted on Jan 11, 2009
Does this camera use the 600 film
635 CL Instant Film Camera
Freddie , yes your camera uses 600 film
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Polaroid Supercolor 635CL Instant Film Camera
Polaroid For Dummies
Mar 31, 2016 | Polaroid 635 CL Instant Film Camera
How to fix my 5130c2 that have white display only
make sure if your device working or not? if working that means it has LCD problem then try this : dissambly the device and unplug lcd clean with alcol and plug again this will solve the problem,if problem persist you need to change LCD (see on you tube how to do clean and dissambly) and if it is not working it is a software problem then connect to pc suite and update firmware.or try hard reset press and hold 3+*+green button+power on until show insert sim card.
Jun 28, 2012 | Nokia 5130 Cellular Phone
The film ripped from the cassette on a contax rts when i was manually rewinding it. is there any way to salvage this at home? also, what is the best way to remove the film from the camera, without damaging...
before opening the camera, press the film rewind release button and ensure that the portion of film which remains attached to the cassette has been totally rewound. Next, with the camera in total darkness, open the camera back and remove the film cassette. Grab a firm hold of the loose end of the torn film and tape it to a piece of wooden dowelling and then turn the dowelling so that the film pulls out and winds onto it. Once the film has disengaged from the camera, place the dowelling with the film into a totally light-proof container: an old but spotlessly clean metal tin, such as a custard powder, cornflour or even a paint tin will do the job. Don't use a plastic lidded tin as the lid is always slightly translucent and will fog the film. When the tin lid has been firmly closed with the film inside, you can take the tin to a specialist processor and get both film portions developed.
Note that specialist handling of this type regarding development is not cheap. You cannot use a regular postal processor or minilab as their machinery cannot handle damaged film, only a professional lab (or a well-equipped friend) can individually process your film. Bear the cost in mind, as it's only worth doing if you are sure that there are valuable/irreplaceable images on the film.
Also note that by pressing the rewind button before pulling out the film, you are largely using the camera as intended so will not damage it. Afterwards, check the camera thoroughly and clean out any broken film fragments.Torn film is sometimes down to a manufacturing defect in the film, or due to the rewind button popping out during rewinding, or rewinding much too fast or due to excessive resistance in the take-up mechanism as the film is rewound; the latter usually indicates that the camera is overdue for a professional CLA (Clean, Lubricate, Adjust) service. The fault may commonly be due to a combination of those factors.
Sep 13, 2011 | Contax RTS II 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Hi I have been using my D80 for three years.today I found the green light of the camera blinking.then i removed the lens and attached.after that the problem is fixed.so I want to know what was the...
An invisible film probably formed over the contacts of the camera body and lens where they meet. When you removed/attached the lens, you slightly cleaned that area. You should now clean it properly with a cotton swab lightly dampened with rubbing alcohol.
Oct 10, 2010 | Cameras
Failed to boot, i cant even get to the bios! only the fan running, led(green) and (red) indicator doesn't even light.
Dear Client, unpluged all the data cables, power cables or wires, bios cell and RAMs. Everything should be unpluged from the motherboard for two hours and then reassmbled. It will work properly but when you reassembled it just plug with the follwing devices.
* Power Cables
* Data Cables
* Bios cell
* Processor + Fan
* RAMs
Do not attach CD-Rom or Hard Disk, just turn on the computer without Hard Disk and CD-Rom and try to enter in bios setup. I assure your problem will be solve. Now you can attach the CD-Rom and then try to boot up from the CD-Rom and in the last you should try to attach Hard-Disk. I hope you will do it step by step and get success.
Good Luck
Feb 14, 2010 | Asrock 775i65G Motherboard
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
How do i replace internal battery on the minolta maxxum 7000? i replaced the AAA batteries, but it still just flashes ''film'' in window.I have no manual and dont know how to get the film out.HELP!
Unscrew battery compartment on the right grip, and remove the battery holder (AAA's in most Maxxum 7000's) In the compartment you should see a silver colored metal plate, held on by 6 small phillips screws. Unscrew these, and carefully lift the plate, and move it aside (there's a tiny wire soldered inside the plate, so don't break it off).
Inside there should be a CR2016 lithium button battery. Replace it, and reassemble in reverse order.
NOTE: This probably won't fix any issues regarding the removal of the film, as the 2016 is just a memory backup battery for when the main batteries are removed.
to remove the film, install fresh main batteries, turn on the camera via the "Lock" switch and rewind the film. on the back of the camera, just behind the LCD screen, above the film door, you will see a grey button marked "R". Push and hold it, while sliding the gray slide switch immediately to the left of it to the left. The film should now rewind.
When the film is done rewinding, open the back via the sliding latch on the left side of the body with the gray button in the middle. Push the button, while sliding the latch down.
To insert film, place the cartridge in the same place and orientation as the old roll, and pull the leader over to the red dot on the bottom right of the film compartment, and close the back. it should advance to the first frame if done correctly, or blink 0 if done wrong.
If you need anymore assistance, contact me via email cwrrailfan at yahoo dot com
Have Fun with your 7000!
Mar 11, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Fitting replacement film door release catch
I suggest you bring the camera to the Canon service rep in your area and for a few dollars you let them do it. This way, if there is any damage they are responsible.
I don't know the answer for your particular model, but in many of these cameras it is possible to easily do colaterol damage when changing parts.
Jerry G.
Apr 09, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Instructions
There are two conditions under which a blinking "H" will appear in the
LCD panel: (1) when the film has been loaded incorrectly or (2) when the
camera's self-test process detects an internal malfunction. If a
blinking "H" indication appears, perform the following operations in
attempt to resolve the situation:
1. Rewind and remove the film using the rewind button, then remove the
battery to clear the memory.
2. Clean the contacts at the base of the battery compartment with a
clean pencil eraser to ensure proper contact between the camera and
battery.
3. Replace the battery, power the camera back up1.gif and operate it as if
it had film loaded, pressing the shutter release.
Jan 11, 2008 | Canon Sure Shot 105 Zoom Date 35mm Point...
Kodak EASYSHARE M763 Digital Camera Logo
81 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
