Question about Maytag 30 in. CSG7000 Gas Cooktop
Gas flames are orange. How do we adjust combustion or do we call repairman?
    Sergeant:
  • 475 Answers
Yes you have to call the repair man.
Posted on Mar 11, 2013
How do I adjust the flames
What is the gas pressure into the stove? This is a critical measurement and should be done by the gas company.
Dec 24, 2014 | Premier Range. 36 in. Freestanding Gas...
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Flame size will not regulate. Authorized Jenn-Air repairman came out and replaced the regulator and I still have inconsistent flame size on all four burners. About 1/2 the time it's like it's...
What other appliances work on gas? The furnace? The water heater? A gas dryer? How much propane is in the tank? I wonder how the cooktop would work on a seperate tank? If it worked perfect on another tank I would say you have a plumbing problem.
Oct 26, 2011 | Jenn-Air JGC8536 Gas Cooktop
One of the 4 burners has a LARGE, YELLOW flame (right rear burner). It just started today. Other 3 have a BLUE flame. Using Propane Gas Is this a fuel/air mixture problem, and if so, how do I fix...
The yellow flame suggest incomplete combustion is taking place and on a flueless appliance Otis very dangerous, check for dirt/greese that has accumulated aroroud the gas jets ( this will dercrease air available at the primary airport) if this is clean then your gas jet may be worn and become larger allowing more gas than air as they mix, in this case you will have to replace the gas injectors
Jul 12, 2011 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Flame in cooktop (3rd one) seems to be mostly blue with orange tips appearing here and there, but is agressive and pots almost burn with food not cooked. No way to turn down on a sealed cooktop. Is this...
if your on propane you will get a little bit of a orange tip. need to see if your model has shutter valves. this adjustes the gas air mixture
Jun 22, 2009 | Cooktops
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
Jan 26, 2009 | Amana AKS3040 Gas Cooktop
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Maytag 30 in. CSG7000 Gas Cooktop Logo
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
