Question about HP 285527-001 - Compaq Presario 900&Presario 1500 Series 8X Laptop DVD Drive (285527001DVDROM) CD-ROM Drive
Compaq laptop pp2140 missing vgaeon.fon
Please could anybody help with this, i had the message vgaoen file missing or corrupt, now it dosent even show this , after trying to boot it numerous times.its such a nightmare trying to get the thing on at times
  • 538 Answers
Try to press F8 on boot and "Safe mode" boot
Posted on Mar 19, 2009
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
My laptop came up with a message that says files missing or corrupt. Use start up disk. I need to get a copy of the start up disk. Can you help.
I'm thinking that the message is that the "system" file is missing.
Go to this link and you'll be able to fix it if the problem is a corrupt registry hive.
http://support.microsoft.com/kb/307545
Oct 30, 2009 | HP Compaq nc6220 Notebook
Vgaoem.fon
Hello there:
your problem is due to a missing or corrupt file this file is a key file that windows needs to operate.
please try this
Root of the issue
You might come across this error message and this behavior of Windows operating system due to missing or damaged Vgaoem.fon file. This is a key file for Windows operating system, which is required for Windows to boot up.
How to recover inaccessible or lost partitions
Follow the underwritten steps to sort out the issue:
  • Configure your PC to start from CD/DVD
  • Insert XP bootable CD and restart the system
  • Boot the system from CD and press R to start system in Recovery Console
  • At command prompt, type map and press enter
  • Type underwritten line and hit enter: expand CD-ROM drive:\i386\vgaoem.fo_ drive: \windows\system here CD-ROM drive is the drive latter of your CD Drive.
  • Type exit and restart the system.
If your system works properly, then the problem is resolved. In the else case use Partition Recovery Software to recover lost hard drive partitions and data. These tools are particularly designed to effectively scan the affected hard drive and retrieve all of the lost, missing and inaccessible hard drive partitions. These applications are quite easy and safe to use. i hope that this helps
best regards mike
Jul 22, 2009 | Compaq Presario 5000 PC Desktop
Sir i am a dealing in notebook. i purchased a compaq presario cq60 104tu .. and also license win xp sp3 . but when i started a boot from that cd ... it dosent work and it showing a blue screen... ( press...
your in windows xp and youre try to install sp3 from a disk i take it.
either the disk is corrupt,missing files or wrong version .causing blue screen.(fatal exception)
you could try leaving the disk in and reboot ...
when in windows select run D: or what ever letter is assigned to cd drive .( start , run , type in d: and enter)
this will show files on cd/dvd. drag and drop the .exe program into a file or on desktop and try to run.if it runs the cd/dvd is the prob (corrupt,virus,missing files.) if it does run its the software incompatable or faulty(incomplete files or wrong version)
either way the cd will be useless.
you can download sp3 (free)as long as you are using a registered os.
Jan 30, 2009 | Lenovo 3000 Y410 (59012354) PC Notebook
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Oct 12, 2008 | Compaq Presario 1700 Notebook
Windows could not start because the following file is corrupt or missing
Boot with a windows cd and do a repair install. It will reinstall all windows files. Please note, even though it should leave your data in tact, I would make sure you have a backup before doing so. After hitting F8 to agree to the terms and conditions on the windows CD, use R to do a repair install.
Jun 15, 2008 | Computers & Internet
Boot up issues
run cmos bios and configured boot device..first boot cd rom drive..
then reinstall/repair your os...
Mar 24, 2008 | IBM ThinkPad T21 Notebook
Windows xp missing file and won't start up
Here's what I would do, because after reading around on that error message, it seems like you can't repair the problem.
I would find myself one of these: http://www.casecooler.com/3drto2dr.html
Take out your laptop's HD, hook it up to that convertor, slave it to a desktop, pull all your data that you don't want to lose to the desktop, put the laptop's HD back into the laptop, reformat/reinstall windows back onto the laptop, pull the HD back out of the laptop, hook it back up to that convertor, slave it back to the desktop, put your data back onto the laptop's HD, then put it back in the laptop.
That will leave you with a clean install that works on the laptop and you won't lose any data.
Nov 12, 2007 | Compaq Presario V4000 Notebook
HP 285527-001 - Compaq Presario 900&Presario 1500 Series 8X Laptop DVD Drive (285527001DVDROM) CD-ROM Drive Logo
342 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
