Question about Lexmark Office Equipment & Supplies
I HAVE AN ALLIN ONE (printer copy scan. However, this is the ist time that I'm using the scan feature. I keep getting File lxbmsccp.hlp cannot be found. I have reinstalled the CD several times
  • 154 Answers
Go to the link below to find the missing file and download it.
http://driveragent.com/archive/3964/?PHPSESSID=4fp22l9o8qdba8o4l8h6nku9n0
Posted on Jan 11, 2009
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
Jun 19, 2012 | HP J4680 Office Jet All-In-One Printer
I got a new dell computer. my hp 5610v allin one printer will not scan, never had any problem before, it wont let me set it up with disc. what do i do????? it copies an prints great. thanks helen
It seems the driver version that you are using is not a full feature software.
Please download the full feature driver and than you should be able to scan.
Thanks
Sep 21, 2010 | HP Officejet 5610 All-In-One InkJet...
My HP6110xi All-In-One doesn't want to scan
First, scans and copies don't really use the computer. Can you print a document from your printer. If not, then your problem is within the computer.
If it does print then....
Try using the scan feature within the HP solution center. It works on mine but the scan button on the printer does. Also some art programs have and "ACQUIRE" feature under file to scan with. (Sometimes called TWAIN.)
Hope this helps, so you can start scanning.
good luck
Feb 21, 2010 | HP OfficeJet 6110xi All-In-One Thermal...
My printer is HP PSC 2310. While installing my
Before uninstalling or downloading a bunch of unnecessary files, try looking for the file in your computer by using the search engine in windows (press start -> search -> type hpfmom10.hlp -> press enter). Then once the file is found, copy it's address to the field where the installation think the file is located. Way easier and less time-consuming than other solutions.
Jul 16, 2009 | Office Equipment & Supplies
How to scan
first stall softwere. then u can scan both methote,keep paper and directly push scan button.2/ go start -program and seclect btother then inside u can get scan tool.
Jun 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
My Canon MX310 will not scan pictures -
it sounds like a file is corrupt,if you have a driver disk,delete everything and redownload it.a file might not have copie right the first time.
Jun 09, 2009 | Canon MX310 Office All-In-One Printer
When we select Scan to File and choose pdf file format, what we get is a file with a pdf extension, however, it is not a true pdf file. We cannot use Adobe Reader search feature. It seems more like a...
Correct! Its a PDF but its just a picture of the characters you will have to OCR it to use the search feature. Good Luck  E-Copy is a good program for doing this or Laserfish
Apr 30, 2009 | Toshiba Office Equipment & Supplies
I need driver for HP PSC 1300 series
Click on the below link and enter the product type and download the drivers which is compatible wiht your Operating system.
http://welcome.hp.com/country/us/en/support.html
Thank you.
Sep 12, 2008 | HP PSC 1350 All-In-One Thermal Printer
Lexmark X7350 Scan feature
well you are able to scan multiple documents.. but the file size is more.. the way lexmark software writes the pdf file.. the file will be huge for PDF... but not sure if this is a case with any other all in one manufacturer like HP also... but i would assume it would be the same.. so scan the file to MS WORD or any other application that supports multiple pages... so u have it as one file... but if u want only pdf files, then u have to do a little work around like writing the MS WORD Document to pdf format. If the PDF Writer is not installed with your copy of MSWORD then try any free pdf writer software available on the internet.
Aug 31, 2007 | Lexmark X7350 All-In-One InkJet Printer
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
