Question about Dyson Ball DC24 Bagless Upright Vacuum
Dyson dc24 brushes do not work even when i depress the silver button
My dyson d24 brushes do not rotate even when I depress the silver button. Why would this happen
  • Alison Lacey Dec 10, 2012
    Hi Jack, the advice you gave me bout my DC24 brushes not working was excellant. Its in full working order thanks to you. Brilliant!!!!!! Thank you so much. Alison Lacey.
  • Official Brand Answer
  • 2,572 Answers
Hi there Alison, it's Jack at Dyson.
DC24 is equipped with a safety device which shuts off the brush bar if something jams it - for example, a shoelace or a rug fringe. From what you've described, it sounds like your machine may just need resetting. This is simple to do if you follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/stabiliser-check
You may also find the video below useful. Make sure that before you test the machine, you've reclined it into the vacuuming position, because the brush bar will never rotate when the machine is standing upright.
I'm confident this will resolve the issue, but if you'd like any further assistance, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Posted on Dec 06, 2012
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Posted on Jan 24, 2009
SOURCE: kickstand on dyson dc24 will not stand up
Solution to Dyson Ball wil Not stand up / Kickstand will not go down:
I had this problem on my Ball. The metal guides on the red foot lever had jumped out of their tracks and you have to get them back into the guide tracks on the rear wheel assemblies. I pulled on the affected wheel assembly to get the metal post on the red kickstand to reset it where it should be.
Posted on Mar 11, 2010
ukvacfan
  • 328 Answers
SOURCE: Dyson 18 slim the rotating brush bar will not
If the DC18 has a proteted belt then it will have to be replaced by a Dyson engineer or repairer. If the cleaner has a removable sole plate where the beater bar is then remove it and replace the belt - sounds like the belt has snapped and needs to be replaced. if your DC18 is still relatively new it should still be under guarantee.
Posted on Mar 27, 2009
Dysonteam
  • 167 Answers
SOURCE: I have the Dyson Ball DC24. I can't get the roller
Hi its Darran at Dyson.
The brush bar re-set switch would normally resolve this, however as you have tried that, please get in touch with our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US) so that we can help resolve this issue for you.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 16, 2010
Dysonteam
  • 167 Answers
SOURCE: dyson ball dc24 the brush bar is not turning
With the machine switched off, press the re-set switch on the side of the head, making sure you push the button in as far as you can. When you switch the machine back on and lower it into the vacuuming position, the brush bar should start turning.
If this doesn't rsolve the problem, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Posted on Apr 20, 2010
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    How do I fix the brush bar reset button on Dyson DC24?
    Hi there, it's Jack at Dyson.
    The reset button will not remain depressed after it's been pushed. Instead, you should hear and feel a click when pressed - it can help to use something like the eraser-end of a pencil. The steps are shown in our video guide below:
    If you've been unable to reset the cleaner head after pressing the reset button as shown, or if you're worried the reset button isn't working correctly, please get in touch as we should be able to help you further.
    You can reach the Dyson Customer Helpline directly by calling us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Please have your DC24 to hand when you call so we can take you through some troubleshooting checks.
    Aug 15, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
    The brush is not rotating. The grey button that is supposed to initiate some safety mechanism does nothing.
    Hi Jane, it's Jack at Dyson.
    DC24 includes a belt engineered to last the lifetime of the machine in normal use. It's protected by a sensor which shuts off the brush bar for protection if something jams it in use. Usually, following each of the steps shown in our video guide will allow you to reset your machine:
    Press the red reset button on the cleaner head firmly with something like the eraser-end of a pencil - you should hear and feel a click. The brush bar will never rotate when the machine is standing upright, so recline it into the normal vacuuming position before testing it.
    Please note, the silver-coloured switch next to the red/on off switch should allow you to shut off the brush bar when cleaning hard floors or delicate rugs.
    If you haven't had any success following these steps, our experts are on hand to provide further assistance. If a repair or a replacement part is needed, they can also confirm if this is covered under your Dyson warranty. When your have your DC24 to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    May 20, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
    Dyson DC 24 brushbar motor stops working , every so often , I press the reset button then it works for a while and stops again till I press reset again.
    DC24 is equipped with a safety device which shuts off the brush bar if something jams it - for example, a shoelace or a rug fringe. From what you've described, it sounds like there may be something in the cleaner head which is jamming the brush bar. It's also important to remove any threads or hair from around the brush bar regularly. Please follow the steps shown in our online Support guide:
    Best wishes,
    Jack
    Nov 25, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    New Dyson DC24 ball vac 2nd time using brush stopped rotating when caught on short rug fringe/ no mat`l caught
    Your DC24 is equipped with a sensor which shuts off the brush bar if something jams it. You can reset the machine by following the steps shown in the video below. You may also want to refer to our online Support guide:
    Please note, the brush bar will never rotate when the machine is standing upright, so make sure you recline your DC24 into the vacuuming position before testing it.
    If you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Apr 30, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    Brushes do not go round on DC24
    I'm sorry to hear you're having difficulties with your DC24. Your cleaner is equipped with a safety device which shuts off the brushbar if it gets tangled with a rug fringe, shoelace etc. After making sure the brushbar is free of threads, hair or other obstructions, you'll be able to reset the cleaner and get the brushbar running again. The easiest way to do this is to follow the steps shown in our online support guide:
    http://www.dyson.co.uk/support/help.asp?article=1502&product=DC24-ALLFLOORS
    Use something like the eraser-end of a pencil to depress the reset button, and make sure you push it in firmly until you hear an audible 'click'.
    Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've turned it off using the silver brush control switch located next to the red on/off switch.
    By following these steps, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you, and will be able to recommend the best course of action.
    Kind regards,
    Jack
    Sep 14, 2011 | Dyson Vacuums
    Brushh will not rotate
    By following these steps, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action.
    Kind regards,
    Jack
    Sep 11, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    The brush head won't move round
    Sorry to hear you're having difficulties with your DC24. Your cleaner is equipped with a safety device which shuts off the brushbar if it gets tangled with a rug fringe, shoelace etc. After making sure the brushbar is free of threads, hair or other obstructions, you'll be able to reset the cleaner and get the brushbar running again. The easiest way to do this is to follow the steps shown in our online support guide:
    Kind regards,
    Jack
    Aug 28, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    Does the dc24 have a belt
    Yes it has belt. The dc25 vacuum is same as dc24 vacuum.------------ Click this link below for more details:--- http://howtobyme.blogspot.com/2011/08/belt-on-dyson-dc25-and-dc24-vacuum.html ---------- This will help.Thanks.Helpmech.
    Aug 19, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    Brush drive unit not turning, button on side has been depressed as reset, button on handle has power to it and drive appears to have suitable tension which would suggest drive belt has not snapped.
    Sorry to hear you're having difficulties with your DC24. Although you've already tried pressing the reset button, you might find it helps to use something like the blunt end of a pen or pencil to do this, and make sure you push it in firmly until you hear an audible 'click'.
    Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if you've turned it off using the silver switch next to the red on/off switch.
    Hopefully this should resolve your issue. However, if you're still having difficulties, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and provide the assistance you need.
    Kind regards
    Jack
    Aug 11, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    3,350 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
