Question about Electric Cycling
Rear tire change aowa electric bike - Electric Cycling
  • Trinidad Armenta
    Trinidad Armenta Dec 26, 2012
    Wow great detail and super helpful, now I am willing to try to tackle the job. It seemed overwhelming without all these step by step instructions! Thanks will post mt results soon! Bike monkey
How to change the rear inner tube on a 2010 48 volt Aowa Hybike e-bike
Changing the rear tire and/or tube is a real hassle. If I ever have to do it again, it will be much easier having done it once. I hope you find this step-by-step helpful and I trust it will save you time and profanities.
There is a lack of technical information on these awesome electric bicycles. I bought mine used off of craigslist in September 2010 and after 2 years of nearly flawless, nearly daily operation, the rear tire developed a slow leak. I had neglected to properly maintain tire pressure at 40 psi (as indicated by the tire sidewall markings) and this most likely caused the failure of the tube (I couldn't find any nails, thorns, etc. that might have caused the leak). I kept riding the bike for weeks in this state and would just add air willy-nilly. The tube began to slip on the wheel so my air stem was getting really crooked, which puts undue strain on the valve stem. One night I was riding the bike to my girlfriend's house and the back tire went totally flat. Because it was late and I was cold and only halfway to her house, I decided to ride on the flat (which is never a good idea; I'm lucky I didn't damage the rear wheel).
Before you begin, find the right size inner tube. 22 x 1.75 is what I used but it says 22 x 2.125 on the sidewall. I got 2 from Phoenix Produce Company, the Chinese market that imports these bikes in AZ. I bought 2 heavy-duty tubes for $24. Pricy but worth the extra durability.
Step 1: One of the great features of these bikes is the locking center stand. It helps deter theft and makes the bike very stable for maintenance or parking. However, the center stand is attached to the rear axle and therefore is useless (and an additional obstacle) when changing the rear tube. I ended up using a cinder block under the center of the bike as a stand. However, the bottom of the ebike is not level and therefore will rock side-to-side, teetering on the central rail of the frame. I wedged two chairs under the hand grips (one chair on each side), which prevented the bike from falling but it was still not stable. I'd recommend either shimming the sides of the lower frame rails and/or using tie-down straps on either side of the bike for stability.
Step 2: Remove the orange "foot peg covers" from the rear axle. There are two Phillips head screws on the top and on on the lower side of each.
Step 3: Remove the vertical supports of the rear luggage rack using a 10mm socket or wrench. It's always good practice to replace the bolts in their holes so you don't lose them.
Step 4: Remove the bolt on the left side (left as in you're sitting on the bike) that secures the rear hub to the lower frame (in front of the brake). Remove the rear brake cable from the brake lever on the rear wheel hub. I failed to do this the first time and couldn't figure out why the wheel wouldn't come off!
Step 5: Look at the axle and note the order of parts on either side. Because the wire to the rear hub electric motor runs through the axle from the left side, you will not be able to completely remove all the hardware from the left side of the axle unless you disconnect the wires. I kept the wires attached and by doing so was able to re-create the order of things on the right side so I recommend you do not detach the wiring. However, enure you do not place stress on the wire (it's protected somewhat by a spring.
Step 6: Loosen the axle nuts. I used a big crescent wrench. Remove the "foot pegs" (they look like angle brackets), the washer, the center stand mount, the locking tab washers, the axle adjusters, and whatever else you find in there.
Step 7: Remove the rear drive chain from the right side by either removing the master link or (what I did), slide the axle forward enough to get the chain off the sprockets.
Step 8: Pull the rear wheel rearward to remove it from the frame. This is very awkward as you'll be contending with the center stand and rear fender and rear hub motor wire. I used a few screwdrivers to pry the axle back. This step (and the next few) were extra-messy in my case as there was green tire "Slime" everywhere.
Step 9: Wash your hands. Have a beer or a smoke.
Step 10: Mark the sidewall of the tire below the valve stem (I used white-out). Using non-serrated butter knives (or actual bicycle tire spoons), force the bead of the right side of the tire off the wheel rim. Pull the tube out and finagle it over the right side of the axle. While it is not necessary to completely remove the tire to change the tube, you should take the extra minute to inspect the tire for any burrs, thorns, etc so you don't have to do this horrible procedure again any time soon.
Step 11: Inspect the rim strip to make sure the spokes aren't poking through.
Step 12: Inspect the tube to see where it failed. If it's not obvious, you can inflate the tube and either submerge it in a shallow pan of water or spray soapy water on the tube and look for bubbles. Using the whiteout mark you made on the tire in Step 10 and the valve stem as a reference, carefully inspect the tire at that corresponding location to see if you can "pinpoint" the cause of the flat. I love puns. Also inspect the wheel rim at the corresponding point for nicks, burrs, or damage.
Step 13: Clean the tire and wheel. Using your knives (or tire spoons), force the bead of one side of the tire onto the wheel (I didn't replace my tire because it still had lots of tread). Partially inflate the new tube just to give it a bit of shape. This makes it easier to position and reduces the changes of pinching the tube with your spoons or the tire bead. Be sure the valve stem is completely perpendicular to its hole in the wheel or you risk tearing off the valve stem.
Step 14: Once the tube is positioned properly, force the other side of the tire back onto the wheel rim. Take you time lest you damage the tube. I had to repeat this step 2-3 times to ensure the valve stem was completely straight. Don't rush this step.
Step 15: Loosen the axle adjuster nuts using a 10 mm wrench. I turned them 5-7 turns. Do this so you can adjust the chain and rear brake in the next step. Position all the hardware on the left and right sides of the axle properly and don't forget to put the chain over the axle if you didn't remove its master link. I forgot to do this and, not realizing there was a master link, had to repeat this entire step. Avoid my mistake! When I say "position the hardware" I mean the axle adjusters and washers need to be "inside" the frame and everything else (center stand mount, foot pegs, axle nuts, etc.) needs to be "outside" the frame. This is a real pain so you might want a friend to help. I did it by myself but it took several attempts. Because the rear axle is oval-shaped, it will only slide into the frame if perfectly aligned. I used an adjustable wrench to turn the axle while holding the wheel off the ground while trying to keep the "inside" and "outside" hardware aligned. This is a juggling act that might require cussing and death metal listening.
Step 16: Slide the axle all the way forward and place the chain over both sprockets. Adjust the chain using the axle adjusters and ensure both are adjusted the same to avoid misaligning the rear wheel.
Step 17: Tighten the axle nuts. Ensure the locking tab washers and center stand supports are in their respective slots on the frame as you tighten the nuts.
Step 18: Reconnect the hub-to-frame bolt and rear brake cable.
Step 19: Test the throttle and make sure the rear motor spins freely. Test the chain as well by turning the pedals.
Step 19: Adjust the rear brake by turning the rounded barrel nut against the cable end.
Step 20: Inflate the rear tire to 40 psi. I added 8 ounces of Slime to the tire before doing so.
Step 21: Pray you didn't mess up anything and go for a test ride!
Posted on Dec 26, 2012
2 Suggested Answers
  • 71 Answers
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Posted on Jun 09, 2009
Aowa electric bicycle wiring
Request a wiring diagram from Aowa.
Oct 19, 2017 | Electric Cycling
Replace rear tire
Hi James
Yes you can replace the rear tire, just follow the steps in the bike owners manual or buy a service manual. After the tire is off if you are not comfortable removing and replacing the tire from the rim you can take it to a bike shop and they will change it for you. I hope this helps. Rod
Jul 25, 2015 | Motorcycles
I have a aowa electric bike 48v 500w. the batteries are split into 4 12v 12ah. can i use a lower, lets say 12v 10ah battery or lets say 4 12v 9ah batteries?
yes, the ah has to do with the capacity of the batteries, so the lower the ah the shorter the runtime, and if you have 3 10ah and 1 6ah the capacity of the 10ah batteries will be downgraded to 6ah
Sep 26, 2014 | Peg Perego 12 Volt Rechargeable Battery
How to change rear tire schwinn suburban womens bike
Remove wheel, take it to the nearest bike shop for correct replacement and tire sizing. Schwinn tires are different than other tires. They use fractions rather than the decimal system everybody else uses. So a Schwinn tire won't fit on a decimal rim and a decimal tire won't fit on a Schwinn rim
Jun 01, 2014 | Schwinn Cycling
Electric bicycle
Contact the seller for a manual http://www.omegastores.com/cozybikele.htm
First remove the battery then find someway to support the bike as removing the rear wheel also removes the stand...
Remove the 2 Philips head screws securing the rear mudguard and the 2 on the LHS rear axle cable protection cover & slide the cover off. Disconnect the rear brake. undo the rear axle nuts. Loosen the chain adjusters and slip the chain off. You may also have to deflate the tyre to get it past the mudguard.
Mar 23, 2014 | Electric Bicycle Motor, Bike,electric...
How to change rear tire on a 26in huffy bike
Dismount back wheel, empty all air from tire, then use the disassemblers to get tire off.
Mount new tire -I will advice to use something like "Slime" to seal tire chamber...
Mount wheel again, and inflate.
You should be on track again
Good luck
PS: You could also see this: Changing a Road Bike Tire
http://www.youtube.com/watch?v=i5K-DXt9djA
Apr 14, 2011 | Cycling
How do i change rear tire
jack the bike up with a bike stand loosen the wheel, (im guessing your bike is belt drive)push the wheel forward so the belt is loose take the belt off the rear wheel, take the spindle out and your wheel will come off, deflate the tire and use tire levers to get it off, or take it to a garage and have them do it
Jun 12, 2009 | 2006 Yamaha V Star 1100 Classic
How do you get the tire of the rear rim of the razor mx500 electric dirt bike???
Jun 09, 2009 | Razor MX500 Dirt Rocket
WHAT KIND OF TIRE FRONT AND REAR
I have a roadliner and have the same problem,they only offer two differant bad tires for our bikes,the dunlop and the bridgestone,you could bump up to a 200/55/17 it will fit and wont change the geometry of the bike.I have been waiting for avon to make tires to fit the bike.I havent heard of the conversion to an 18in tire,will have to look into this.
Mar 31, 2009 | 2006 Yamaha Stratoliner S
Cycling Logo
570 people viewed this question
Top Electric Cycling Experts
Colin Stickland
Colin Stickland
Michial Gueffroy
Are you an Electric Cycling Expert? Answer questions, earn points and help others
