Question about Adobe Acrobat 7.0 for PC
Ok I've got a sony vaio laptop on vista, I've got the ethernet cable from my modem going into the wirless router (which is plexus a adsl2 + gateway) now i'm able to connect to the router ok, but if you hover over the status it says local only and im unable to access anything on internet. I've followed the guidelines on the cd that came with it and connected to router, and done everything it says to configure it but same problem. It comes up with the error message "windows tried a repair but the problem still exists, security policy settings on this computer might be blocking the connection, the following policy might need to be adjusted to allow windows to connect, policy provider: windows firewall, filter name:query user I've gone on several sites and have tried ipconfig /release ipconfig /renew tried turning off firewall and all anti-virus protection tried resetting tcp/ip to manufacturers settings i've also gone into windows firewall with advanced security on local computer via admin tools in control panel and domain/private/public profile are all set to windows firewall is on then inbound connections that do not match a rule are blocked, then outbound connections that do not match a rule are allowed any further sugguestions, i am an IT, but i have very little experience with vista so I am baffled....
  • 366 Answers
Connecting to Router open diagnostic page and check your Wan connection.
If you do not find it use from same router the ping or trace command to check your Internet connection.
If you cannot get a result check Wan configuration: (PPOE/A Bridge etc) with your ISP (call or read user manual)
if your router is on net but you cannot browswe vrom vaio check if router access list is set: disable it or add your PC MAC address.
Posted on Jan 11, 2009
Unable to connect to internet despite connection confirmed
Improve the FixYa experience for everyone by voting.
I'm going to provide you with some generic approaches in an attempt to solve your problem.
First: Microsoft will perform a complete systems check for you in three clicks with their FixIt app. CLICK HERE and Microsoft will fix (repair) any Windows related problems that might be causing your problem.
Second: It is important to connect the modem to the router before you configure the modem in order to verify communication between them. If the cabling is incorrect, the rest of the process fails.
As a rule, external modems are built with a female data communications equipment (DCE) DB-25 port for connection to a controlling device such as a PC or a router
Connecting the modem using the network cable to the wrong port of the router (other than the WAN port) is easy to identify. You can easily troubleshoot the problem. In some cases, you may correctly setup the wireless router connection but you use the wrong cable type in connecting the modem to the router. Cross type UTP cable must be used in connecting the Ethernet port of the modem to the WAN port of the router. But this is not always true. Today, many types of wireless routers (and any LAN Switches) embedded their Ethernet ports (either WAN or LAN ports) with Auto-sensing type port (auto-MDIX LAN). It means that you can use either cross-type or straight-through-type network cable for the Ethernet port connections. The system will detect the cable type and automatically adjust the ports signal accordingly.
Apr 28, 2012 | Sony Vaio VGN CR353 Laptop Universal AC...
Can't install router
Ensure the cable is plugged on one of the ports 1..4, try a replacement cable.
Aug 31, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
My ADSL 2+ works fine with wireless, but not with a local area connection. My PC uses this. I,ve switched cables, tried a cable with the laptop, and reset the router. No change. Any ideas? Steve
If the wireless connection is working fine it show that your internet security is fine and you can access net without problem
there could be a connection issues a within the cables
1) Connect the Ethernet cable to the Laptop and connect the other end to router E1.
2) Open the command windows (DOS ) by typing cmd or command on the Run option ..
START- RUN- type command then hit Enter
3) In the black command windows - Type IPCONFIG
c:\> IPCONFIG hit enter
it will provide with the correct IP ADDRESS and Gate Way Address
Check the gateway address - shout strat with 192.168.X.X
If it is not there is some problem -
4) Check the Device manager and check the Ethernet Adapter whether the adapter is enabled or Disables or Drivers are installed or not
Aug 10, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
CG814WGv4 cable modem from Optus Australia, all 4 ethernet ports not wokring since thunderstorm in January 2009, can ethernet ports be checked if they are still ok, can it be fixed by SW reload, purch
hi i had the same problem with an optus modem thunderstorm ruined my ethernet port. i had to replace the modem from optus and all it cost me was $40(put on my next bill) cheaper then buying another modem. i was told i couldnt buy a modem from another source because apparently they have unique codes on them...hmmm don't know about that, but thats what i was told.
hope this helps :)
May 10, 2009 | NetGear CG814M Wireless Cable Modem...
Wlan lights off and now wirless access
Does your computer say Network cable unplugged?
If the wlan light is off, it means that your computer is not being detected by your router. You can try unplugging and replugging the ethernet cable at the back of the computer. Make sure that you hear a 'click' when you plug it back in to make sure tha it is properly seated. Check also the light on the wan port (desktops usually have lights..not sure about laptops though).
Do the same process with the ethernet cable but now from the other end--the one connected to the modem/router. if your modem/router have other ports on it, try to connect it to other ports as well. If you're wan light is still off, try using a different ethernet cable.
what's wrong with your wireless access? i can't read it from the title.
May 04, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Connection using DSL-2640T
Try diagnose and repaire the connection if that does not work Reset your modem it should go back to default manufacture setup.Then turn modem off and connect any computer or laptop to the modem with ethernet wire turn the modem on go back to your computer that you are connected to modem with wire go to network connections and disable the wireless Network connection and enable local area connection once you see you have connected and have internet working go to start menu you can do this on the start search bar with vista or run with any other windows version type cmd and press enter, it should bring a DOS command menu and then type in ipconfig and enter scroll up and down to where you see default gateway type that ip address to your internet browser it should take you to login screen username should be administrator password admin setup your WEB key make the wireless access available DO NOT FORGET to write the web key down, give a name to the connection and change the default password from admin to something you can remember. save the settings and turn that off keep the laptop on. Then unplug the ethernet cable and switch the network connectiion again enable wireless disable local area also you need to scan the available wireless internet and pick the one you just named use the webkey to access and save when the connection in made.
Feb 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Unable to connect to internet on vista via wireless router
Jan 11, 2009 | Microsoft Windows Vista Ultimate Edition
Welcome to FixYa! Vista is not access friendly but you will able to see your connection status by clicking on the network connection icon on the taskbar where you will see "Connected to: " and if you click on that a network map will appear. You will see a red "X" between your wireless access point icon and your Internet icon if the access status is "Local only". Clicking on the Internet icon will retry that connection. Make sure that your ip address is not as that is Windows little way of saying it can't connect.
If you choose the Diagnose option it will do a release/renew operation automatically. With Vista you must "elevate" access by right clicking on the Command prompt executable and choose "Run as administator" if you wish to do that ipconfig manually.
Also when you are in the firewall configuration select the wireless connection>settings and make sure all of the permissions boxes are checked (ICMP, etc.)
With the adaptor advanced settings make sure your adaptor has the wireless mode (a, b, g, n) at the correct mode.
Have you tried logging on to the router via the Run bar? That is the most informative way to see your router config. Please repost if you need help with that. I also am a network professional certified since 1978 so I know that Vista defies using many tools we took for granted for so many years and often makes me feel frustrated. Maybe Windows 7 will be better as I only run Vista to help others like yourself, though at least you can understand what I am talking about:) Good luck, Steve Medley
Jan 11, 2009 | Adobe Acrobat 7.0 for PC
LinkSYS ADSL2 -AG241Modem + Router Ethernet
First : check your cables if its plugged in securely on each each
Second: Try to change their ends
Third : Try to replace your Ethernet cable.
If your router is connected to a modem try to isolate the problem by connecting your router directly to your computer and check f light would turn on. IF YES then thers something wrong with your modem, check it out.
Hope those simple steps ive provided helped you in way, If not pls let me know and lets keep the ball rolling.
Jun 19, 2008 | Linksys ADSL Modem + Router With 4-Port...
Adobe Acrobat 7.0 for PC Logo
108 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
