Question about NA Zilla 11893 24/7 Digital Timer Power Center, 1875-Watt
I have lost my manual (probably inadvertantly through it out) for a digital relocatable power tap E192912 PS805 w/o a name but it looks like a Zilla 11893 24/7 digital timer power center. Can you help?
Ohhh those are easy... if you respond I will walk you through it. and they are all basically the same. i have 3 or 4 different brands and re program them each season , such as DLS
Dec 04, 2013 | NA Zilla 11893 24/7 Digital Timer Power...
Having problems programing the mode
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Add a comment and describe problem in more detail since Fixya truncates questions and we cannot see full question sometimes
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 07, 2013 | RTO Zilla 24/7 Digital Timer Power Center
How do I set the timer for a GE relocatable power tap EMP700UL-PC?
1) Copy following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Timer turns ON automatically at dusk.
Push button to select duration of ON time.
d is probably dawn, so dawn-dusk
Maybe A is always ON, and maybe F always OFF.
1-9 will be number of hours timer remains ON, for example ON at dusk and OFF 9 hours later.
Dec 02, 2012 | GE Home
How do I set timer for relocatable power tap 6099
You have a power strip timer with either digital or analog timer.
Copy following link to identify common power strip timers, and download manual, or instructions..
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
http://waterheatertimer.org/How-to-set-timers.html
If this is not your timer, then add a comment and describe timer in detail.
Nov 25, 2012 | Hardware & Accessories
I have the timer set, all 7 cycles to come on at 6am go off at 6pm. set and checked. put mode on auto but light did not come on. it only came on when set on the on mode. please help, thank you
You are having problem programming zilla digital power strip timer.
Either timer is defective, or programming has conflicts that cause timer to ignore programming, or blue-yellow outlets are not understood, or combination of these problems.
Zilla yellow outlets are for daytime hours.
Blue outlets for nighttime.
The instruction manual does NOT specify what hours are for daytime. 6 am to 6 pm? Or 12 am to 12pm?
The zilla analog timer divides day and night at 12 and 12.
If digital timer is also 12 and 12, then you cannot set ON at 5:59am and OFF at 5:59pm without fudging the current time setting. For example offset current time by exactly 6 hours.
Add a comment for more free help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 10, 2011 | RTO Zilla 24/7 Digital Timer Power Center
Woods timer model E192912
I do not recognize E192912 number
You posted under photo that shows Woods 59377, which is also sometimes Utilitec 155671or 95363 or TE06WHBL or Woods 49377 or TD2200.
Woods timers have different model numbers for same timer depending on who packaged and sold timer.
Look through page below that shows photos of Woods timers plus manuals, and then add a comment
Dec 05, 2010 | Woods Industries 59377 Indoor Digital...
How to set timer for aqualight digital power center.. it has 7 time cycles per day but do i need to set all 7 cycle and if now i do i set it..
With digital Zilla timer, you can set from 1 to 7 programs.
You can set one program, and that's it, or set 2 programs or 3.
Up to 7.
Open following link to identify timer and download manual.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
Feb 22, 2010 | Coralife Zilla Aqualight Power Center
NA Zilla 11893 24/7 Digital Timer Power Center, 1875-Watt Logo
2,135 people viewed this question
Top NA Reptile Experts
windryder
Level 1 Expert
john h
Are you a NA Reptile Expert? Answer questions, earn points and help others
