Question about Panasonic " 55"" Class / LED / 1080p / 120Hz / 3D / HDTV TC-L55ET5"
501 NOT IMPLEMENTED ERROR MESSAGE WHEN TRYING TO CONNECT VIERA TOOLS VIA THE INTERNET
I have checked all of the connections from the phone line socket to my router ( new sky HUB ).
Junoon007
  • 1011 Answers
SOURCE: Hi. I have a Panasonic
sir,
something magnetic near the tv. move it and the line will go away. either that or heat damage...if its near a window or open fire place.
thanks
Posted on Aug 30, 2008
SOURCE: Connection problems with Panasonic Viera Cast
I have had the same problem with my Panny DMR-BS850 which was resolved by changing the ethernet cable I was using which had only 4 contacts on each plug end for one which has 8 contacts. I tried all variations & combinations of IP & DNS before buying the new cable from my local pc store (£10 for 10m cable) and was relieved when setting the system to auto connect it worked within 3 mins. I think the slight delay was the router setting up a new address for the new hardware it detected.
My new cable states on it "Verified For Gigabit Ethernet" and is Cat 5e rated and I was assured that it will carry data for runs up to 95m long, which is contrary to the Panasonic support agent who told me to shorten my initial 5m cable to prevent signal degradation.
Give it a try.. it might just work.
Posted on Jul 21, 2009
  • 50 Answers
SOURCE: Cannot connect to the internet via Lynksis router
enter the MAC address from the blu-ray player (should be in the main menu under connections) to your router in the wireless settings
Posted on Oct 11, 2009
  • 126 Answers
SOURCE: How do I set up
Cliff, it al depends on what kind of DIRECT TV receiver you have, if it has an HDMI port on the back of the receiver then all you have to do is plug it in and change the input on your TV to HDMI
Enjoy thats a great TV
Posted on Dec 03, 2010
SOURCE: Panasonic Viera Link stop working
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Posted on Jan 25, 2011
Tip
Common FTP Error Codes
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy - mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
120 Service ready in nnn minutes.
125 Data connection already open; transfer starting.
150 File status okay; bout to open data connection.
200 Command okay.
202 Command not implemented, superfluous at this site.
211 System status, or system help reply.
212 File status.
213 File status.
214 Help message. On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. where NAME is an official system name from the list in the Assigned Numbers document.
220 Service ready for new user.
221 Service closing control connection.
225 Data connection open; no transfer in progress.
226 Closing data connection. Requested file action successful (for example, file transfer or file abort).
227 Entering Passive Mode (h1, h2, h3, h4, p1, p2).
230 User logged in, proceed. Logged out is appropriate.
250 Requested file action okay, completed.
257 "PATHNAME" created.
331 User name okay, need password.
332 Need account for login.
350 Requested file action pending further information.
421 Service not available, closing control connection. This may be a replay to any commend if the service knows it must shut down.
425 Can't open data connection.
426 Connection closed; transfer aborted.
450 Requested file action not taken.
451 Requested action aborted. Local error in processing.
452 Requested action not taken. Insufficient storage space in system. File unavailable (e.g., file busy).
500 Syntax error, command unrecognized. This may include errors such as command line too long.
501 Syntax error in parameters or arguments.
502 Command not implemented.
503 Bad sequence of commands.
504 Command not implemented for that parameter.
530 Not logged in.
532 Need account for storing files.
550 Requested action not taken. File unavailable (e.g., file not found, no access).
551 Requested action aborted. Page type unknown.
552 Requested file action aborted. Exceeded storage allocation (for current directory or dataset).
553 Requested action not taken. File name not allowed.
on Jan 12, 2010 | Computers & Internet
Tip
COMMON FTP ERROR CODES
~~~~~~~~~COMMON FTP ERROR CODES~~~~~~~~~~
# Description
110 Restart marker reply. In this case, the text is exact and not left to the particular implementation; it must read: MARK yyyy = mmmm where yyyy is User-process data stream marker, and mmmm server's equivalent marker (note the spaces between markers and "=").
150 File status okay; about to open data connection.
200 Command okay.
212 Directory status.
213 File status.
214 Help message.On how to use the server or the meaning of a particular non-standard command. This reply is useful only to the human user.
215 NAME system type. Where NAME is an official system name from the list in the Assigned Numbers document.
227 Entering Passive Mode (h1,h2,h3,h4,p1,p2).
230 User logged in, proceed. Logged out if appropriate.
421 Service not available, closing control connection.This may be a reply to any command if the service knows it must shut down.
452 Requested action not taken. Insufficient storage space in system.File unavailable (e.g., file busy).
530 Not logged in.
on Dec 03, 2009 | Computers & Internet
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
HTTP 501 ERROR
To resolve this issue:
  1. In Internet Explorer, click Internet Options on the Tools menu.
  2. In the Internet Options dialog box, click the Advanced tab.
  3. Click to clear the HTTP 1.1 check box, and then click OK.
  4. Test to determine if the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to the next step.
  5. In Internet Explorer, click Internet Options on the Tools menu.
  6. In the Internet Options dialog box, click the Advanced tab.
  7. Click to clear the Show friendly HTTP error messages check box.
  8. Try to view a Web page to reproduce the error message and to receive a new, more descriptive error message. This new error message may be similar to the following: HTTP version not supported by program name. Note the name of the program in this new error message.
  9. The program name that you noted in step 8 may be the cause of this issue. Either remove this program, or reinstall it.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 28, 2010 | Computers & Internet
When trying to open an internet site I get a page that says http501not implemented or supported, also it says http505 not implemented or supported. How to correct this?
The 501 status code message is displayed when the server does not recognize the document request method. The server is not capable of fulfilling this request and states the request was “Not Implemented"
These are either "Internal Server" problems if you are privately networked or "Service Provider" errors or blocks, or Site Specific.
Sometimes this can be fixed by resetting your internet protocols in IE.
Please contact your Service Provider to see if they can shed some light on this error.
Jan 15, 2010 | Computers & Internet
HTC s620 internet connection configuration problem
you just have to go to->Menu->Tools->Options->Connections. In Connections uncheck the AUTOMATICALLY DETECT SETTINGS option and select the Work option in SELECT NETWORK. Click done and now you are supposed to be able to connect to the Internet via WiFi
Mar 28, 2009 | HTC S620 Smartphone
Connecting to internet via pc
hey buddy,the problem of airtel connection starts with the settiongs on ur phone to surf...messge all to 222 for settings..after settings reboot the phone...after that..don browse on phone first...connect the usb then using sony tools connnect to net..
ne other prob's do tell me..N plz do rate me
cya
Apr 15, 2008 | Sony Ericsson K750i Cellular Phone
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Motorola Phone Tools
Try connecting the phone via USB with the power off & once connected, power on phone. Thanks.
Jul 05, 2007 | Motorola Mobility V365 Cellular Phone
Panasonic " 55"" Class / LED / 1080p / 120Hz / 3D / HDTV TC-L55ET5" Logo
306 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
