Question about Adobe Acrobat 7.0 for PC
Unable to connect to internet on vista via wireless router
Ok I've got a sony vaio laptop on vista, I've got the ethernet cable from my modem going into the wirless router (which is plexus a adsl2 + gateway) now i'm able to connect to the router ok, but if you hover over the status it says local only and im unable to access anything on internet.
I've followed the guidelines on the cd that came with it and connected to router, and done everything it says to configure it but same problem. It comes up with the error message "windows tried a repair but the problem still exists, security policy settings on this computer might be blocking the connection, the following policy might need to be adjusted to allow windows to connect, policy provider: windows firewall, filter name:query user
I've gone on several sites and have tried
ipconfig /release
ipconfig /renew
tried turning off firewall and all anti-virus protection
tried resetting tcp/ip to manufacturers settings
i've also gone into windows firewall with advanced security on local computer via admin tools in control panel and domain/private/public profile are all set to windows firewall is on then inbound connections that do not match a rule are blocked, then outbound connections that do not match a rule are allowed
any further sugguestions, i am an IT, but i have very little experience with vista so I am baffled....
    Sergeant:
  • 306 Answers
Welcome to FixYa! Vista is not access friendly but you will able to see your connection status by clicking on the network connection icon on the taskbar where you will see "Connected to: " and if you click on that a network map will appear. You will see a red "X" between your wireless access point icon and your Internet icon if the access status is "Local only". Clicking on the Internet icon will retry that connection. Make sure that your ip address is not 169.xxx.xx.x as that is Windows little way of saying it can't connect.
If you choose the Diagnose option it will do a release/renew operation automatically. With Vista you must "elevate" access by right clicking on the Command prompt executable and choose "Run as administator" if you wish to do that ipconfig manually.
Also when you are in the firewall configuration select the wireless connection>settings and make sure all of the permissions boxes are checked (ICMP, etc.)
With the adaptor advanced settings make sure your adaptor has the wireless mode (a, b, g, n) at the correct mode.
Have you tried logging on to the router via the Run bar? That is the most informative way to see your router config. Please repost if you need help with that. I also am a network professional certified since 1978 so I know that Vista defies using many tools we took for granted for so many years and often makes me feel frustrated. Maybe Windows 7 will be better as I only run Vista to help others like yourself, though at least you can understand what I am talking about:) Good luck, Steve Medley
Posted on Jan 19, 2009
Unable to connect to internet despite connection confirmed
Improve the FixYa experience for everyone by voting.
I'm going to provide you with some generic approaches in an attempt to solve your problem.
First: Microsoft will perform a complete systems check for you in three clicks with their FixIt app. CLICK HERE and Microsoft will fix (repair) any Windows related problems that might be causing your problem.
Second: It is important to connect the modem to the router before you configure the modem in order to verify communication between them. If the cabling is incorrect, the rest of the process fails.
As a rule, external modems are built with a female data communications equipment (DCE) DB-25 port for connection to a controlling device such as a PC or a router
Connecting the modem using the network cable to the wrong port of the router (other than the WAN port) is easy to identify. You can easily troubleshoot the problem. In some cases, you may correctly setup the wireless router connection but you use the wrong cable type in connecting the modem to the router. Cross type UTP cable must be used in connecting the Ethernet port of the modem to the WAN port of the router. But this is not always true. Today, many types of wireless routers (and any LAN Switches) embedded their Ethernet ports (either WAN or LAN ports) with Auto-sensing type port (auto-MDIX LAN). It means that you can use either cross-type or straight-through-type network cable for the Ethernet port connections. The system will detect the cable type and automatically adjust the ports signal accordingly.
Apr 28, 2012 | Sony Vaio VGN CR353 Laptop Universal AC...
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting to Router open diagnostic page and check your Wan connection.
If you do not find it use from same router the ping or trace command to check your Internet connection.
If you cannot get a result check Wan configuration: (PPOE/A Bridge etc) with your ISP (call or read user manual)
if your router is on net but you cannot browswe vrom vaio check if router access list is set: disable it or add your PC MAC address.
Jan 11, 2009 | Microsoft Windows Vista Ultimate Edition
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
Vista/router/wireless connection
Make sure that all the wireless cards are set in the properties to obtain an ip address automatically, dissable the wired lan adpter connections as this can confuse the router. Restart all the pc's and then right click on the wireless pc icon in your task bar and then click view wireless networks and make sure that you are connected to your network and that the internet is available, known as local & internet in Vista. open up internet explorer, go to tools, internet options and delete browsing history cookies and temp files and then refresh the page as the proxy server will need to refresh.
Sep 24, 2007 | Computers & Internet
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Adobe Acrobat 7.0 for PC Logo
1,412 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
