Question about GE Hotpoint 30" Self-Cleaning Freestanding Electric Range - White-on-White
After running self cleaner - oven door remains locked, even though the oven has cooled down
I ran the self cleaner on my oven. Stopped it after a little over an hour into the cycle because it was just too smokey for my apartment. After allowing the oven to cool, I moved the latch back to open and the oven door is still locked. It has been days since this happened and the oven door remains stuck. Any suggestions on how to fix this?
    Top Expert:
  • GE Master
  • 9,472 Answers
Try to run the self clean again for just a few mins. and see what happens.
Posted on Dec 02, 2012
  • Jean-Marie Smith Dec 04, 2012
    Thank you for the suggestion, I did try this but unfortunately it did not work. Fortunately I found out where the latch is and stuck a knife through the vents to release. It seems the lever has been damage.
  • Richard Roth
    Richard Roth Dec 04, 2012
    What is the model number?
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I ran the full self-clean cycle (4:20) and I now
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 06, 2010
  • 354 Answers
SOURCE: Ran the self cleaning cycle - Now it keeps posting
Your switch isnt right ,check the wiring on the switch or make sure the switch is closing or opening when its suppose to,you should hear a click each time it opens or closes. your problem is in the switch area no where else,the computer on the oven needs tosee that switch input and doesnt
Posted on Feb 15, 2011
Door won't open after Self Cleaning Oven
if you are facing this problem still yet, I suggest that call a service guy to fix it and turn off the power.
Apr 19, 2013 | Electrolux Kitchen Ranges
We have an electric hotpoint range and ran the oven cleaning cycle today and now the door seems to still be locked even though it should have had enough time to cool down.
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2010 | Hotpoint Kitchen Ranges
I did a self clean for 5 hours yesterday on my upper oven and almost when it was completed it showed an error code of F9, I cleared that and then it came up with an F2 error code 9 times. After it stopped...
chris15640,
I am so sorry, for your delema...
If I was around at the time you purchased your unit i would have told you, "NEVER USE THE SELF-CLEANER," Because it uses a much higher tempuature then the wires can handle..
There maybe a wire or two burnt and the computer sees them at a low resistance and the computer is not letting operate an unsafe oven.
You need to remove oven from the wall... Check ALL wires and also check the thermistat probe at the connection with the electrical. If thermistat has a resistance, OK, If no reading.. replace thermistat. If you feel that all wire are OK put back oven and if it does not let you bake,... replace computer. That is Very costly
Nov 02, 2010 | Ovens
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    Lock light on frigdaire self cleaning oven
    OK, this is not a good situation here. your Electronic Oven Control board is damaged. the logic sectors are faulty. The F-1 represents a major EOC failuer and, you will need to replace your EOC(clock) asap, if possible.
    Jun 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Jenn Air oven door won't open after clean cycle
    You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
    Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven door remains locked after completion of self clean cycle
    My oven door stays locked , when I press the clear button I get F1?
    I hold the clear button for a few seconds and still nothing.
    Please,
    Thank You
    Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Self cleaning won't shut off
    that is because it needs to cool down before the oven will unlock.There should be a timer running and when it gets to "zero" it should unlock.
    Jul 08, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
    Self-cleaning gas oven
    Door lock motor has probably failed.....Self clean on many
    ovens can be a self destruct mode. Door latch motors, sensor
    probes and even the electronic controls can be destroyed by
    this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
    Jun 02, 2008 | Frigidaire Ovens
    GE Hotpoint 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    171 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
