Question about Frigidaire Refrigerators
Styrofoam piece in fridge where air blows into unit...is that supposed to be there? appears to be restricting air flow
Just had fridge delivered and there is a piece of styrofoam in the vent where the air blows into the fridge and this seems to be a packing piece but is not listed on any of the literature I can find on this model. The air flow seems restricted to me and I think this piece should be out, but I am not sure if it is supposed to be part of the design (if so, that seems slightly stupid?). There is not much air blowing into the fridge, while the freezer has already started to cool considerably.
My kenmore side by side has only one opening between fridge and freezer but has another vent at the bottom but it does not go all the way though, its just full of styrofoam,shouldnt there be two? Is this...
If you don't have the owner's manual for your refrigerator you can go to Sear's website and get it online. But normally shipping styrofoam isn't packed where it's too difficult to remove. If you see blue tape on it that's a very good indicator that it is not supposed to be there for normal operation.
Aug 24, 2014 | Refrigerators
Tip
Columnar cushion - S-type styrofoam packaging material
S-type styrofoam cushion pieces are found in typical packing materials.
To create a columnar (collumn) shape, attach the individual S-shapes into a collumn.
The result is a single piece of cushioning material for placement where you need a continuous cushioning.
on Mar 22, 2010 | Air Tools & Compressors
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
Just received a new air purifier, and was quite surprised to see big pieces of styrofoam in the fan/air output area.....at first we thought it must be packing materials. My question is: I thought that...
That is packing materials. It was placed there to protect the vent louvers on the front from breaking during shipping. Apparently, some of them chipped or broke and found their way into the louver section. Simply clean them out. Small pieces can be sucked out with a vacuum that has a hose and crevice tool attachment.
Mar 07, 2011 | Hunter (30067) Air Purifier
My whirlpool refrigerator is leaking water from the top freezer down to the refrigerator. What is causing this?
most likely you have a clogged drain,when the fridge goes into defrost it melts the ice off of the evap coil and it drains down to where the compressor is in the bottom section of the fridge,if the drain is plugged up the water will leak into the fridge section,take out all the food and shelves and remove the back wall of the freezer,if you know where the timer is or if it has a timer you can advance it and turn the heater on to help you out or unplug the unit so the fan isn't blowing or shut off the control,with a hair dryer melt all the ice,where ever you see styrofoam try not to leave the hair dryer in one place to long you can damage the styrofoam,the vents are under the fan,you can put a plate or something inside the fridge and pour hot water down the vents to melt out the ice if the vents have ice in them and it melts the ice faster and won't damage the styrofoam,now when you have the ice melted i use a steamer to clear the drain but if you don't have one you can use a turkey baster or a piece of hose and blow through it,anything you can think of to blow through the drain line,when you think you've cleared it pour hot water down the hole,if like a half a cupful goes down it's clear if it stays there it's not clear and you'll have to blow it out again,if you have any electrical wire with the ground wire in it you can use the copper wire wrap it on the heater or near it if it's a glass heater and when the heater comes on the wire will heat up and stop the drain from freezing in the future,stick it in the hole as far as it will go and leave a little extra so you can wrap it around the heater or like i said if you have a glass heater attach it to the metal frame as close to the heater as you can and you should be fine,they sell heater probes at the parts store also,let me know how you make out
Sep 05, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Possible remnant foam left in vent from manufacturing process
This needs to be taken out if not it will affect your system. Never cover up the vents on a unit hard on compressor.
Jun 24, 2010 | Heating & Cooling
I have a Samsung Twin cooling french door fridge with the freezer drawer at the bottom. I notice that in the vents in the back cover where the cooling fans are you can see styrofoam. I am afraid that it...
This is normal, the vents are lined with styrofoam to help minimize loss of cooling when the air is circulated from the freezer section into the fridge section.
Most of the vent and cold air channels are made entirely from styrofoam these days in most fridges.
Most packing foam is in plain sight and usually held in place with tape, so it is highly unlikely that any packing foam would be behind anything mounted permanently in a fridge.
Hope you find this Very Helpful and best regards!
Aug 29, 2009 | Refrigerators
Used older refridgerator not getting real cold; styrofoam coils
the evaporator coils should be on the inside of the freezer/fridge,the outside coil is your condenser coil and the air needs to be able to move freely through it for it to work properly.there may also be an auxiliary set of coils that sit in the water run over pan that helps evaporate the runoff,this run off also helps the frig work better by cooling the condenser.this set of coils may or may not have air flow usually not.If it is blowing cool air give it time sometimes a old machine needs to run for a while before it starts to work .
Mar 16, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
1,659 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
