Question about GE Home
How do I set the timer for a GE relocatable power tap EMP700UL-PC?
There is only one button and a digital screen of #s 1-9 and A, d, and F.
  • GE Master
  • 5,245 Answers
1) Copy following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Timer turns ON automatically at dusk.
Push button to select duration of ON time.
d is probably dawn, so dawn-dusk
Maybe A is always ON, and maybe F always OFF.
1-9 will be number of hours timer remains ON, for example ON at dusk and OFF 9 hours later.
Posted on Jan 01, 2013
I have lost my manual (probably inadvertantly through it out) for a digital relocatable power tap E192912 PS805
Ohhh those are easy... if you respond I will walk you through it. and they are all basically the same. i have 3 or 4 different brands and re program them each season , such as DLS
Dec 04, 2013 | NA Zilla 11893 24/7 Digital Timer Power...
Need instructions to program GE emp700ul-pc cat#15147
1) Following links will help identify timer, and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#13660
2) Mode button could be a problem: After programming is complete, press clock button to start timer programs at next set point.
It is not necessary to push Mode button.
3) If timer does not show, then Add comment and include photo or detailed description of timer for possible identification of timer, and possible manual
Dec 04, 2012 | GE Hardware & Accessories
How do i set the timer for a GE emp700ul-pc, cat#15147
F= off
O= on
1-9= # of hours it stays on after dusk
D= on from dusk to dawn
R= random hours is stays on after dusk each night
Dec 04, 2012 | GE 15107 24Hour Yard Stake Timer
How do I set timer for relocatable power tap 6099
You have a power strip timer with either digital or analog timer.
Copy following link to identify common power strip timers, and download manual, or instructions..
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
http://waterheatertimer.org/How-to-set-timers.html
If this is not your timer, then add a comment and describe timer in detail.
Nov 25, 2012 | Hardware & Accessories
Could you please describe the problem you are having a little better?
Nov 24, 2012 | Refrigerators
How do I program a GE Relocatable Power Tap EMP700UL-MT
TIMER INSTRUCTIONS:
When the timer is plugged in, the timer's dial will turn clockwise. The pointer, on the face of the dial, points to the current time of day.
1. Locate the segments on the outer edges of the timer's dial. These segments, each representing 30 minutes, can be pushed down (try using the tip of a pen or pencil). Conversely, segments pushed down can be easily pushed back by hand. Be sure all segments are pushed up before programming. Select a time period (or periods) you want the device turned on, push down the segments that fall on or within that time period. For example, to have the timer turn a device on 10PM and off at 2AM, push down the segments representing 10PM and 2AM, and ALL the segments in between. See Figure 1.You may need to turn the dial clockwise to access the desired segments.
2. Rotate the timer's dial clockwise until the pointer on the face of the dial points to the current time of the day. Note: Nighttime hours (from 6:30PM to 6:30AM) are highlighted.
3. Plug the timer into an electrical outlet convenient to the device to be controlled.
4. Plug the device into an outlet on the timer. Turn the device's switch to the on position for automatic control. The timer will not turn the device on if the device's switch is in the off position. The device will now turn on and off at the times you have set. In case of power failure, reset the time of the day as explained in step 2.
Sorry no Image.
Dec 04, 2011 | Televison & Video
How do I set the timer for a GE relocatable power tap EMP700UL-MT
F=off
O=on
1-9 = # of hours that it stays on after dusk
R= random amount of hours it stays on after dusk
Dec 04, 2011 | GE Home
Have set the timer to come on at the same time every day and off at the same time every day but when I put it Auto mode does not turn on. What step am I missing
You posted under GE dial-type power strip timer.
GE has 2 different models: 57698 & 15090
15090 has instruction manual, and 57698 doesn't.
http://waterheatertimer.org/GE-timers-and-manuals.html#57698
GE also makes 15077 digital power strip timer:
The digital power strip has Auto mode.
1) If programming has overlaps, or if programs are set for conflicting days, then timer will not operate as expected. Review programming steps by pressing PROG button.
2) If current time is not set, then programs will not operate. Press and HOLD clock button while setting current time.
3) I test timers, and sometimes manuals are confusing so I write out the steps to make sure I understand correctly.
4) It is possible that timer is defective.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | General Electric GE 24-Hour Power Strip...
Home Logo
1,199 people viewed this question
Top GE Home Experts
adrian tinta
 Geoff Hazel
Geoff Hazel
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a GE Home Expert? Answer questions, earn points and help others
