I have a ge top load washer and the agitator is not working . what would cause this to happen?
I posted a question and received a answer telling me that the transmission was bad on my unit. i got lucky and a friend of mine had a wash machine he was not using. thanks for the help. it saved me the expense of a service call.
Posted on Jan 12, 2009
My top load GE fills, drains, spins, but does not agitate. Agitator coupler or timer control?
The most likely cause of this is a worn out agitator coupling. To see if this is the problem with your machine. Grasp the agitator and twist back and forth. If there is movement without turning the tub you most likely need a coupling. Reach into the washer and try to turn the agitator by hand and if you can turn it freely the agitator coupling the coupler is out and it has to be replaced. ----------- This will help.Thanks.Helpmech.
Jan 20, 2011 | GE WBSR3140DW Top Load Washer
What will cause black grease stains on clothes in a GE washer, when the clothes are not greasy going in. Agitator seems a little loose.
It maybe a bit of grease worked it's way down inside the agitator,check if there is a way to "torque" down the device.
Mar 28, 2010 | GE WJSR2070B Top Load Washer
Knocking noice in agitation cycle
Do you get same sound if you run through a wash cycle empty (no clothes?) using detergent? If so, then likely a basket support has come loose (check deep inside along top ring). If not, then you may be overloading washer (unless using different sized loads), or the agitator is not working like it should, and basket is torquing.
Sep 15, 2009 | GE WJSR2070B Top Load Washer
GE top loading washer Washer wwse5200- Agititation?
it is a "trany" problem...just buy a new washer or it is a plastic cap inside that spiral part, that cap have groves...it is maybe goes bad....
GE as a brand has a lot of problem with washers, dryers, microwaves and fridges...and dishwashers so try to stay away of repairing or buying a new GE....
Sep 05, 2009 | GE WWSE5200B Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
Agitator is slipping- GE model WJRR4170G top load washer
IF the agitator is like the ones in the older models, it will just pull straight up and off of the transmission shaft.
Inside the agitator there is a rubber splined insert with an aluminum center. The soft aluminum strips out causing the grinding sound. Very common to happen.
We used to use a special puller to remove that part and then press a new one back in.
Voila! Repaired agitator!!
Most any appliance parts store should be able to look up your model # and tell you if that agitator can be resplined.
Jan 30, 2009 | GE WJRR4170E Top Load Washer
GE Washer top load model WDSR4110T
the agitator is the spline insert . that you can replace. The spin problem is in the clutch which is a bigger job
Dec 11, 2008 | GE WBSR3140DW Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
GE washer WWSR3090T6WW
I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
Oct 22, 2007 | GE WDSR2080D Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
