Question about Plumbing
Have a well for my sprinklers. The pump starts at 35lbs then after a minute or 2 drops to zero then after another minute or two back to 35lbs. It does this through the running of all 3 zones. What could be casing this?
    New Friend:
You R losing prime air is seapping in from the suction side of the well pump.check all the fittings from the pump to the well head to see if u have a leak also check the pipe to see if it is cracked or broken. If every thing looks ok it can also be a lack of water supply in your well meaning the water kevel in the ground is low. The onley other thing i can think of is the impeller in the pump is bad and not throughing water
Posted on Dec 02, 2012
2 Suggested Answers
  • 1015 Answers
SOURCE: Brand new Wel Bilt 1 HP shallow well pump, shuts
It sounds to me like you have a defective thermal switch that is shutting power off as if motor is overheating.Unless you are exceding the head or flow ratings on the pump I would recommend you return it for replacement.Thank you.
Posted on Jul 13, 2011
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
Fuel pressure v6
the fuel pressure should be around 35lbs with the key on. and when running should be the same with some fluctuation but no more than 3lbs either side of 35. how long has it been since the fuel filter has been changed. this should be done if it hasn`t been and or when the fuel pump has been changed.
May 25, 2014 | Nissan Frontier Cars & Trucks
Icemaker Kitchenaid KUIA18PNLS2 water won't run over the chill plate.
Replace the recirculating pump, that pump must run to bring water from the reservoir to the chill plate. A quick teat for you, Turn off unit wait 2 mins, turn back on, tat this time the unit should fill for a minute, run recirculating pump for one minute, fill again 1 minute, than run compressor with the recirculating pump. Anythings fails at this point the component will need to be replaced.
Good Luck
Nov 16, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
2004 gmc sonoma why does it take 2-3 times cranking before it starts and only does it sometimes?
install pressure gauge and watch when key is turned off to see if pressure drops to zero if so bad drain back valve in fuel pump replace it or deal with it or could be cheap aftermarket pump and has hard time building unnecessary pressure to open poppet valves between before fuel injectors
Oct 23, 2012 | 2004 GMC Sonoma
Brand new Wel Bilt 1 HP shallow well pump, shuts off after running for 5 to 10 min !!! Help ! JGP12001CHT (Northern Industrial Shallow Well Pump. Installed to pump creek water for yard, runs at 30 PSI on...
Jul 13, 2011 | Plumbing
I have an aquamate pump and when i connect it to a continuous sprinkler it stops and starts contiuously
The pump is putting out too much water for the sprinkler.
You can raise the pump shut off pressure at the switch until it is higher than the pressure that the pump runs at with the sprinkler operating. You should have a surge tank connected to the system to give the pump time to balance with the sprinkler.
You can use more water with the sprinkler. This could mean adding another sprinkler or increasing the nozzle size of the existing sprinkler.
Dec 05, 2010 | Garden
My 2000 S10 with the 4.3l vortec is hard to start. I connected a pressure gauge to the schrader valve and the fuel pump builds 10psi when I turn on the key. If I cycle the key several times it will slowly...
Key on engine off pressure on your truck should be 60-66lbs. A fuel pump replacement is definitely in order, bad thing is it is a whole assembly.
Jul 24, 2010 | 2000 Chevrolet S-10
Sprinkler pump quits after 30 seconds?
call the company you purchased it through...that would be a warranty issue...sounds like it is overheating.
Jun 11, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Ice maker is switching itself to clean mode. I have to push stop ...wait a few minutes and switch it back to "ON". It is doing this quite frequently. In addition, once it is switched back on, the water...
hi my name is mark, sounds like the clean switch is sticking. does this unit have a membrane in front of switch. switch might be wet. also you might let the clean time out, then restart unit.
Feb 04, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Plumbing Logo
506 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
