Question about Zynga Texas HoldEm Poker
"Access code 34m my chips..noe u gave me 1m..why???
I follow double Dowb Casino's for 1M chips, 20 times and for a few that were 15M and yet I can't seem to get to the codes, alwasy something blocking it or I see you have earned 1M in chips redeem now,
double down casino is very quirky. it is always offline or updating. i dont recommend buying anything from them. there are better alternatives to casual casino gaming style apps. contact cust care.
Mar 12, 2014 | Evermoremedia DoubleDown Casino
I need the "activation code" to enter PCH 1M 2014
I tell about get winner now and w71 notice. now
Jan 27, 2014 | pch.com
Obo scanner gave me these codes p0171, p0201, p0202, p0203, p0204, p0321 and it wont start? please help i noe what the codes mean just dont noe what to go for
I will give you what the codes mean and you can then work out what to replace.
code p0171 refers to system too lean--bank 1===causes intake / exhaust leak---AIR system---MAF/VAF sensor---fuel pressure/pump---injector/s---HO2s
code p0201 refers to injector 1--circuit malfunction===causes--- wiring--injector ---ECM
code p0202 refers to injector 2 --circuit malfunction===causes --wiring---injector--ECM
code p0203efers to injector 3 --circuit malfunction===causes---wiring--- injector --ECM
code p0204 refers to injector 4 --circuit malfunction===causes ---wiring ---injector ---ECM
code po321 refers to crank shaft position (CKP) sensor/engine speed (RPM) sensor---range / performance problem===causes---air gap---metal particle contamination---insecure sensor /rotor --wiring---CKP/RPM sensor.
Jan 05, 2014 | Audi TT Cars & Trucks
DoubleDown was giving away 1m chipsto loyal players. I did the word gifts on the page where you buy chips and it gave me the 1m chips. I started playing and all of a sudden they took the 1m chips away and...
Zynga Poker sent you an email regarding possible unauthorized access to your Facebook and Zynga Poker account. This email was sent to a**a@yahoo.com. We recommend changing your Facebook password immediately.
Please verify your account by carefully following the instructions in the email. Click here to resend email.
Message Code: CA1
Aug 11, 2013 | Evermoremedia DoubleDown Casino
I have a dodge grand caravan 96 itruns but wen i stop it just trowes masfires and i run the machine gave me code p1495 i think is a sensor but dont noe were it is
code P1495 leak detection pump solenoid circuit malfunction. the leak detection pump located underneath the vechicle right behind lower left corner of the engine compartment.
Oct 05, 2012 | Cars & Trucks
Thanks for installing Zynga Poker! We now offer email updates about new features, special promotions, poker tips and more. Also, your first email will include a special Welcome Chip Bonus up to 1M...
I have the same problem, I used a temp fix, I am using Firefox, I Right Click and go to Inspect Element(Q), And delete the correct node from the bottom navigation menu called "DIV#popups_top_delayed_onetime" and then close the inspect interface from the bottom right, if you delete the wrong node you will have to reload the page and try again, every time you reload your browser you will have to repeat this action, I have yet to come up with a permanent solution.
Aug 04, 2011 | Facebook Social Network
Have zynga poker give player to claim bonus chips???
Cam, thanks for installing Zynga Poker!
We now offer email updates about new features, special promotions, poker tips and more. Also, your first email will include a special Welcome Chip Bonus up to 1M chips!
Feb 26, 2011 | Zynga Texas HoldEm Poker
I have a dell inspiron 9100
It appears you have the latest BIOS revision for your notebook.
That chip is not supported by your motherboard/BIOS revision. You may want to contact dell, or keep checking the support download page to see if they release an update allow you to upgrade.
Nov 10, 2008 | Dell Inspiron 9100 Notebook
Zynga Texas HoldEm Poker Logo
14 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Corne Viljoen
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
