Question about Refrigerators
Whirlpool refridgerator is working but it runs constantly, makes a slight thumping noise periodically (compressor). Does not shut down for more than 15 secs. Model # model et1mtexlq01
  • Russ Nesbitt Dec 02, 2012
    forgot to add Coils get cleaned every 6 months, BUT with two cats and a golden retriever they are very dirty each cleaning!
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 02, 2012
rylee_smith
  • 8619 Answers
SOURCE: making lots of noise when running help?
Hi
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Please revert for further assistance and Do accept the solution if found useful.
Thanks
Rylee
Posted on Mar 18, 2009
leorcid
  • 281 Answers
SOURCE: noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Posted on Feb 06, 2008
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
SOURCE: Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Posted on Aug 16, 2009
Constant steady loud noise from Whirlpool Gold refridgerator. Sounds like an engine running.
I wrote a tip about that and why refrigerators can get an annoying noise sometimes...
Refrigerator Fan Noise
heatman101
Jan 18, 2011 | Whirlpool Refrigerators
Only when my whirlpool refrigeratior stops running, the compressor makes a knocking noise. If I push the compressor slightly with my hand, it makes the same noise and the mounting bolts are tight. What...
Good day,
The motor and pump inside the housing are mounted on 4 springs to cut down on vibration.
One or more of the springs has broken, allowing the internal unit to flop around, hitting the sides of the case.
There is no repair possible except replacing the compressor.
Oddly, the compressor may run a long time in that condition, but it will ultimately fail.
Oct 22, 2010 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My GE tfx27f is working fine but when the
the thump ing sound is probably the rubber mounts under the compressor . they go hard and do not insulate the compressor . . pry the comp up on all four mounts and make sure they are loose and not stuck down if ther are hard and not bouncy .. replace them . if compressor has borken internal motor mounts / there is nothing you can do . but put up with noise ..
Jan 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool top load washer makes noise on filling
Its mainly caused by back pressure when the inlet valve suddenly shuts off the water to the machine. The pressure causes your plumbing pipe work to shake inside the walls.
You can turn down the pressure by closing your water tap and only having it slightly open. Or you can get pressure limiters which join on the hose.
Regards
Ash
Oct 26, 2009 | Whirlpool Washing Machines
Mar 20, 2009 | Refrigerators
Refridgerator
One of the springs that retains the piston in the compressor is broken. Refrigerator may operate for years like this, but check your warranty many refrigerators have 5 year coverage on the sealed system.
Fieldpro Appliance Repair & Installation 503-775-3501
Jan 31, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpoor Refridgerator 10-12 yrs old
I had a whirlpool fridge that did the exact same thing. Sometimes it was loud enough to wake me up at night! It is the compressor shutting down. I had it for several years untill I purchased a larger one, and then gave it to a girlfriend at least a year ago. Its still working good today. So if you can tollerate it, just live with it. Otherwise change the compressor.
Jan 04, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool Refridgerator Noise
Why did you put the megahertz (60 hz) on your question? Get access to the back of the fridge, take the panel off, on the bottom, there is a compressor and condenser fan motor. Look these two and see if the noise can be found here. The fan should run when the compressor runs. If the fan is running and quiet, put your hand on the compressor. It should be warm, slightly hot, but not so that you cant leave your hand on it. If it feels hot and the fan is running, clean off the coil underneath the fridge. Often this is the only problem as nobody hardly ever cleans this thing off. Its the equivalent to the radiator on your car.
Dec 26, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
