Question about GE GFWN1100LWW Washer
GE front load washer tub wont spin in both directions
    Top Expert:
  • GE Master
  • 9,472 Answers
First, check the pump filter to be sure it is clear and post back your results.
Posted on Dec 02, 2012
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may not align perfectly but don't worry, just get them to go back in the hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
Posted on Apr 15, 2008
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
SOURCE: ge front load washer does not spin or drain
Unscrew the botom front panel,behind that you will see a lint trap,with the power off,and unplugged,place lot of towels on floor at this trap,unscrew slowly,as water will exscape,trap will pull out with plug,clean trap,,,,,,,,,,,,,,,,,,,,,,,trap is about 1.5 inches round,it located at bottom right side of my machine,,,,,,,,,good luck
Posted on Apr 11, 2009
  • 512 Answers
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Posted on Jun 12, 2009
kapishtech
  • 2272 Answers
SOURCE: GE front load washer is not draining after spin cycle
The draining is controlled by drain pump in the washing machine. If the drain pump is clogged or got loose then water will not drain properly and this problems will occur.Remove the drain pump and drain hoses. First thing you can do is take the drain hose and blow into it and check if its getting blocked.If the air is passing through the hoses then loosen the hoses to the pump. You might want to get some pinch off pliers to save water from going ever where or a shop vac to **** out the tub. If the pump is getting warm current is flowing to it and propeller is jammed more than likely. The front should have a couple of 1/4 screws at the corners on the front should pop after removing them. If you require parts then you can buy them from www.repairclinic.com Thanks. you can rate this solution and show your appreciation.
Posted on May 17, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
Wash tub seems loose and wont spin
There are bearings on the back wall of the unit that may be worn out and on the front- may be the door seal -or bearings also. Not enough info here from you
Jan 08, 2014 | GE WSXH208A Front Load Washer
DURING THE SPIN CYCLE THE WASHER STAR KNOCKING.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 20, 2011 | GE WSXH208A Front Load Washer
Sounds like the tub is out of balance when spinning a load of wash.
Washer Problems
heatman101
Jan 26, 2011 | GE WSXH208A Front Load Washer
The tub wont spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 10, 2010 | GE Energy Star WCVH6260F Front Load Washer
Our new GE front load washer shakes/ vibrates and moves during the spin cycle
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Aug 22, 2010 | GE WSXH208A Front Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
My ge washer wont spin by itself. i have to take
it sounds to me like your motor is defective, maybe, just the start switch, but best to replace motor...Bruce
Oct 10, 2009 | GE WDSR2080D Top Load Washer
remove bottom cover ..remove as much water as possible from inside tub remove cleaning port on front of pump by turning counter clockwise..rmove all money lint screws nails be sure to ck into pump itself
May 28, 2008 | GE WBVH6240F Front Load Washer
GE GFWN1100LWW Washer Logo
74 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
