Tub wont spin in both directions
Wont spin either
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Check the drain filter.
Posted on Dec 02, 2012
LG Model WP-9241 Washing Machine - Wash tub spins in only one direction
wash tub spins in only one direction it cannot spin in other direction
Dec 21, 2014 | LG Washing Machines
Why does the inner tub for the LG washing machine tub not spin when the tub is full?
not sure I understand you, but ur drum should or does not spin when full as it is set that way, first the drum drains most of the water then it goes into spin?
Jul 29, 2014 | LG Washing Machines
Washer filled and will not drain if I reset the fill capacity knob it will fill but not drain.
This washer has a belt. The belt drives the pump on this washer. The motor turns in both directions. iIn one direction the washer tub is locked and the tranny agitates. The water pumps out and the tub spins in the other direction. If that pump is locked up or the hose from tub to pump is blocked then it wont pump the water out. Lay the drain hose down towards a bucket and see if any water comes out. If not you got blockage. Once you drain it out tip is back and remove the belt (no tools needed) turn the pump both directions and look for signs of a failed pump. Manual and more
Jun 30, 2011 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
WASHER WONT DRAIN
Does the washer spin on rinse and drain cycles ok? If it does spin but won't drain, the problem is the plasic impeller in your drain pump. This model is a direct drive unit with a reversing motor that runs one direction for agitate, but reverses to spin the tub and operate the drain pump. So if it spins but DOES NOT drain, it's the drain pump, but if it doesn't spin or drain, than it's probably a lid switch. Also the tub to pump hose or pump discharge hoses may be clogged with something. If your mechanically apt, you can do this repair yourself and save a service charge. The pump runs about 30 dollars or so and is really easy to change out. Check out Youtube videos on Whirlpool washer repairs, they will show you everything to do. Yes, I said Whirlpool, because Roper is built by Whirlpool.
Hope this helps
kcomp1863
Dec 29, 2010 | Roper RAS6233KQ Top Load Washer
Washing machine tub is jamed and wont spin, motor is still spinning and belt is squeeling.
Sounds like either the brake or the transmission is locked up. Either way it is a major teardown.
Jan 03, 2010 | Westinghouse Washing Machines
Washer vibrates terribly loud on high speed spin cycle
Either bad motor, motor bearing, tub bearing or idler pulley (also broken motor mount). Unplug unit. Spin tub by hand. Try and feel if spins freely. If direct drive unit (no belts). Most likely tub bearing or motor. Remove rear panel. Inspect for damage (broken mounting parts). Turn tub by hand. Look for malfunction.
Jul 10, 2009 | LG WM0642H
Maytag Washer, LAT2300AAE, won't spin
ok lets see here;your transmission can go in two directions.if you turn the middle pully one way it will agaitate if you turn the oppisit direction you can watch [from under neath]the brake raise as the cam seperates and lifts the brake.now with the brake lifted ,your tub should spin.if its not lifting the brake you need a new center pully kit[i have had to do many]it comes with washers ,bearings and cams.if the brake lifts and your tub still wont spin you may have a pice of clothing between the two tubs[i had that one to,many times]i hope that helps.you can email thru fixya if need more advice God bless ,tom
Jan 26, 2009 | Maytag Dependable Care LAT9706
Wont spin
Could be the clutch. Is there a burning smell from the tub area? The clutch is directly under the tub. It's a royal pain to get out.
Apr 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
