Question about Dishwashers
My dishwasher moans as if in pain while running.
Anyone have a clue about this?
  • 979 Answers
I believe the problem to be with the circ motor (recycles the water). If this machine is older than 7-8 years, then you may have to replace the motor. Hopefully, it is just that the machine needs to be delimed. This causes a lot of problems.
Posted on Jan 11, 2009
My Bosch made a moaning sound and never got water to wash dishes. I tried to cancel the cycle and it would not cancel. I am guessing I have a bad controller? Can you tell me how much that piece would...
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Sep 10, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Moaning Dishwasher
I am still waiting for my response. Your site has not responed yet.
Jun 25, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Moaning noise in steering column
The probably lubed the intermediat shaft conenction. The loud poping noise could be from them not sitting the boot back correctly. Inspect your boot. As for the moaning noise Only thing I can think of is a hydraulic noise.
Dec 11, 2008 | 2007 Saturn Outlook
Fagor Dishwasher
ok if you have a volt meter then remove the bottom kick-plate locate the water valve take the connector off the valve set the meter to ac volts plug the leads into the connector turn the timer to fill if your getting the proper volts to the connector then replace the valve if nor reply to me
Jun 11, 2008 | Frigidaire 24 in. FDB126RB Built-in...
There is a green light on with padlock next to it
Try holding the "heated dry" button for 3-4 seconds. It may be that the "child-proof" lock is on.
Nov 28, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Washes fine doesn't drain.
I had the same problem, solution was simple.I removed the cover and there is a small white wheel on the right lower side, not where the motor is..it was not turning, i just restarted the whell movement by hand then carefully oiled with wd40.
works great again
hope it helps you
Sep 22, 2007 | Danby 22 in. DDW396 Free-standing...
Variable fan, moaning
a variable-speed fan is highly unlikely for this unit. your fan needs to be replaced or serviced with 30W oil on shaft bushings
May 30, 2007 | GE GSH25JFR Side by Side Refrigerator
Error message on Smeg dishwasher
i have error 1 on our dishwasher any clues ?
Apr 23, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Dishwashers Logo
247 people viewed this question
Top Dishwashers Experts
