Question about Whirlpool Washing Machines
WTW5600XW0 Our machine was used for approx 6 mos. then in storage for 1 yr. It is now just not cleaning well at all. It is no longer filling with as much water as it used to. It's as if the weight sensor is inaccurately weighing the clothing. It does agitate and spin, but, again, is NOT getting our clothes clean at all! Sometimes some of the clothes on top don't even get all of the way wet. Anyone know what I should do to fix??
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
  • 254 Answers
SOURCE: water problem
  1. Calypso washer
  2. FAQ's for washers
  3. Frigidaire, Westinghouse top load washers
  4. Frigidaire front load washers... ( some GE and Kenmore are made by Frigidaire )
  5. GE  newer style washers - after approx 1995
  6. GE  older style washers - pre approx 1995
  7. General Washer Information   - how does my agitator come off, filling problems and much more...a great place to start!
  8. How Washers Work
  9. Maytag Dependable care top load washers
  10. Maytag's SE1000 electronic stackable diagnostic chart
  11. Maytag's Neptune front load washer
  12. Maytag's Atlantis "how to take apart"   Which is very close to the Performa & Magic Chef
  13. Maytag Performa & Atlantis plastic tub washers....Norge, Magic Chef,American Admiral washers
  14. Noise tip for washers and dryers
  15. Speed Queen and Amana washers
  16. * Whirlpool, Inglis, Kenmore Direct Drive washers
  17. * Whirlpool, Inglis, Kenmore Belt drive washers
  18. Whirlpool, Duet front loading washing machine ( some of the Kenmore's as well )new25.gif
  19. Own a Kenmore? Department store brands can be a pain as it is difficult to figure out which manufacture has made your product. This link here should help to find out which manufacture has made your Kenmore Appliance.
  20. How old is my appliance help for some of today's major manufactures
  21. Cleaning and laundry tips
  22. Repair manuals can be ordered here: Appliance Repair manuals
  23. Washer timer knobs and how they come off
  24. Washing machine dancing across the floor? - Here's some tips on how to keep it in its place
Posted on Apr 01, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
hiltonjug
  • 612 Answers
SOURCE: Washer wont fill with water/clothes dont get clean
Actually the machine is working like it is designed. When the correct soap is used, these machines clean clothes better than the old style. Try using a major brand of soap like Tide, Bold, or Cheer. Make sure it has the HE design on the bottle. This means that it is made just for the new High Efficiency machines. Also make sure you don't use to much. Read the directions. If this is done correctly, I'm sure you will find that it does clean great. I was like you when I first saw one of these new machines. "These is no way you can clean dirty and I mean dirty clothes without enough water to cover them. Well since, I have became a believer. They have put a lot of thought into designing these things. They had to of, for them to clean as good as they do.
Please rate solution
Posted on Aug 28, 2009
WTW5600XW0
Check the water level sensor hose by blowing it out. The hose runs from the side of the tub to the console.
Dec 02, 2012 | Whirlpool Washing Machines
WTW5700XW0
with the unit being moved around you have probably unplugged the motor some how. if its not moving the drum round and has been moved around, that's what i would check for as with the motor not moving it will not measure water or load as this is done by the motor.
Jul 10, 2017 | Whirlpool Washing Machines
Whirlpool cabrio wtw5600xw0 will not spin
There is a spin sensor that is part of the shifter if this is wet it wont sense the spinning, hence wont spin, and if it is wet you mat need to replace the tub seal http://www.appliancepartspros.com/gearcase-motor-pump-parts-for-whirlpool-wtw5600xw0.html
May 29, 2012 | Whirlpool Cabrio Washing Machines
I have a Xantrex 400 plus jump starter 2 yr old won't take a charge ???
Hi!!
The problem with those jumpers is the battery, if it is not used regularly, it can go bad in 4 - 6 mos. Replace the battery and you'll be OK.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 18, 2011 | Xantrex Technology Air Tools & Compressors
ELEMENT IN OUR F1063B WILL NOT HEAT ,TOLD BY LOCAL REPAIR THERMOSTAT CONTROL NEEDS TO BE REPLACED,IS THIS PART AVAILABLE AND IS IT POSSIBLE IT WOULD BE A WARRANTY ITEM,DEEP FRYER APPROX. 1 YR. OLD ...
Most items are 1 yr warranty, however Firm may fix this under GOODWILL if you state this item should be expected to last longer than 1 yr before breakdown...I found that in most cases if you speak to the company they will listen and be sympathetic to your problem.....Good luck.....
Feb 14, 2011 | Euro-Pro F1063 Deep Fryer
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Drum filling with water and now and them gives off a nasty smell
try cleaning out the filter but dont forget to turn the hot and cold water taps off at the rear!
Aug 15, 2008 | Zanussi F1245W Front Load Washer
Maytag 2 Door Refrigerator (1 yr old)
the rule that i follow is ,not used more than two months unplug open doors and air out.
May 15, 2008 | Maytag MSD2656G Side by Side Refrigerator
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
