Question about Brother Disney PE-180D Computerized Sewing Machine
Brother pe180d thread bunching up underneath
My machine used to work fine. It was then put away while we moved and got sorted ect. I got it out the other week to use and now all it is doing is bunching the thread underneath. It is also working its self around the bobbin aswell. Anyone know how to stop this and get it working how it should do again? Many Thanks
  • Brother Master
  • 7,365 Answers
Try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin is turned the right way
make sure the thread has not come off the thread take up lever
if the machine continues to see bunch thread underneath then the
machine may need to be checked to see if some part has become
damaged or out of alignment
Posted on Dec 02, 2012
SOURCE: bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Posted on Feb 08, 2008
SOURCE: needle not picking up bobbin thread
Check the timing.
Posted on Mar 06, 2008
SOURCE: Thread won't catch bobbin
I hope to God nobody else pays more for a repair than the machine is worth.
It's ridiculous to spend $300 for that repair since the machine is available almost everywhere for way under $200. You could have thrown that one in the trash and bought a new one cheaper than the repair!!
I paid $129 for mine, had the same problem with two, yes, two of them, and sent them back and was sent another which so far is working fine. There seems to be a flaw in the engineering of that machine since so many people are experiencing the same problem. The machines DO have a warranty so please, please, be careful of unscrupulous repair people. Oh, I'm sorry but I need to mention that I bought my machine from eBay and it was a refurbished machine sold by Ken Sewing and Vacumm in Muscle Shoals, Al. They stand behind their products and were very nice to deal with, they even paid for the return shipping on the two that I returned. Hope this helps y'all.
Posted on Nov 10, 2008
SOURCE: brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Posted on Dec 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: I have a Brothers XL-3200 which works great but
Your thread tension needs adjustment.
Most likely it is the lower thread tension (not the upper thread tensioner).
When sewing very thin or very heavy material - it is required to adjust the lower tension as well.
To regulate the lower thread tension - turn the small screw on the tension spring of the bobbin case with a small screwdriver.
To increase tension - turn it clockwise SLIGHTLY.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jul 01, 2009
Disney embroidary pe18od loose stitches under work what am i doing wrong
Use a brand new needle that is best suited for the thread weight and type of fabric you are stitching.
All About Needles
Be sure that you ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disk so the thread will seat properly. Also, if it continues to have loose stitches underneath, tighten the upper tension.
Oct 18, 2016 | Sewing Machines
STRING IS BUNCHING UP. NOT FEEDING RIGHT MAYBE
By string, I assume you meant thread ? Is it bunching up underneath the fabric you are sewing, or on top ?
If it bunches up underneath the fabric, the upper thread tension may not be right or the mechanism may be worn or need replacing. If it bunches up on top, thread guides may be catching or the needle may be damaged.
First thing, try a new needle. Damaged or dull needles can cause problems. Also try a new spool of thread, because sometimes a thread spool might have been damaged or is just bad quality. Some machines will not work well with very cheap, economy threads, so if you're using cheap thread, get better thread to try also.
Test stitch after each change you make to see if it's helped. The upper thread tension adjustment should work at any setting, but for normal sewing, should be at a middle setting.
If thread snarls up on top of the fabric, unthread the machine and check every thread guide for wear or nicks that might be catching thread.. needles can cause this also. May need to replace a guide if it's damaged, or perhaps use a file, emery cloth or sandpaper to smooth a rough spot. Rethread the machine with a new spool, set the upper tension to a medium level and try again.
If the thread bunches under the fabric, it's often the upper tension that's not right. Thorough cleaning of lint from the bobbin area should be done also, even a tiny bit of lint can be a problem in some machines. Try rethreading, try a new spool of thread, and a new needle.
If no setting on the upper tension produces a balanced, even stitch without bunching, the mechanism of the tension adjuster may be worn and need either professional adjustment or replacement.
Very rarely, you may find the bobbin tension might also need adjusting. Take out the bobbin case, you'll see the tension is controlled by a small spring which has a tiny slot screw on it. Mark the exact orientation of the screw slot now, [ marker pen or tape] so you can put it back where it was if need be. If you have to to a adjust it, you should move that screw only a tiny fraction of a turn at a time.
Check bobbin tension - pull out a foot of thread and hold the end of it , with the bobbin case dangling. Shake the case up/down like a child's toy YO YO. If the bobbin moves along in reasonably even increments with each jerk, it's likely ok. Or you can pull it along and see how hard it is to pull. If the bobbin case won't move or is hard to slide, it is too tight. If it slides on the thread freely it is too loose.
Usually. clockwise turns tightens the tension, but check to be sure. One tiny adjustment at a time, it gets a bit tedious. You have to put the bobbin back in and try a few stitches after each adjustment to see if the bunching is getting any better. If it makes no change or makes it worse, put the screw back to the original position.
If you are handy and can find a repair manual for the machine, you may be able to adjust the upper tension mechanism yourself, it should not need special tools. Often for older machines the hardest part is finding another part to replace the damaged one.
Sep 29, 2014 | Brother Sewing Machines
My machine needs the tension adjusted, i believe...because while i am sewing the thread bunches underneath the fabric that i am sewing. help? *my needle is sharp *my thread is new
You have not got is threaded on top right. Do this test, rethread your machine with the presser foot up, pull thread, it should move smoothly, now put the presser foot down, pull thread, it should barely move. This seats the thread in the tension discs. See if that works.
Apr 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
Hello, I just purchased a used brother 170D and the thread keeps wading up underneath. Can you please let me know what the problem is Thanks, Glenda
It is more than likely your top threading, insert a new needle (flat side facing away) because it could have a burr or a slight bend in it. Now totally rethread your machine, with the presser foot up, then pull on the top thread, it should move smoothly, put the presser foot down, pull the thread, it should barely move. This procedure should seat the thread in the tension discs. If, this does not solve your problem, return the machine and get a new one. Good luck.
Mar 18, 2011 | Brother Sewing Machines
Bobbin tension is far to loose I tried adjusting the screw but no luck
Are you sure that it is not in your top threading instead of your bobbin? Try this test, totally rethread your machine with a fresh needle inserted (flat side facing away from you). Make sure that your presser foot is up (when threading and the first part of this test) , now pull on the top thread, it should move smoothly, then put the presser foot down, now pull the thread, it should barely move. This usually seats the thread in the discs.
You will find that bunching up of thread underneath is usually the opposite of what you thing, ie. top threading. Top thread issues are the bobbin causing the problem. Good luck
Mar 06, 2011 | Brother LS2125i Sewing Machine
The thread keeps bunching up underneath top looks good but bottom stitch is bunching up
Totally rethread and put in a fresh needle. It should work wonders, if not go to brother-usa.com and troubleshoot
Sep 06, 2010 | Brother Sewing Machines
How to use automatic threader on the pe180d embroidery machine
make sure needle is in the highest position before you thread
mary h
Jan 06, 2009 | Brother Disney PE-180D Computerized Sewing...
Needle won't move; something stuck/dislodged
Can you remove the bobbin? Sometimes when thread gets bunched up under the lower plate it will force the bobbin out of position. Try taking it out and cleaning any loose thread and lint from the area. Put a couple of drops of oil on the outside of the bobbin case and re-insert it. Make sure you lower the needle and pull the bobbin thread through to the top and back behind the needle before beginning to sew again.
Hope this works!
Zelma
Jan 18, 2008 | Brother XL-2230 Mechanical Sewing Machine
Brother Disney PE-180D Computerized Sewing Machine Logo
203 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
