I have windows xp and i am unable to install silverlight. it keeps telling me i need to uninstall the old silverlight but when i try it tells me it cannot find the file to remove it. any suggestions? i have restarted my pc and tried removing programs already ;(
    Scholar:
  • 156 Answers
It sounds like you have deleted the program files instead of uninstalling it. go to www.filehippo.com and there you may get the same version of silverlight and install it. then uninstall it from the add remove menu.
Posted on Dec 02, 2012
IrishDruid
  • 2712 Answers
SOURCE: How to uninstall Vista and load XP in Lenovo Y510 Ideapad
Several points:
1. Although you may prefer XP to Vista, it is probable that you are simply
more familiar with it. If you would give yourself some time to become
accustomed to Vista, you might find that you like it. I know I do.
2. You can't literally "uninstall" Vista, but if you want XP instead, you
simply do a clean installation of XP the normal way. That will format the
drive, removing whatever is on it.
3. Do you already have a copy of XP you want to install? Did it come with
your old computer? If so you need to be aware that OEM versions (such as
those that came preinstalled on computers) are permanently tied by their
license to the first computer they are installed on. If that's your
situation, your copy of XP is not available to be used on your new laptop.
4. Over and above the licensing issue in point 3, many OEM version of
Windows XP are BIOS-locked to the computer they came with, and you actually
won't be able to install it on a different one.
5. You should check with your vendor to be sure, but the warranty on your
new computer may be voided if you change operating systems.
6. Laptops often have special drivers they need for components within them.
Your new laptop undoubtedly came with all the drivers needed for Vista, but
it didn't come with the drivers needed for Windows XP. Finding and getting
the drivers you need may be a problem.
If I were in your shoes, I'd stick with Vista.
If you still want to uninstall:
The normal way to "uninstall" any operating system is to format
the hard drive and install a new OS of your choice.
After backing up any data you wish to transfer to the new OS
installation, simply boot from the WinXP Home installation CD. You'll
be offered the opportunity to delete, create, and format partitions as
part of the installation process. (You may need to re-arrange the order
of boot devices in the PC's BIOS to boot from the CD.)
HOW TO Install Windows XP
http://support.microsoft.com/default...B;en-us;316941
http://www.michaelstevenstech.com/cleanxpinstall.html
http://www.webtree.ca/windowsxp/clean_install.htm
Then the backed up data can be restored and applications re-installed.
You can even try a dual boot, where you have both Vista and XP on the same system. Click HERE for pictorial guide.
Posted on May 25, 2008
  • 93 Answers
SOURCE: I removed CA antivruse from my add and remove program .
Solution 1 :
go to control panel
click to administrative tools
double click services
find service related to CA and Stop it.
now try to reinstall ca.
Solution 2:
Download small program called "REVO uninstaller" and run it and then try uninstall this CA from that Revo.
Solution 3 :
go to "c:\program files\ CA" folder delete it. before deleting from the system tray exit from CA
then got RUN in Start menu.
In RUN type regedit
registry editor will open the try to find for CA and delete all keys in registry related to CA
Restart computer.
then try to reinstall CA.
Posted on Nov 17, 2008
djxtreme979
  • 151 Answers
SOURCE: Problem installing SystemSuite 9
do a search on the net for the file that is missing and install it. Then try uninstalling.
Posted on Dec 29, 2008
SOURCE: How do I uninstall omnipage se from my laptop? I
Use Revo Uninstaller. It will work like the Add/remove programs however it will forcefully remove the programs and also will let you remove its registry items of the Omnipage.
Posted on May 17, 2010
  • 4 Answers
SOURCE: a new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
Posted on Dec 09, 2010
How can get netflix to play on my labtop?
  1. Clear browser cookies
    Your browser may be referencing an out-dated or corrupted setting in the cookie file.
    1. Go to netflix.com/clearcookies to clear the Netflix cookie. This will sign you out of Netflix.com.
    2. Select Netflix Home, then Member Sign In to log back in and play your movie or TV show again.
  2. Restart your browser
    Sometimes restarting your browser can clear this issue.
    • Quit your browser, restart it, and play your movie or TV show again.
  3. Try another browser
    A browser extension, plug-in or add-on may be causing this error. Try playing your movie or TV show in another browser.
    • If you're unable to play your movie or TV show in multiple browsers, there may be a problem with the Silverlight Plug-in used by Netflix.com.
try this
You may be running an outdated version of the Silverlight plug-in, or the plug-in may have become corrupted.
To uninstall the Silverlight plug-in:Windows 8
  1. Quit all open browsers - including this window! You may want to print the following steps.
  2. Swipe from the right edge of the screen, then tap Settings. (If you're using a mouse, point to the lower-right corner of the screen, then clickSettings.)
  3. Select Control Panel
  4. Underneath Programs, select Uninstall a program.
  5. Locate and select Microsoft Silverlight
  6. Select Uninstall
Windows 7/Vista
  2. Click on the Start Button
  4. Select Programs & Features
  6. Select Uninstall
Windows XP
  4. Select Add or Remove Programs
  6. Click Remove
To install the latest version of the Silverlight plug-in:
  1. Navigate to the Watch Instantly home page and click play on any title.
  2. Follow the prompts to download and Install Silverlight on Your Windows PC.
if your using Firefox
From the black screen:
  1. Click the orange Firefox button in the upper-left corner of the browser window.
  2. Select Options.
  3. Make sure there is a check mark next to Add-On Bar.
  4. A bar should appear along the bottom of the browser window. In the bottom left corner of the bar, click the red stop sign.
  5. Click Disable on movies.netflix.com.
  6. Press the back arrow to return to the Instantly Watch home page.
  7. Try playing your movie or TV show again.
If disabling Ad Blocker causes you to see ads when streaming from Netflix, please see our Ads and Pop-ups When Streaming to Your PC or Macarticle.
Jul 19, 2014 | HP Computers & Internet
Whe i want to watch a movie it tells me i need to uninstall microsoft silver and reinstall still wont work?what should i do?
Uninstall Microsoft Silverlight.
Restart your computer
Install the latest version of Microsoft Silverlight
Or
Install CCleaner for https://www.piriform.com/ccleaner
Tools > Find Microsoft Silverlight and click Uninstall.
Registry > Scan for Issues > Fix Selected Issues > Fix All.
Restart
Dec 08, 2013 | Computers & Internet
I downloaded netflix, one month free and 7.99 was to come out if I decided to keep it at the end of the month but it was taken the next day and I was told my free month was up
Seems like you're having weird issues. Best thing to do now is probably contacting netflix directly. As for silverlight (I can only assume that's what you meant), switching to a different browser might get that solved for you. My favorite is Chrome, but Firefox, Opera and even the newer versions of Internet Explorer seem to do OK with most of what's on the web.
Apr 14, 2013 | Netflix
I can't get netflix to work. error message N8161
2/24/2013 Netflix Error Code N8161, Protection Error Problem became a recent problem on 3 of my five XP computers, one Home Edition, the balance are XP Pro. After trying uninstalling and re-installing Silverlight, all the adobe products and Media Player I finally resolved the problem by uninstalling the current Silverlight 5, restarting the PC and then and installing old version Silverlight 4. I had to search hard to find a site that both still offered it and that I trusted. Just don't let Microsoft Updates or Netflix demand to install Silver light temp you to update. Chrome insists on the Silverlight plug in update - DON'T DO IT. Firefox and IE8 seem OK, at least for now.
Feb 20, 2013 | Microsoft Windows XP Professional
Unable to install silverlight on xp
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 08, 2013 | Microsoft Silverlight 4 Step by Step
I can not uninstall silverlight
How to uninstall Silverlight Bellow are the steps to follow to uninstall the silverlight
1. Go to Start menu.
2. Go to Control Panel
3. Open Add or Remove programs.
4. Choose Microsoft Silverlight in Add Remove Programs Dialog box.
5. Click on Remove
6. It asks you for the confirmation.
7. Click YES to Uninstall the Silverlight
Aug 12, 2012 | Microsoft Windows XP Home Edition
I'm trying to upgrade a HP a530n from windows xp to windows 7. I keep getting- Error Code 0x80070002, Windows was unable to create a required installation folder. All windows xp updates are current. Any...
Does your computer meet all minimum requirements? Try the Windows 7 compatibility program before tryin to install and it will tell yopu what the problem is.
Apr 17, 2010 | Computers & Internet
Quicken 2004 Installing on Windows Vista
i got new window vista cd orginal to upgrade previous version
window xp that i download also use orginal cd for installation.
but my winamp player,webcam,live messager & mail was stop working when i double click on the icon.
i also try to uninstalling & install back,but still same problems
show stop working.......prompt on the screen.
can you tell me why and how could i troubleshoot this problem or repair it please.
Jan 19, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
