Question about Bower LCD Timer and Remote Shutter Release for Canon EOS 1C/3/1D/1Ds/1Ds MkII/1Ds MkIII/10D/20D/30D/40D/50D/5D/5D MkII/7D Digital SLR Cameras RCLC3R
How to use bower rclc3r
Need manual
Need help with my bower M POWER conversion lens
The dark halo, is caused, by the size of the lens. The convertor lens, is smaller than the front lens of your Samsung and blocking the light on the sides.
That is the halo you see. If you want a conversion lens for your Samsung, you need a bigger one.
Mar 21, 2014 | Bower MPower 45x Conversion Lens for...
The Bower SLY500PN High-Power 500mm f/8 Telephoto with T-mount attached to my Nikon D5200 shows 'nop lens attched'. What is the problem?
There is no problem. The lens simply does not have the electronics for the camera to detect. You need to use the lens in Manual mode (turn the mode dial to M). You'll have to set both the shutter speed and aperture yourself, without any help from the camera's exposure meter.
You can take a picture, look at it on the back of the camera (preferably with the histogram) and adjust the exposure accordingly. Repeat until you get a good exposure.
Jan 24, 2014 | Bower Sly500pn High-power 500mm F/8...
Problem conecting the Bower 650-1300.. to the camera.
What exposure are you setting? Try pointing your camera out the window during the day, with the ISO at 200, the aperture at f/8, and the shutter speed at 1/125. Don't worry about holding the camera steady, we're just trying to get the exposure. Does it still come out black? Try slower shutter speeds (1/60, 1/30, etc.). Any change?
Nov 20, 2013 | Bower 650-1300mm f/8-16 Manual Focus Lens...
My shutter release on the bowers battery grip does not work. Do I need to change a setting on the menu?
The battery grip is likely defective. Bower is not know for their high quality, but rather their afford-ability. If it is under warranty, I would recommend returning the unit and requesting a replacement from either the manufacturer or the retailer from which you ordered it. There is no setting in the menus to enable the vertical shutter release on the grip.
Thanks for choosing FixYa!
Feb 27, 2011 | Bower Vertical Battery Grip (XBGND40) for...
I have a bower lens no.05166 i need the lens model
Sorry, but it's likely that you can't trace it that way. 05166 probably just means it was the 5166th example of that particular model manufactured. Other Bower models might also have the same number. In any case, the data you need to consult is not available in the public domain.
I suggest that you contact Bower for advice directly.
Feb 26, 2010 | Bower FCC62 Lens
Where can i find a on line manual for a bower sfd926p flash gun
Are you looking for service or op manual?
What is wrong with your flash?
atdlee@betzero.com
Jan 16, 2010 | Bower SFD35C for Canon TTL Flash
I have 2 Nikon D80's and a Bower 724AF speedflash
Set the flash unit to full manual.
Aug 12, 2009 | Nikon Cameras
Washed out pictures using a Bower 724 AFPX flash
This is probably not the camera settings. Pentax k200D wilt only give auto-flash with just three of their own units. Sounds like you have the Bower set on Auto. Set the flash to Manual, and adjust exposure on the aperture setting with the body set to manual as well.
Note that several people have reported problems with Bower units on digital cameras (and not just on Pentax)
Mar 22, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Bower SFD35C Digital Autofocus flashgun
Yes, just go to this URL scroll down about half way and download the manual.
http://www.bowerusa.com/catalog.php?item=300|330
Nov 02, 2007 | Bower SFD35C for Canon TTL Flash
Bower LCD Timer and Remote Shutter Release for Canon EOS 1C/3/1D/1Ds/1Ds MkII/1Ds MkIII/10D/20D/30D/40D/50D/5D/5D MkII/7D Digital SLR Cameras RCLC3R Logo
264 people viewed this question
Top Bower Video Cameras Experts
Are you a Bower Video Camera Expert? Answer questions, earn points and help others
