Question about Samsung DA-E750 Wireless Audio Dual Docking System for Samsung
Function button not working
Cannot get the device to pick up any devices accept for 'line in'. Pressing the function button doesn't get the dock to cycle through functions.
Did anyone ever find a solution to this?
Posted on Sep 22, 2014
    New Friend:
I have same problem mine was a store demo. I just got off chat with samsungs website. In order to get out of demo mode you will need model, serial, and remote, mine did not come with a remote so im out of luck so far. Try going to samsungs website and chat they were very helpful.. Hope this helps!!!!
Posted on Dec 04, 2012
  • Ryan Sandberg
    Ryan Sandberg Sep 22, 2014
    Did you ever get a solution to this?
The guitar hero Wireless don't want to work at all I hit the Wireless button on my Xbox but it doesn't pick up the signal
I don`t own a exbox however many programs need to recognize and the function must be set to except the external device and make sure the correct batteries are being used some equipment wont work with certain types such as my mouse that wouldn`t work with a camera AA rechargeable battery but did work with a plain ever ready rechargeable.
Jan 31, 2013 | Video Game Consoles & Games
Turnon wireless
You have to hold the FN (function) key while pressing F12, that should work.
Jun 19, 2012 | HP Computers & Internet
The number button doesn't work for the address function
Try performing a reset on the device.
Also you may want to contact TomTom Support for assistance.
http://us.support.tomtom.com/app/home/?Lid=22&locale=en_CA
Nov 28, 2011 | Tomtom GPS
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
I can't use any USB, it needs a registration on my laptop.. but i don't know how.. help pls!
If you can't use any usb device, the usb function is disabled.
  • To enable the usb function you have to access the Bios setup of your Desktop.
  • By pressing Delete button, F2/F11 button or Esc button in order to open the Bios Settings.
  • During power on the button menu will show up (press the key right away before the Windows starts)
  • In Bios setup there are several menu. Check each of them until you found the settings for Usb Functions
  • If the Usb Functions is disable change it to enable
  • Then go to the Save Menu and Save to apply the settings you created. (Sometimes F10 button is use to save the settings)
  • Restart the computer
To check if the Usb Function is working in windows mode open:
Start Menu > Control Panel > System > Hardware tab > click Device Manager.
Under Device Manager
click the ( + ) sign in Universal Seria Bus Controller
You'll see all the Usb devices detected in your computer
Jan 14, 2010 | Computers & Internet
HP Photosmart 3110 All-in-one - Scanner function not working
Scanning requires two-way communication between the computer and the scanner. Usually the error that you describe above indicates an issue with the USB connection. First, make sure that you are not using a USB hub. Try a new USB 2.0 (A-B) cable that is under 6' long. Try using a different USB port on the computer.
If the problem persists, check the Device Manager to see if you have a USB driver problem. (For most versions of Windows, press the Windows key + X to quickly access the menu with the Device Manager.) Expand the section labeled Universal Serial Bus controllers and look for an exclamation point or an X. Similarly check for any issues in the Devices and Printers section of the Control Panel. The All-in-One should be listed as a printer and a scanner.
I hope this helps. If you are still having problems, please add a comment with the OS version on your computer. That can help identify additional issues that could be involved.
Apr 04, 2017 | HP Photosmart 3110 All-In-One InkJet...
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Craig mp3 player
Reset the Device
NOTE: THIS IS AN ADVANCED OPERATION. NORMAL USERS ARE NOT RECOMMENDED TO PERFORM THIS OPERATION!
Sansa e200 provides a Reset Function. Please note that you only need to use this function if the device does not respond for several minutes. The button is like a power down button of the device. You can turn off the device by using a reset operation, such as pressing and holding the Menu button for 15 seconds. Once you perform the reset function, the adjustments you made during last
30
Dec 27, 2007 | Philips GoGear HDD6330 MP3 Player
Remote code
Use the search function, but don't give up. It takes about 20 minutes to find the correct code.
Here are the instructions
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Sep 12, 2007 | Televison & Video
Samsung DA-E750 Wireless Audio Dual Docking System for Samsung Logo
181 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
