Question about Canon PC1061 Copier
How do fix system error E110 on a cannon PC1061
When i turn on copier and press start it makes this noies like a belt sliping then stop and show system error E110
  • 3 Answers
SOURCE: ImageRUNNER 1600 E100 System Error
if a little part of drum is broken the door of laser is closed. J am sorry for my english .
Mario. (Rome-Italy)
Posted on Feb 07, 2008
  • 11 Answers
SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Posted on Oct 01, 2008
iservice
  • 318 Answers
SOURCE: system error for cannon 1670f
Press the usermode star-the star just above the lcd display-and then # key,scroll with the arrows until clear is displayed press ok and scroll again untill ERR is displayed press ok,Swotch the machine off and on again.
Posted on Jul 01, 2009
  • 16 Answers
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Posted on Jul 15, 2009
canontech
  • 1219 Answers
SOURCE: how do i fixed system error e100 on cannon
How many copies do you have? If over then 55000 change the drum unit.
But it can also be the laser trouble.
Posted on May 04, 2010
Hi,please help me my machine showing error e00025-003 cannon ir5050
E000 the heater fails to heat
E001 there is an abnormal rise in temperature
E002 there is an error in the rise in temperature
E003 there is an error in the rise in temperature
E004 there is an error in the IH power supply/IH control mechanism
E005 there is no fixing web/there is an error in the detection of web solenoid connection
E010 there is a feed motor error
E012 there is a drum motor error
E013 the waste toner pipe is clogged
E014 there is a fixing motor error
E020 there is no toner in the developing assembly; there is an error in the detection of
developing assembly toner sensor connection; there is an error in the detection of
developing hopper toner sensor connection
E025 there is an error in the detection of toner feed motor over-current, there is an error in the
detection of toner bottle motor over-current, there is an error in the detection of toner
bottle motor connection
E032 the counter of the NE controller has malfunctioned
E061 there is a potential control error/there is an APC error
E100 there is a BD error
E110 there is a polygon motor error
E121 there is a controller cooling error
E196 the EEPROM is faulty
E202 there is an HP error
E225 there is an error in the intensity of light
E227 there is an error in the power supply (24 V)
E240 there is an error in the communication between the main controller PCB and the DC
controller PCB
Jul 12, 2015 | Cannon Office Equipment & Supplies
How to fix cannon mx320 Check ink U162 error
For many Canon printers, you can clear the U162 error by pressing and holding the Stop/Resume button on the printer. (You may need to turn off the printer and turn it back on. Then press and hold this button when the error appears on the LCD screen.)
This error can mean that the ink system is having problems pulling ink through to the nozzles or that the printer believes that the cartridge is empty/too old. You can try a deep cleaning To access this, press the Menu button several times until Maintenance is displayed. Then use the left or right arrows to navigate to Deep Cleaning and press OK. Wait until the process is complete (1 1/2 minutes). The second issue is sometimes related to the printer's firmware program that checks the cartridge identification information.
I hope this helps.
Apr 05, 2015 | Cannon Office Equipment & Supplies
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Cannon pc1061 error 100
there is no error code `100'. The error codes that show on the display start with an `E', then three numbers, ie: E001.
Apr 02, 2014 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
How do i fixed system error e100 on cannon
Mar 15, 2010 | Canon PC1061 Copier
System error e225
Try this With the Printer On:press and hold the Stop/Reset button for a full 6 seconds.
Release the button. Restart the Printer and try to print again.
Let us know if you need further assistance.
Thanks for contacting Fixya.com
Jan 14, 2010 | Cannon i70 Printer
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Error code on canon pc 1061 of E110. Can someone tell me what this is? Thanks Kath
Not sure right now, but it will tell you to turn off and back on. Make sure noone has reinstalled the packing thumb screw in the top left rear side cover. Then to reset fixing error codes like E-000
Press additional functions key
press # key
press + key until the display reads #7
press set
press + key until the display reads #4
press set
press - key for yes
then unplug it wait a couple seconds and plug it back in
Keep this for future reference and please rate my help
Thank you
Bob
Mar 04, 2009 | Canon PC1061 Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
Canon PC1061 Copier Logo
old marine
old marine
