Question about Boston Acoustics Recepter Clock Radio
Were can I get my radio fix
Can't change the station I think it worn
  • Stephan Whittier Dec 04, 2012
    I don't know what more I can add I can't change the station I belive it neen a new control I'm just trying to get a it fix
Why wont my radio work?
Think you need the advice of a car
stereo sound place or go to a forum
on the internet that folks like yourself
play around with those vehicle changes
From my perspective, I fail to see how you
could add to or change anything on today's
vehicles, because of the computer systems
the can bus & data stream,& security on radios
I would forget it
Anything to do with sound will have to be a clean new install,
stand alone from the vehicles systems
I would have a dealer fix your factory system, then add
something you want ---NOT-- tied to the factory options
Jul 17, 2014 | 2007 Toyota 4Runner Limited
I have a 2005 Cadillac STS. The sound cuts off on my radio/ cd player after a little while if playing. I don't think its the speakers or a loose wire since the sound comes back as soon as I change the...
no quick fix there. Dealer would be best option. There have been many issues with the STS, XTS CTS, and ATS radios.
Most problems relate to XM radio, but the issue you mentioned seems to lean toward the "replace it" path.
Best to check with a dealership to see if there is a recall.
Dec 07, 2012 | Cars & Trucks
Changing battery/radio code
Cycle through the various menus...I think there's a choice you have to enable to get the station info to show. The station freq should, though, like 104.5 on the fm band. Make sure you've selected a broadcast station and not aux input, for example.
Jan 18, 2018 | 2008 Honda Accord
My radio doesnt work- the radio station is displayed on the screen, however, not able to change station or listen to soun on the speakers. I called my Nissan Dealership and they suggested it being the...
Sounds like it's inside the radio, unless they mean an in-line fuse holder on the power wire leading into your radio. I would ask them again.
I don't think removing battery would help, but no harm in trying. Just take off your negative cable from battery, and it will be totally "as if" removed.
Oct 20, 2011 | 2006 Nissan Maxima
XMp3i is stuck on "powering
Bad TSOP flash chip. No way to fix without disassembling, removing the flash chip, and placing a new flash chip on it. Doing so requires a donor radio (with another issue), and will change your XM Radio ID. You'll also need to have a hot air (or IR) rework station for desoldering the old chip, and a soldering iron for placing the new chip on the radio.
I'd say give pioneer a call since it's a design flaw, and a VERY common issue. My best guess is that it's caused by excessive heat & defective chips.
Aug 07, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
Factory radio recieves am stations only no fm stereo
get a new one as they are cheap these days!
& not worth the labour costs to try & fix them anymore!
Cheers Rob
Jul 20, 2009 | 2002 Chrysler Town & Country
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
Speaker Pop when i turn on or change tune on radio
the speaker is probably worn is it factory is the speaker wires crossed need more detail
Mar 09, 2008 | Sony CDX-GT710 CD Player
Boston Acoustics Recepter Clock Radio Logo
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
