Question about Makita Tools & Hardware - Others
Wiring diagram for makita 82mm planer 1902
Switch wiring diagram
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: FITTING DETAILS FOR MAKITA PLANER BLADES
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
Posted on Mar 09, 2009
  • 52 Answers
SOURCE: were can i buy a drive belt for a 1902 makita hand
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/1902
I've had really good luck with Tool Parts Direct. They send emails when something ships and are upfront about the parts they order direct from the manufacturer.
Part Number 225071-8 is $10.79 and ships in 10-14 business days.
Posted on Mar 08, 2010
  • 10865 Answers
SOURCE: I have a Makita 1902 motor problem
Hello. You are going to have to get inside to do a thorough inspection followed by a test run. Begin by unplugging it and then removing the blades. Check the play in the drum, and the clearances to be sure that the drum is still centered. It could be that a bearing has gone bad. If the drum still rotates freely, plug it back in and see if it operates smoothly, without sparks. If it does, take a close look at the blades as they are actually thin and delicate and can be easily warped. Joe
Posted on Mar 30, 2010
Testimonial: "some help but still have problem. thank you"
I have problem finding a grooved belt for
This is a link to the company that sells the planer, perhaps you could contact them about parts!
http://www.made-in-china.com/showroom/colin2006/contactinfo/contact.html
Oct 03, 2013 | Makita 1902 4Amp 3 1/4 Inch Hand Held...
How to replace brushes on a makita 1902 planner..?
Hello. I have found the link to your product's manuals. The part's breakdown is quite detailed and should be able to help you out. Failing that, under the "services" tab at the top you will find the contact info necessary to speak to Makita's tech support. Hope this helps, if so - please rate this a four-thumbs up. Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=801
Apr 05, 2011 | Makita 1902 4Amp 3 1/4 Inch Hand Held...
How to install 3 1/4 planer blades into makita planer model 1900b
go to Makitausa.com and download an owners manual and it will have directions on how to do this. Let me know if you still have problems.
Jun 28, 2010 | Makita Planer Replacement Blade, 3 1/4"
Mar 30, 2010 | Tools & Hardware - Others
Were can i buy a drive belt for a 1902 makita hand planer
Mar 07, 2010 | Makita 1902 3-1/4 inch Planer, 16000 RPM,...
Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
Mar 08, 2009 | Makita Planer Replacement Blade, 3 1/4"
Tools & Hardware - Others Logo
37 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
