Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
SYMPTOMS: Rising Black Horizontal Area and Right Side slight Pincushioning (bowing) of the picture. Clears up after the TV warms up for about 12 to 20 minutes. DETAILED DESCRIPTION: The sound and all other functions are working fine. The picture has a Black Horizontal Area (I will call it "BHA") that spans the full width of the screen. That BHA appears from the bottom of the picture and then rises up the screen, until it gets about 75% high, and fades when it gets to three quarters (75%) from the bottom. That is, the top 25% of the picture is completely unaffected and always looks fine. The BHA looks like a completely blacked out area, surrounded top and bottom with finer and finer horizontal black lines. So it looks like the fine black horizontal lines are concentrated in the middle, and spread out more on the top and bottom of the BHA. This BHA is about 25% of the screen's height at first, and gets smaller and smaller as the tv warms up. The BHA rises to one quarter from the top of the picture and completely fades, and then rises again from the bottom and again fades and repeats this as the set warms and the BHA gets lighter until it disappears. THE BHA seems definitely related to the slight (1inch) black pincushion bowing in of the screen on the RIGHT HAND side of the picture. That black bowed area runs from about 3 inches from the bottom of the right hand side, to about 5 inches from the top of the right hand side. The BHA, when the tv is almost warmed up completely, seems to stop at the top of the bowed in area, so I think these are both symptoms of a single/related issue. The picture is showing all the time, while the BHA is moving up across the screen. Any ideas about this?
  • Anonymous Mar 12, 2014
    hi i have a panasonic 74 cm tv.It was working fine then all of a sudden the screen shrink from top to bottom and side to side now the picture is small and not clear
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Posted on Dec 05, 2012
  • chris59492
    chris59492 Dec 05, 2012
    Thanks for the helpful analysis. I have a perfect picture, after it is powered on for 12 minutes or so, as stated. Notice when the volume is turned up high, then a loud noise through the speakers will cause the picture to "improve", that is, for the blackened area to bounce with the sound to take up less of the screen, and then bounce back to its former size (analogous to "tapping" the TV case hard, I suppose). For now, I will live with it, because even the pincushion is very minor, almost unnoticeable, and only on one side. .
megatronix
  • 57 Answers
SOURCE: white horizontal lines at top of picture
Yes, definitely worth fixing. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor (no more than USD4.00 in price) usually gets it working perfectly again. If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Posted on Jan 18, 2008
SOURCE: White lines accross top of screen on our 27 inch Toshiba,
My Toshiba required replacement of two of the vertical filters/capacitors. Doesn't take long and the parts are inexpensive, but requires a repairman.
Posted on Sep 12, 2008
  • 556 Answers
SOURCE: I have thin white lines that run across the top of
sounds like bad capacitor in vertical circuit. It's not a hard fix if you know where to look. Repair shop should not have hard time repairing it.
Posted on Aug 10, 2009
  • 65 Answers
SOURCE: I have a 32A14 Toshiba TV. At full screen, the
you have to take in affect on how old is the tv if you have had it a few years then the screen is going out and will only be a matter of time before it goes all the way out and you will be buying a new one if it not old and its one of the newer flat panels then its the signal that the tv is receiving if its hooked to a digital antena then you only get max of 720 from it on certain channels no matter if the channel or channels are showing hd with out a hd source your tv will not show better then that i have a 42 inch hd flat panel and use a antena and the best i get from my hd broadcast channels certain times will i get true hd like when the news is showing or when one of the series that was filmed in hd is on other then that i only get a 720 picture instead of a 1080 most commercals are not film in 1080 but in 720 max and i dont know why makes no since
Posted on Aug 28, 2009
  • 458 Answers
SOURCE: CRT TV, horizontal line appears, got sound, no
You have a poor solder connection in the frame output stage. If you have a soldering iron, remove the back cover & look for an IC that will be attached to a metal plate that acts as a heatsink. Carefully re-solder the pin connections on this IC ensuring you dont leave any of the pins shorted together. If you spot any other connections around about this area also looking dry, then resolder them as well.
Posted on Oct 19, 2009
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Cold power up, colored vert lines, (rainbow) audio perfect. When warms up, pix returns, slight black horizontal lines in top forth of screen which go away when warmer.
All Plasma and LCD ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, Good luck in rectifying the problem.....
May 17, 2011 | Sanyo DP46848 LCD TV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Picture is wavy and has black vertical and horizontal band
The following are supposed to be checked on the horizontal and vertical,
the supply of the sawtooth oscillator
eletrolitic capacitors near a line transformer
zener diodes
and driver transistor a round that area.
Apr 08, 2009 | Toshiba 35A44 35" TV
Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
Mar 10, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical problem,
chek tje vertical deflection yoke winding and the socket. readjust the vertical height control.hope this will help.
Feb 05, 2008 | Samsung TXM3096WHF 30" TV
Pincushion Problems
check the cap that couple the horizontal transistor, this could be bad replace the flyback.all caps and transistors in that circuit should be cheked.good luck.
Apr 03, 2007 | Proscan PS27108 TV
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
