Question about Kenmore 21.9 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Water on floor in front of kenmore sidebyside opened door water in the ice mold was very very warm almost hot too the touch
Model 50564992
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 02, 2012
  • 2 more comments
  • kirk d kramer Dec 02, 2012
    model # 106-50564992
  • kirk d kramer Dec 03, 2012
    water in ice mold very very warm almost hot to touch/ turned off water supply to maker/ turned off power to frig 5 minutes / plugged back in turned ice maker and water supply back on. Ice maker has not recycled yet.
  • Richard Roth
    Richard Roth Dec 03, 2012
    OK, you have a faulty ice maker mold that is heating constantly. You can replace just the mold part but I think the whole unit will need to be replaced. Here is the mold to order.http://bit.ly/Ty4nNe Here is the complete ice maker if you should want to order it.http://bit.ly/Ty4GHO For the less than thirty dollar difference, I would get the whole unit.
  • kirk d kramer Dec 04, 2012
    I had another ice maker took mold off and put in on one from frig. I also made the ice maker cycle by jumping the T and H ports. It went throgh cycle. I suppose I need to wait for water to fill mold, or is there a jump for that also
Kenmore sidebyside no water or ice replaced valve and icemaker still nothing
The first thing I woulb check is the water filter itself. Water comes into the machine via the water valve, and from the valve it goes to the filter and the to its respective area, dispensor or ice maker. It's a very rare case that both the ice maker and water in the door stop working at the same time other than the filter being bad,
May 10, 2012 | Kenmore Side by Side Refrigerator
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Kenmore Model: JSI-23, two door (water/ice)
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 22, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
I have Kenmore frostless 25 with an ice and water dispenser in the door. It does not makes ice, but the water dispenser works fine. I could hear the ice maker switch bar moves up and down in the ice...
Most times it's the water control valve on the rear of refrigerator and near the floor. And you can test the ice maker by filling with water. Let it freeze and if it dumps the ice and does not refill then the water control valve. If the water freezes and nothing happens the the ice maker is the problem. If you had your model number I could tell you part numbers. Anyway try that and let me know your findings. Kenmore uses a model number like 312.54689 for example found on front near floor and behind the fresh food section door. Let me know, Thanks Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
The door seal contact surface is hot to the touch.
ther so pose to be a switc if none that for hummit
Jan 17, 2009 | Kenmore 53082 / 53084 Side by Side...
Kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore sidebyside
you are probably getting an ice build up on the evaporator and the drain also blocked with ice. take back cover off freezer and melt any ice off with careful use of a hairdryer. make sure the drain at the bottom of evaporator if free by pouring a little water down it. if blocked with ice, free with hot water and parience. if fault reoccurs, you have a fault on defrost system
Apr 17, 2007 | Kenmore 52673 Side by Side Refrigerator
Refrigerators Logo
343 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
