Question about SINGER 7470 Sewing Machine
Difficulty reinstalling needle plate in Singer Confidence 7470
Took plate off to clean and cannot reset the plazte properly
  • Singer Master
  • 1,564 Answers
Look at page 80 of your manual.
There's a little finger on the left of the plate that fits in the corner.
Posted on Dec 04, 2012
  • Helen f moon
    Helen f moon Apr 07, 2016
    Very helpful could do with a video on how to clean and replace or items
  • 46 Answers
SOURCE: singer 6038 needle issues
That sounds like the needle is not in straight or is bent.
Posted on Oct 24, 2008
  • 46 Answers
SOURCE: Singer Confidence 7470 does 3-4 stitches, then beeps and stops
ring up or go to where you bought it from. They should be able to tell you.
  • 23 Answers
SOURCE: Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Posted on Feb 27, 2009
bargainbox
  • 1388 Answers
SOURCE: The machine needle is no longer in the correct position
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Sep 01, 2009
  • 980 Answers
SOURCE: my needle is hiting bottom plate on singer 413
Good machine, you may need to retime it, email me and I will attach timing instructions
drivewithken@blueyonder.co.uk
Posted on Nov 03, 2009
Hi, I have a singer confidence 7470 sewing machine and the needle keeps hitting the bottom of the bobbin. I need to know how I can adjust the needle.
Try a brand new needle. If the old one is bent, that could be why it is striking. If the new needle doesn't resolve the issue, the machine most likely has a timing issue. You can search for multiple web sites and videos for discussions and instructions for sewing machine timing issues. Or you can take it for service.
Oct 04, 2016 | Singer 7470 Confidence Sewing Machine
My sewing machine jammed the fabric into the bobbin case and now it won't sew the needle hits the plate under the bobbin case can I adjust this myself
Here are some videos that may help. If not, search the internet for thread jam.
How to Fix Thread Jam Sewing Machine
When Thread is Caught in Sewing Machine Sewing Lessons
https://www.youtube.com/watch?v=tDcBUR0PcyA
If you get it unjammed, be sure to install a new needle as the old one is probably damaged. If there are still issues, the machine's timing may be off and would need professional service.
Oct 23, 2015 | Singer 7470 Confidence Sewing Machine
I bought my machine last yr & just started using it 2 days ago. Now it's acting up? The needle is hitting the bobbin plate. I've notice this is a common thing to happen to other confidence owners.
Sounds like the needle is bent. If it hits the plate just once it will blunt the needle and not sew properly. Failing that, the machine's timing may be off. Was it shifted about a lot in the year it was left in the box?
Apr 18, 2015 | Singer 7470 Confidence Sewing Machine
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
I was sewing with my Singer Confidence 7470 when it suddenly would not pick up the bobbin thread. I changed the needle, re-threaded the machine, and checked that the bobbin case is clean and in correctly...
Yes, try looking very closely at the needle assembly. Make sure the new needle is loaded with the flat side against the arm that holds it. If the machine is only a few months old, it's probably under warrantee. There should be a number to call on the serial plate. If all else, call the store you purchased it from. Sometimes they have sales people who are well versed with their equipment and can help you but I bet the needle is facing the wrong direction when you replaced it. Find any broken pieces of needle and remove them too. Look with a flashlight. I hope this helps!
Sep 22, 2011 | SINGER 7470 Sewing Machine
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
May 11, 2011 | SINGER 7470 Sewing Machine
SINGER 7470 Sewing Machine Logo
134 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
