SOURCE: d card reader writer
Did you purchase the 4D reader writer kit? If so, once you've loaded the driver for the reader/writer box, you go to the "organizer", select a design and "send" to your box. If you purcased new, the directions are pretty straight forward; otherwise, you may want to contact your locat Viking dealer for assistance.
SOURCE: 4D Extra and Reader/Writer
QUESTIONS:
is the reader writer a USB or parallel cord? (they have both.
If it's USB you need the 256K card otherwise the regular card, and yes it can work you just have to have the right card for your reader writer.
SOURCE: I need the driver installation for my reader/writer d-card
Drivers are on the installation disk. 3D will have it on cd#1 and 4D on the dvd. With the disk in the drive, plug the dCard reader/writer in and use the "add new hardware" wizard to allow the drivers to install automatically. Now,either repeat this for each usb port or remember to always plug in to the same port.
SOURCE: I had the Husqvarna Viking Rose machine with the
Your software cannot connect through a usb port if it originally connected through a printer port. The usb option came about in later versions of husqvarna's software and there is no patch that makes it work through a usb hub. Her only option for running your old software is to have an older computer with the parallel port for the printer style cable.
SOURCE: Reader/Writer for Viking Rose-Do I have to replace?
I would reccomend that you go to the dealer and think about upgrading your machine, I used to have a Rose. I upgraded and am happy I did, I think you can get the 4D with some of the new machines...if not deal for it with your new machine.
