Question about Jwin JD-VD145 DVD Player
When powered up, dvd tray will open and close at will.
The remote's only working button is setup. This player came new out of the box and never used.It was a gift.
  • yoka vandenberg Jun 08, 2007
    Hi I tried the region code and no matter what region code, this dvd player keeps opening and closing the dvdtray at will and in a constant pace.Holding down on the remote play button will keep the tryy door closed but you can hear the clicking going on to open and close the door.
    as this was a gift with an subscribtion to a national newspaper in canada I am ready to give it the boot!
    Problem Solver:
  • 22 Answers
Maybe you can try this for setting-up the region code: 1. Open the disc tray 2. Press 9, 7, 3, 5 3. Change the region code to "1" for USA
Posted on Jun 08, 2007
  • Ken Christensen
    Ken Christensen Jun 09, 2007
    I've looked around for you, here's some ideas:
    The eject button may be stuck or shorted.
    The door-sensor switch may be messed up, not knowing if the door is fully extended or closed.
    I don't know if you are thinking of trying to get them to send you a replacement. If you are somewhat "techy", you could open up the unit and check the tray door
    switch(es) and the door switch & eject-button wiring, but will that invalidate any warraty you might have(?)
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
Unlock toshiba SD800ky
2. Press the Open/close button on your remote control to open the drive tray; remove any disk and leave the tray open.
3. Press 2,4,0,3,9,6,0
4. Press 9 for multi-region playback. You will see a "9" appear in the upper right hand corner of the TV. DO NOT Press Enter button on your remote control
5. Press the Open/close button on your remote control to close the drive tray, and power off the DVD player before it says "no disc".
6. Power the DVD player back on and it is region free !!! Woohoo !
Jan 09, 2010 | Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Dvd8723uk curtis dvd player wrong region
region code solution as per
http://www.dvdcodes.net/newCodesAZ/codesD/DigixMedia/DigixMediaHT-1056A.php
Power up the player and open the tray. With the tray open, hit the setup button and then 0000 and then the "Up" button.
On the Setup menu, go to Version and hit enter. Go to region code and change the number to 0 for region free and hit setup again to save.
Or
Press the SETUP button. The setup menu appears.
Press ZERO on the remote control four times - 0000
Press the CHAPTER FORWARD button - the one on the bottom right of the remote control unit that looks like a double arrow with a bar.
A new menu item appears, "Version". There is a REGION option you can select, and this can be set to zero "0" for all regions. Once you see its set to region 0, press SETUP to exit, close the tray and power off. When you power up again, its region free. RCE disks work fine in this unit.
To recap - open the tray, press setup, press 0-0-0-0, press Chapter Forward, select Version, choose 0 for region free, press setup again.
Or
1) Turn on the System
2) Open the tray
3) Press "setup" button
4) Press four times the number "8": 8888
5) Press the "Next Chapter" button (>>|)
6) Appear a menu called "Setup Factory"
7) Select with the cursor movement key "Region All"
8) Press "setup" button to save de changes.
Sep 09, 2008 | Digix HT1056A DVD
Fix for DVD Player
Try making DVD player multiregion
Or
Or
2) Open the tray
Aug 31, 2008 | Digix HT1056A DVD
Curtis region error
This region code solution as per
Or
Or
2) Open the tray
Aug 17, 2008 | Digix HT1056A DVD
DVD8723UK
this region code solution as per
Or
Or
2) Open the tray
Jul 11, 2008 | Digix HT1056A DVD
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Does not respond to remote control
After power on the dvd, open the tray and put any video dvd in and close it, wait for about a minute, then press Setup or any button on remote control, if it work then need to replace with the new battery CR2025.
Jan 27, 2008 | Cyberhome DVR 1600 DVD Recorder
Jwin JD-VD145 DVD Player Logo
100 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
Sheldon Dedek
Raj Patel
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
