Question about Xerox DocuMate 252 Path-Through Scanner
Xerox DocuMate 152 broke output tray - Xerox DocuMate 252 Path-Through Scanner
3 Suggested Answers
  • 7 Answers
SOURCE: Xerox Documate 152 - Scan quality is now V.BAD!
I would go to Xerox.com and look up their knowledge base. Here is a copy of data from their site related to this problem:
Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
The following solutions can help resolve poor scan quality.
Solution 1 - Adjust the scan settings
Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
  • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
  • You can also try adjusting the brightness and contrast
  • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
Solution 2 - Clean and Calibrate the scanner
Note: Calibration only applies to sheetfed scanners.
Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
Posted on Jan 10, 2010
dlopez762
  • 34 Answers
Hello.
I am a Support Engineer with Xerox Scanners.
I am sorry to hear that you are having trouble with your scanner. The problem is either the scanner, power supply, or outlet. I know that probably sounds exceedingly obvious, but I would recommend checking each individually.
If the power brick has been plugged in for a while, see if it is warm. If the brick is cold to the touch, it may not be functioning or the outlet it is connected to may be no good. Try turning the scanner on using the power outlet in another room (on an outlet that you know works).
If it still won't turn on, then you have eliminated the outlet from being the problem, and you can focus on the hardware. That leaves us with the scanner or the power supply. If the power brick was cold, and you know that both outlets work, I would recommend getting a replacement power supply. If it was warm, the scanner is more likely at fault and should be replaced.
In either of the last 2 situations, if the scanner is in warranty, you can call us for a warranty replacement (of which ever part needs replacing). Otherwise, you can call us to discuss your replacement options.
Replacement power supplies can be ordered online here.
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Posted on Sep 28, 2012
How do I replace the white strip inside the documate 152 scanner?
warning
don`t try to replace it. If it make a problem try to treat it in it`s place
Jun 23, 2014 | Xerox DocuMate 152 Pass-Through Scanner
Xerox documate 152 scanner - won't scan
Hello.
If scanner is stopping @ 98% is normally due t oa communication problem. Make sure USB cable is conencted to rear of PC ,and cable is no longer than 6ft..
We also have an extensive support site and knowlegebase at http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410bsat4ube4gblqiaaaaasuvork5cyii=.
Regards,
Oct 30, 2012 | Xerox DocuMate 152 Pass-Through Scanner
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
I have been using my Xerox 152 scanner for a year
Okay, I brought on my feminine side and read the manual. I cleaned the rollers etc and located the extra 'pad assembly ' that came with the scanner. So I hope I am all set for awhile.
Jan 10, 2010 | Xerox DocuMate 152 Pass-Through Scanner
Jul 08, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Xerox ducuMate 152, password recently does not work
You could reset the device, that usually resets everything - the downfall is that you will have to re-configure everything.
  1. Right-click on the One Touch icon and choose Show Hardware from the pop-up menu.
  2. The Hardware Properties dialog box opens and shows information about your Xerox DocuMate 152 scanner.
  3. Click the Properties button.
  4. To return the scanner to its factory settings, click Reset Device.
  5. Click OK to save the changes and close the dialog box.
If this doesn't fix the problem please post a comment, I will do some more research into it.
Mar 20, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Xerox DocuMate 252 Path-Through Scanner Logo
78 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
