Question about Sewing Machines
I am trying to sew a Abby script font "B" 4 inches high and on the right side of the letter it will not sew. It sews one stitch stops then again
It like I cant so more than 2 1/2 high
  • Sewing Machines Master
  • 1,564 Answers
Make and model of your sewing machine might help.
Posted on Dec 04, 2012
  • 8 Answers
SOURCE: beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Posted on Apr 27, 2008
SOURCE: singer futura CE-100 4 blinking reds lights
Hold onto the thread that is coming out of the needle, and pull on the top of it (by the spool of thread) to tighten it. Then it should work fint.
Posted on Mar 02, 2008
SOURCE: EURO PRO 6131 Sewing Machine not maintaining stitch
http://www.sewusa.com/Sewing_Machine_Instruction_Manuals.htm
Posted on Sep 04, 2008
dupina
  • 110 Answers
SOURCE: Persistant beeping
Look for the buttonhole lever, just behind the needle threader lever. Pull it down and push it up again. The machine gives a warning message if you want to sew and the button hole lever is down. Good luck!
Posted on Nov 04, 2008
  • 68 Answers
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Posted on Feb 25, 2010
Straight stiches great. select any other stitch and it stitches about an inch and then stops
Test: With straight stitch and needle on left side sew.
With straight stitch and needle on right side sew.
Does one of the two sew and the other not sew?
The reason is the timing of the needle and bobbin are not set right. In other words it is in need of timing from a repairman.
Dec 12, 2015 | Singer 8763 Curvy
How do i get sewing machine to stop showing code 6 when I have done everything by the book. sews perfect stitches for about an inch then code 6 and locks again?.
Since it is a computer,maybe try unplugging for about a minute and plug back in and turn the machine on. See if the code is cleared. hope this helps
Oct 02, 2014 | Brother Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Lever is stuck in reverse
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
I have a Kenmore 19606, I have never own a machine that does embroidery stitches, the pattern of the stitches shows on the wrong side of the fabric not the right side. Is this suppose to happen? If not how...
Not sure if you are doing embroidery w /a hoop and all, which I don't do but I have lots of decorative stiches . Ytp lacing some tear away interfacing below the fabric you are going to sew. Most stitches come out top to bottom. Say I have an alligator option. Image will be about 1 1/2 inch , Try it on a piece of scrap fabric to start. I used muslin and the tear away bnacking to stabilize the design on lettering and patters.Also use good thread. I like Guttermans. Coat and Clark / Sulky are very fine and snag and tear easily. Good luck. Keep trying. The design you sew will show on both sides , so if you do not want that you will have to add another level of fabric to the backside after completing the design. Hope that makes sense.
Mar 29, 2009 | Kenmore 19606 Computerized Sewing Machine
SEWING THE ALPHABET
The machine will feed the material you only need to guide it gently and it will sew the letters sideways.
Jan 12, 2009 | SINGER 7470 Sewing Machine
Sewing Machine Stops
this sounds like its set for zippers check settings!
Dec 09, 2008 | Husqvarna Sewing Machines
Just made a floppy disk from quick font plus and now
1>Turn on machine
2>touch PROG (menu on top)
3>insert desired font disk
4>touch floppy icon
5>select font/font size
6>touch each letter consequtively until speeled (use "_" in menu for a space between words/names.
7>When done, touch REP (menu on top)
8> then start to sew by pressing start/stop
Nov 15, 2008 | Husqvarna Designer I
Singer futura CE-100 4 blinking reds lights
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Dec 23, 2007 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
