Question about Garden
Water leaking out of weep hole
There is water leaking out of the weep hole at the bottom of the pump (approximately 2 to 3 cups a minute. I took the pump apart and it appears that the 3 pumping pistons have a hole located on the cylinder. These holes all connect to one another through the milled out portions of the water pump. They all come together and drain out of the bottom of the pump. These holes are there for a reason, but I can not seem to figure it out. The only way water can get there (from what I can tell) is leaking by the pistons, between the piston and cylinder, and coming out of the hole, eventually to the weep hole at the bottom. I hope my description was good enough. But is water SUPPOSED to come out of the bottom weep hole? is it used for cooling purposes?
  • Trey Cox Dec 02, 2012
    I forgot to mention that other than the small leak, the pump works great! the pump is operating at the correct pressure and flow-rate.
Treefrog15
  • 127 Answers
SOURCE: water leaks from two locations on my Badger 5, 1/2 hp disposal
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
Posted on Dec 23, 2008
  • 6 Answers
SOURCE: quiet series 300 maytag water won't drain
This is more of a tip than a solution as I am having a partial-draining problem and have discovered by accident how to have the Quiet Series 300 "drain only" (which is not an option on the control board and the manual doesn't seem to address this).
TIP 1:  The "drain-only" function can be activated by selecting "Rinse Only", pushing the "Start" button, and then pushing the "Start" button again (which cancels the start).  This activates the drain pump which will drain any remaining water.
I think I might have a partial clog below which I have been able to access so far as I removed the top drain cover (3 --I think the term is star screws) and used a screw driver to take debris out from between the drain blades.  This improved things but didn't solve the problem. As of now, I just completely drain the machine by cancelling the "Rinse only" as described in TIP 1 above.
TIP 2: If you don't have a star or hex screwdriver, you can pick up one very cheaply at a discount store (e.g., Odd Lots, Marcs, or even some Dollar Stores).  Check out their tool section.  I've bought a bunch of stuff, sure it is not the highest qualilty, but how often do you use most of your tools?  I bought the star-screwdriver set for about $1-2 and will probably use it 10-20 times in my lifetime. I bought it to change a bulb in out minivan and have now used it again.  In my cynical opinion, more and more companies are NOT using straight or phillips-head screws as a way to force many to use their repair services.  I'm not a professional, just a guy who's using the internet to feel his way around in the dark.
Posted on Mar 25, 2009
co7196
  • 3433 Answers
SOURCE: 2003 crf 450 leaking coolant from hole from the bottom of the case under the water pump. What does this indicate?
It means your water pump seal is seeping at this point. Eminent failureportended. Replace water pump. Seals on pumps usually fail because of bearing wear, so this is a precursor to pump shaft failure. Good luck
Posted on May 27, 2009
  • 3567 Answers
SOURCE: Kawasaki KX250F 2006 model coolent leak
There are two seals on the impeller pump. Replace the seals an the leak is stopped. Put in a new cover gasket as well.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx Click on the "ENGINE COVERS" tab.
A “very helpful” rating for this answer? Thanks!
Posted on Jun 20, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
Water pump leaks out weep hole in water pump when plugged in otherwise doesn't leak! Does this mean water pump seal is out?
Yes. Water pump seal is leaking. The weep hole keeps the water from getting to the bearing in the water pump.
Dec 19, 2016 | Cars & Trucks
Weep hole
THE WEEP HOLE IS THERE TO TELL YOU THE BEARING AND OR SEAL IS GOING BAD.NOT A GOOD IDEA TO PLUG IT.
Jan 03, 2014 | Cooling System for Kia Rio
Water leakage
COOLANT (COLORED?) CHECK THE FOLLOWING:
1. ALL RADIATOR AND HEATER HOSES FOR LEAKS OR LOOSE CLAMPS
2. LOOK FOR A CRACKED OVERFLOW BOTTLE
3. MODERN WATER PUMPS CONTAIN A "BOTTOM SIDE" SMALL WEEP HOLE THAT WILL START LEAKING WHEN THE SEAL AND BEARING ARE FAILING
4. ALSO CHECK RAD CAP, RADIATOR SIDES AND BOTTOM TANKS FOR LEAKAGE, AND WEEPING AROUND THERMOSTAT COVER
Dec 20, 2013 | 2004 Mustang Factory Wiring Diagrams
Leaking coolant and antifreeze
Have you checked the water pump? It has what is referred to as weep holes (2). Just before failure in a water pump, it will leak antifreeze out one or both holes, usually the bottom hole. Also, check passenger floor for dampness, which would mean heater core or heater core hoses are leaking
Nov 14, 2013 | Chevrolet Cars & Trucks
Antifreeze is leaking bad in 2008 dodge charger
older model water pumps had what was called a weep hole under the bottom just below where the shaft goes into the pump when the pump is going out the weep hole will let water leak out(antifreeze)
hope this helps !
Dec 19, 2011 | 2008 Dodge Charger
My car is leaking water from the bottom of water pump what could it be
There is a small hole (called a weep hole) on the underside of the water pump. Coolant will leak out of this hole when the water pump goes bad. Verify the leak and replace the water pump
Aug 30, 2011 | 1998 Saturn SL
Overheating, small water leak don't know where it is leaking could be water pump
Water pump has a small 'weep' hole that is probably leaking-an internal seal is now leaking though this weep hole and the only fix it to replace the water pump.
Dec 28, 2010 | 1984 Toyota Corolla
My 1982 ford f150 is leaking from the water pump over flow why and what to do to stop this. the fluid is also a brown color.
If you are referring to the weep hole in the bushing that the shaft comes through, this is the primary failure mode for water pumps. Once the packing comes loose in the bushing, the pump must be replaced. If this is not what you were talking about, please reply.
Sep 15, 2010 | 1982 Ford F 150
2000 Jeep Grand Cherokee Limited
No, what you're seeing is the weep hole leaking on the water pump. This is the warning sign that the water pump is worn out. Don't use any stop leak or anything to attempt to stop it. You'll be waisting your time. You'll have to replace water pump at this point.
Jun 13, 2008 | 2000 Jeep Cherokee
Garden Logo
271 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
