Question about Samsung RS2630SH Side by Side Refrigerator
Frezer doesn't work
The water dispenser and freezer doesn't work. The refrigerator seems to be working at 38 degrees but the freezer is 54 degrees.
We have a different model, but had the same problem. The evaporator fan motor has most likely gone out. If the air doesn't move over the coils they start to get frost on them and it causes the water reservoir to freeze as well. It's located on the inside back wall of the freezer, behind the panel.
Posted on Jun 22, 2007
Frigidaire side by side Freezer only freezing top shelves, warm at the bottom
Its defrost issue.
Defrost cycle is not taking place on time or its not working at all.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Frigidaire Refrigerators
Kenmore Elite bottom freezer, model number 596.76522500, Serial Number 10310256GL. Water dispenser on the inside left of the refridge. Water dispenser is not working, items are frozen in refridge. Ice...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Water dispenser system
the dispenser in the freezer door has a small low temp heater surrounding the dispenser compartment to keep this from happening, and also to keep condensation from building up around the dispenser. this heater may have stopped working.
May 22, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Maytag refrigerator, Model MSD2454GR
Your best bet is to shut the unit down for a while and let it defrost. You've probably got your box set too cold. 0-5 degrees on freezer...38-42 on fridge side. If your unit is not digital, use a regular outdoor thermometer, close the door for half an hour and then open to read it. Adjust accordingly. If too cold...you're using too much energy, too.
Jan 03, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Fridge cooling 54 degrees - freezer 38 degrees and 24 degrees
Will not be the defrost timer as they have a set cycle independant of the normal cycle...unless your fridge is eletronic. Did you stand the fridge up when shifting?
Dec 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Samsung RS2630SH Side by Side Refrigerator Logo
89 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
