Question about Computer, Chip, Cruise Control for Ford F150 Flareside SuperCab
Cruise control blows fuses on 1993 f150
Blows fuses all the time
    Problem Solver:
  • 30 Answers
Sounds like a wire is broke and grounding causing fuse to blow
Posted on Apr 14, 2014
Cruise control not working 97 ford f150
You can see if you have a blown fuse in seconds using my method!
Don't waste time searching for the exact location, just check them
all. You can find it by pulling out each fuse one by one. Don't mix
them up, replace each one as you go, make sure to look at each
one. You may even find you have more than one bown fuse! If you have some needle-nose pliers, they work very well, most times you can use your fingers. Here are a few pictures if your unfamiliar with what your looking for:
Dec 19, 2013 | 2002 Ford F150 Regular Cab
1993 grand prix.blows brake light fuse when u apply brakes
hot wire touching metal fuse blows so you don't burn up the wiring get it tested and fixed soon could be dangerous to keep putting in a new fuse
Jun 24, 2013 | 1993 Pontiac Grand Prix
#15 fuse keeps blowing in my 02 ford f150
If it is Fuse #15, that looks to be an issue with your brake lamps or cruise control.
did you have
recall 05S28. Description: Speed Control Deactivation Switch. Part number 1L1Z-9F924-AA is the last one I have. 14 supplements in the recall series.
If you did not have the recall done, or if the secondary switch has fluid in it, the recall part has failed and needs to be replaced.
If you disconnect this at the end of the master cylinder, and jumper the plug and replace the fuse, does it still blow ?
Aug 21, 2011 | 2002 Ford F150 Regular Cab
I have a 2002 Ford F150. Fuse 15 (5 Amp) keeps blowing.
replace nuetral safty switch for gear shifter and check window relays
Feb 12, 2010 | 2002 Ford F150 Regular Cab
I have a 2001 F-150, 5.4 litre, 4x4 truck. Fuse
first find out the right fuse rating if correct ///operate one electric switch at a time and look for fuse blown ///that part is involved ///
Jan 14, 2010 | 2001 Ford F150 Styleside SuperCrew
# 15 fuse keeps blowing, no windows, no wipers, shift locked...What could be the proplem...noticed that cruise control went out a few months back
possibly the cruise cancel switch on the brake master cylinder is shorted, disconnect the switch and replace the fuse and see if everything comes back to life. the switch may be on the end of the master cylinder, Ford has had BIG problems and RECALLS for this switch going bad.
Sep 23, 2009 | 2001 Ford F150 Styleside SuperCrew
1993 crown vic horn/cruise control won't work
Check the fuse for your cigar lighter/horn. I've seen the fuse blown from the lighter shorting. It will caue the cruie not to work also. I hope this helps. Good luck.
Aug 12, 2009 | 1993 Ford Crown Victoria
1997 F150 4.6l cruise control does not work.where do i start?
Does Ford replaced the cruise control deactivation switch.
Vehicles involved in the recall include the following:
1998-2002 Ford Ranger
1992-1997 Lincoln Town Car
1992-1997 Ford Crown Victoria
1992-1997 Mercury Grand Marquis
1993-1998 Lincoln Mark VIII
1993-1995 Taurus SHO
1999-2001 Ford Explorer
1999-2001 Mercury Mountaineer
2001-2002 Ford Explorer Sport
2001-2002 Ford Explorer Sport Trac
1992-1993 E150-350 Vans
1997-2002 E150-350 vans
1993-1997 Ford F-Series pickups
1993 Ford Bronco
1994 Mercury Capri
2003-2004 Ford F0150 Lightning
1995-2002 Ford F53 motor homes.
May 15, 2009 | 1997 Ford Expedition
Cruise control quit speedometer works
DID YOU CHECK THE RECALLS?? MY 93 F150 HAD A RECALL W/ THE CRUISE CONTROLL (WICH I HAVENT DONE..LOL) AND SUPOSIVLY IF IT ISN'T FIXED IT'LL CAUSE A ENGINE FIRE.. ACCORDING TO THE FORD DEALER IF THIS RECALL SERVICE IS PERFORMED IT CAN POSIBLY MAKE THE CRUISE WORK AGAIN.. (MINE DON'T WORK EITHER) I DONO.. MABE IT'S THAT.
Oct 30, 2008 | 1993 Ford F150 SuperCab
Computer, Chip, Cruise Control for Ford F150 Flareside SuperCab Logo
103 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
