Question about Dell Inspiron 620 ST Desktop Computer Intel Core i32100 processor (DDDNKT1)
Dell unstick power button on PC desktop
I just went to power on my dell Inspiron 620s desktop computer and noticed that the power button is stuck down . now we can unstick it but we cant get power to the computer
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.
Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855
Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123
Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
Posted on Dec 02, 2012
SyNNeR6x3
  • 19 Answers
SOURCE: dell model DHM DESKTOP which is stuck while plug in .
Try this out:
1. Hold down the Start (Windows Flag Key) button on your keyboard and press R
2. Type this Command : shutdown.exe -s -f -t 00
This will shutdown all running programs and shutdown windows Instantly.
Optionally you can create a desktop shortcut to do this automatically. Here is how:
1. Right click on any blank space of windows desktop -> New -> Shortcut. A “Create Shortcut” window will open.
2. In the blank, type in:
It means, shutdown and wait for Zero second. Click “Next” button for next step.
3. Type in whatever name you like in the blank. I use “Turn Off PC”. Then, click “Finish” button.
4. You are finished . A new shutdown shortcut has been created on your windows desktop!
Just click on it to shutdown.
Posted on Dec 07, 2008
leecom72
  • 4806 Answers
SOURCE: computer not coming on
jsparo could be right, however, there could a number of causes for this, start by opening the side panel, take out the system memory, clean the memory contacts and slots of dust with a dry, clean, soft paintbrush, re-seat the memory firmly and try to boot the PC again.
Make sure you pull the power cord from the rear of the desktop before opening the side panel.
Good luck and thanks for using Fixya!!
Posted on Feb 26, 2009
SOURCE: comp. powers on, shuts down three times then goes into powersave
I had a similar problem...I'd turn on my Inspiron 530 and it would power up and shut down by itself several times and then finally finish booting up but nothing would show on the screen.
Turns out, it was a bad video card. Since there are two ports for hooking up a monitor -- I ended up hooking up the monitor through the VGA and completely removed the video card (just used the built-in device on the motherboard). This solved the problem and it booted up straightaway.
Dell is sending the replacement video card and I will just use the built-in until it arrives.
I hope this helps with your problem!
Teachinfourth
Posted on Jul 19, 2009
  • 1019 Answers
SOURCE: My Dell Dimension desktop 9150 was running very
the constant Green, states that the motherboard is getting Power.
The red/yellow would possibly suggest, that the ethernet port has a fault or possible corruption.
Solution:- remove the Power Lead from the Computer Case.
Remove side panel. take out any ethernet-Cable from the rear.
Locate the CMOS battery, round silver Battery on The motherboard.
For 10 seconds, this should reset The bios, to it,s original Default Settings. Replace Battery, side Panel. And power Lead.
You could also try This. Boot with Hard-drive power Cable Disconnected ( this will Eliminate HD Fault ) same for CD/DVD drive et,c.
Mike @ Compurepair.
Posted on Oct 23, 2009
SOURCE: my dell inspiron 531 desktop enters auto detect power save mode
start your computer in safemode and then turn off all power saving features
Posted on Apr 11, 2010
Looking for the dell inspiron 620s back pannel
look on ebay or search google for a Dell second-hand refurbisher that may be able to help.
Sep 10, 2014 | Computers & Internet
Dell inspiron reset button
Poen casing, clean up Power button.
Apr 05, 2014 | Computers & Internet
Dell 620s flashing yellow start button
Generally this means that it can't find the system disk. Most of the time if you press and hold down the power button, the computer will shut down. After that, restart and see what happens.
Jan 27, 2013 | Dell Inspiron 620 ST Desktop Computer...
My dell inspiron 1100 does automatic press the q button... How do i fix that?
Make sure no key next to it is causing it because the keys are stuck together. Hit the q key repeatedly to unstick it.
It may be time for a new keyboard.
look on ebay for a new keyboard. Just put Dell Inspiron 1100 Keyboard in the search box.
http://www.ebay.com
May 08, 2012 | Dell Computers & Internet
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
I can't activate the bluetooth because there is no FN key on my keyboard. It says to activate the bluetooth to press FN+F2. There is no FN key on this keyboard. Is there a way around this?
Hi ,
You need to look for a key tthat says FN, should be on the bottom left , of the keyboard , you must have one , if not tell me your computer make and model , and I will advise futher .......Good luck Roy
Oct 01, 2011 | Dell Inspiron 530s Desktop Computer
Dell Insprion 530--No start up. Just hum.
Try this link....!
http://forums.techguy.org/windows-vista-7/787925-solved-dell-inspiron-530-frozen.html
Good luck,
Hank
Jun 11, 2009 | Dell Inspiron 530s Desktop Computer...
Dell Inspiron 620 ST Desktop Computer Intel Core i32100 processor (DDDNKT1) Logo
332 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
